I drilled out a hole... Is it a lost cause now?
  • CplusJ
    • Sep 2010
    Newbie here.
    Wish I would have found this forum before I did what I did.
    I had two capacitors that needed to be replaced not the circuit board of my plasma TV.
    Taking out the old capacitors was no problem.
    Clearing the holes wasn't working, so I got the smallest drill bit I had, yes it was a fraction larger than the original hole, and I dialed out the old solder.
    When I soldered in the new capacitors the problem was not fixed (obviously).
    I read that it's a disaster to drill out the holes.
    Define disaster?
    Is the board hopelessly ruined and not worth taking it to a professional now?
    Is it possible I just did a poor soldering job and that's why the repair didn't work and not because I drilled out the hole?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: I drilled out a hole... Is it a lost cause now?
    It's -possible-.
    Also possible the caps were not the only problem.
    Probably.
    I doubt a professional would take on the job and even if they did the outlook on fixing it isn't good.
    Define disaster?
    You know those strips of copper on the top and bottom of the board..
    Multi-layer boards have them in between layers too.
    The insides of the holes are plated and the plating is what connects to the strips in between layers. [It's called a Via.]
    You removed the Via.
    The odds of getting a good connection by filling the hole with solder are slim.
    Mann-Made Global Warming.
    - Dr Seuss
    • Toasty
      • Jul 2007
      • 4171
      Perhaps one of the TV guru's could help. There are hundreds of TV's out there and every board is different. Please include the make, model, size, and what board you did this to. Pictures are a great help, so take some of the whole board, the part number of the board, and the area in question. Also, post what the problem/symptoms were and why you believed it was the caps.
      Welcome to the forums and I hope this works out for you.
      Toast
      veritas odium parit
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Follow the traces and find a different spot to solder the caps to. At worst, you cut some traces and you'll need to solder some wire to reconnect them. It isn't easy, but definitely not impossible.
        Last thing i fixed with a piece of wire were 2 cut traces to the CPU socket of an AM2 board. That was definitely hard to do, but i fixed it. Board's still working fine atm.
        A working TV? How boring!
        • Toasty
          • Jul 2007
          • 4171
          I defy you to do that with the sandwiched traces --> the ones you can't see.
          That's what PC is trying to explain here.
          veritas odium parit
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Exactly.
            You can't solder to the traces between layers because you can't get the edge of the trace hot enough for a solder bond before the PCB material starts melting and contaminates the hole and solder with crap.
            If CplusJ is lucky that particular joint doesn't have any connections between layers but there is usually no way to tell.
            - Dr Seuss
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              if you are real lucky its just double sided.in which case its no big deal.
              any more layers and you are f***ed.
              • larrymoencurly
                • Oct 2004
                • 960
                This circuit board repair company recommends drilling a slightly larger hole, to just the depth of the inner copper layer. That sounds easy, like brain surgery with chopsticks or the D-Day invasion.
                http://www.circuitrework.com/guides/5-0.shtml
                CPlusJ: I don't mean to rub it in, but why ever try a drill bit slightly larger than the hole, as opposed to slightly smaller, even if it's the smallest bit you have?
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  It's not that easy.
                  I've done it with aid of a bottoming cutter and a mill.
                  If you cut too deep the copper is gone too.
                  If you get it too hot the copper might delam, catch on the bit and rip right out.
                  By hand forget it.
                  Even with a drill press chances are you will cut too deep.
                  Drill presses are sloppy when it comes to something with this little margin for error.
                  With an actual mill [a good one] and a REAL sharp cutter you can remove .001" at a time if you want to.
                  - Dr Seuss
                  • MXM
                    • 430
                    • Unknown
                    wel dude at least you have finally found this site
                    hope you make it work again, take into consideration all youve been said here, some pics and specs will definetly help help you.
                    -and welcome to the site,
                    peace.
                    We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
                    • severach
                      • Aug 2007
                      • 1055
                      Many bad capacitors are found on power supply boards and many power supply boards are single sided. If the board is single sided then drilling is safe but usually unnecessary. Single sided boards are easy to work with. Two sided and multi layer boards are where drilling is a problem.
                      If the through hole plating connected to an inner layer then the board is toast unless in the unlikely event you can find another way from the surface to connect to that same point.
                      If all the through hole plating did was to connect the two outside layers then you have a chance. Solder could easy fulfill the same job. The problem is that getting the solder to flow all the way through requires a lot of heat and you can't get it from a soldering gun alone. By the time the area is hot enough to flow the solder the gun will burn all nearby traces. A hair dryer is too hot and too wide.
                      A regulated soldering gun with a regulated hot air station has a chance to get the solder all the way through with some help from flux.
                      sig files are for morons
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        It's probably just double sided. If he drilled thru anyway, why not simply use a piece of wire to connect the top and bottom traces?
