Battery
  • Shodan486
    • Nov 2009
    • 203
    Battery
    HI! All
    Should I be worried of the CMOS battery installed in a mobo while measuring ESR? Can something be damaged?
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Battery
    you should be testing them out of circuit... just to be safe.
    sigpic
    (Insert witty quote here)
    • Shodan486
      • Nov 2009
      • 203
      Re: Battery
      But when that's not possible?, i.e. DALLAS chip soldered directly to board ?
        • 31278
        Re: Battery
        those modules only leak current on a couple of data lines that wont have caps on them - dont worry.
        • Shodan486
          • Nov 2009
          • 203
          Re: Battery
          I hope I made my self clear when I said ''while testing ESR'' OF CAPACITORS on the mobo, not the battery itself
            • 31278
            Re: Battery
            he means to be safe with the readings.
            you cant trust testing caps on the mobo because you will be metering the stuff the cap connects to.
            like more caps!!!
            • Shodan486
              • Nov 2009
              • 203
              Re: Battery
              like more caps!!!
              Guys!
              I really don't mean SAFE WITH READINGS...I mean if I can damage anything just by connecting the wires to the pads and activating my ESR meter. Don't care about the readings, just the current going thru the circuitry...so can be damaged something ?
              • Shodan486
                • Nov 2009
                • 203
                Re: Battery
                I just tested ESR on all caps on a VP6 I got from my neighbour he found in TRASH(!!!) but left the CMOS battery in the socket while testing the caps, all of the electrolytic ones over the board - thus can I damage some parts on the mobo?
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Re: Battery
                  Safer to remove CMOS battery when possible but probably won't damage anything if you don't.
                  Handling and static are more likely to zap the BIOS chip than the meter as long as you are sticking the probes where they, um, should be stuck...
                  As someone tried to say,
                  you can't check VRM caps in the board because of parallel paths.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • Shodan486
                    • Nov 2009
                    • 203
                    Re: Battery
                    And what happens if I use an ESR meter (particularly PEAK) for example measuring a crystal or a coil, MOSFET, just DOING dumb stuff - can be the board, particular part or the meter damaged this way? or ALL of them?
                    or for example just connecting the pads to a CMOS battery socket tips?
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Re: Battery
                      All an ESR meter is is an ohm meter but instead of a small DC volts it uses a small AC volts [usually a square wave].
                      As long as the equipment is de-energized you aren't going to hurt the meter because the meter is where the voltage comes from.
                      The voltage is tiny.
                      The only component you might hurt is one that would be hurt by static.
                      - Dr Seuss
                      • Shodan486
                        • Nov 2009
                        • 203
                        Re: Battery
                        Alright, but let's see - the only energized part in the whole system when unplugged from the PSU is the connection from CMOS battery to the BIOS chip...can something be damaged when putting a for example voltmeter somewhere to this path, again, doing dumb stuff...imagine a little kid playing with an ESR meter just putting the probes wherever his young heart desires...just imagine this dumb situation - HOW can I damage a motherboard with such instruments - is it even possible? And when you guys measure the ESR of some caps, do you extract the CMOS battery from the board?
                          • 31278
                          Re: Battery
                          to be safe, remove the cmos battery - best to fit a new one after anyway.
                          and far more important, short the caps out with a screwdriver before you meter them.
                          or you may find one charged with 12v in it!
                          • Shodan486
                            • Nov 2009
                            • 203
                            Re: Battery
                            not with my meter, able to discharge...but again, how can I damage a mobo with these tools?
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Re: Battery
                              How many different ways are you going to ask the same question?
                              Originally posted by Shodan486
                              HOW can I damage a motherboard with such instruments.
                              You can't unless you beat the motherboard with the instrument.
                              You would damage it with static from your hands first.
                              - Mobo caps have discharge paths. They don't stay charged.
                              Yes.
                              Probably not necessary but I and I think most people do.
                              - Dr Seuss
                              • Shodan486
                                • Nov 2009
                                • 203
                                Re: Battery
                                many times if necessary, PCBONEZ ....
                                Okay, i think i made my point out...just asking sometimes crappy stuff, but it interests me so much..any other possible destructive ways, guyz?
                                  • 31278
                                  Re: Battery
                                  the most motherboards i see damaged are from the screwdriver slipping as they are removed or the heatsinks unclipped!
                                  • Shodan486
                                    • Nov 2009
                                    • 203
                                    Re: Battery
                                    got a bit astray question : what are the rated voltages of those little MLCC caps? From what values do they range? And the capacitance? I've browsed a lot and found some from 50v to 100v, sometimes the capacitance was not provided.
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Re: Battery
                                      http://www.mouser.com/Passive-Compon...ded/_/N-4gzxj/
                                      http://www.mouser.com/Passive-Compon...-SMT/_/N-b2cj/
                                      - Dr Seuss
                                      • Genghis_Khan
                                        ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
                                        by Genghis_Khan
                                        I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
                                        Issue summary:
                                        Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
                                        However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
                                        11-11-2025, 11:51 AM
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • mkdj
                                        by mkdj
                                        Mark and model: ASUS X571
                                        Tests already made:
                                        - I have removed...
                                        07-14-2025, 09:16 AM
                                      • techfreak9356
                                        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                        by techfreak9356
                                        09-14-2023, 11:10 PM
                                      • magistertc
                                        CMOS battery drains quickly
                                        by magistertc
                                        This problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
                                        as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
                                        Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
                                        Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
                                        configured to support the RTC and some volatile RAM (when SMPS is on). What you may...
                                        07-06-2024, 09:55 AM