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5037
                          • New Zealand
                          I imagine that IF the traces on the internal layers also connected to another via nearby which also connected to one of the outside layers, you could hardwire it that way.
                          But that would no doubt require the schematic etc and then there's no guarantee that the vias you needed were actually there.
                          Hope like hell that it's only double sided!
                          -David VanHorn
                          • Toasty
                            • Jul 2007
                            • 4171
                            I think the OP has been lost.......... helllooooooo?
                            veritas odium parit
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5037
                              • New Zealand
                              Maybe he forgot to enable email notifications and thinks nobody has replied to his post?
                              -David VanHorn
                              • Toasty
                                • Jul 2007
                                • 4171
                                Could be. i always thought some of the forum defaults were "backwards"...
                                veritas odium parit
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5037
                                  • New Zealand
                                  Most forums I have signed up to seem to have email notifications disabled by default.
                                  Got caught out once when someone replied to a message and I didn't know, only came across it again by accident almost a year later!
                                  So after that, I always make sure the first thing I do when I sign up anywhere is enable all email notifications
                                  -David VanHorn
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    I just noticed this
                                    Agent24
                                    Fuhjyyu Killer
                                    Isn't killing Fuhjyyu a mute point? They are already suicidal. - LOL
                                    - Dr Seuss
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      I lol'd at that!
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5037
                                        • New Zealand
                                        Originally posted by PCBONEZ
                                        I just noticed this
                                        Agent24
                                        Fuhjyyu Killer
                                        Yeah, I guess so. I think I wanted something unique and couldn't think of anything else at the time...
                                        Perhaps "Fuhjyyu correction therapist" would be better?
                                        -David VanHorn
                                        • 13mh13
                                          Aluminum SMD caps vs thru hole caps (reliability)
                                          by 13mh13
                                          The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
                                          https://i.postimg.cc/kGrR6BpZ/image.jpg
                                          I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
                                          I have not tested/replaced those alum. SMD electro PCB caps.
                                          Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
                                          All the thru hole electros I removed / replaced on this CDP (and most...
                                          04-05-2024, 07:41 PM
                                        • jjkevi
                                          Lost MAC Address After BIOS Rewrite – Need Help Restoring on HP 800 G1 SFF
                                          by jjkevi
                                          I’ve run into an issue with my HP 800 G1 Small Form Factor PC after performing a BIOS rewrite. Everything works except for one major problem — the MAC address for the onboard network adapter is missing.
                                          Here’s the situation:
                                          • Model: HP 800 G1 SFF
                                          • OS: Windows 10 Pro
                                          • Cause: After rewriting the BIOS, the system lost its original MAC address.
                                          • Symptoms:
                                            • Network adapter shows a generic or invalid MAC (or sometimes blank).
                                            • No Ethernet connectivity unless I use an external USB-to-Ethernet adapter.
                                          • What I’ve tried:
                                            • Checked BIOS settings (no MAC override
                                          08-11-2025, 05:05 AM
                                        • jerem57m
                                          Lost bios password on HP Spectre Pro 13 G1 (X2F00EA)
                                          by jerem57m
                                          I hope I'm in the right place to make my request. Now that I've made my presentation, I'd like to make a request regarding a 2017 HP Spectre PRO 13 G1 laptop. I have a lost BIOS password. I really don't remember setting a password on this computer, and after changing the battery, the computer no longer wants to boot without it. Can you help me remove the password?
                                          I read on the forum that someone who had a model similar to mine managed to remove the password, so I figured with any luck I'd find some help here.
                                          Exact information:
                                          Product: X2F00EA
                                          Trade name:...
                                          07-17-2025, 06:26 AM
                                        • rive.hafintosh
                                          HP Probook 650 G4 - Lost power?During AMT de-provision process, now I get blackscreen
                                          by rive.hafintosh
                                          First here is how things went down.
                                          I entered the bios and began to de-provision Intel AMT - it began with a reboot and then prompted me to de-provision AMT - proceed Y/N -
                                          I pressed Y and hit enter, and I thought the PC shutdown, but perhaps it actually lost power at this point. I had the power adapter plugged in but apparently the plug from the wall came out of the brick when I wasn't noticing so 1 of two things could have happened…
                                          Something went wrong with the process, or it lost power during the process and corrupted something
                                          I tried making a HP recovery...
                                          10-12-2023, 07:42 PM
                                        • ktmmotocross
                                          Did all laptop works when they lost one of power phases for cpu?
                                          by ktmmotocross
                                          Hello.
                                          Have this acer nitro that have short on 1of4 for powerstage for cpu. i remove shorted drmos and power for cpu and laptop start but have no video or BL on lcd. all voltages are now ok. as i see there is some amateur injection marks so i think someone toasted cpu with highvoltage.
                                          quistion is - should all/most of laptop works in basic when lost one of power phases for cpu/gpu ? i know that many does, but did all?...
                                          04-25-2025, 02:06 AM
