Please help me fix my beloved Panasonic TC-P65ST30
  • Ren01
    • Aug 2021
    • 33
    My beloved TC-P65ST30 suddenly stopped turning on last week, no LED lights on at all, and it deserves a lot better than being tossed out. After some youtube troubleshooting steps, I was able to find a blown ceramic capacitor, C404 on the main power supply board, picture attached. All 5 fuses on the PSU seem to have continuity.
    I’m not sure what the actual rating was since the label side is blown off, but there are other capacitors of similar size on the board rated at 470pf and 1KV. Would it be a safe bet to replace the cap with one rated with this?
    I also check the adjacent capacitor, C403 and it seems to measure as a short. I guess I should replace that too?
    My concern is that there might be bigger issue that is causing these capacitors to blow in the first place. Should I go ahead replace the capacitors and hope for the best? I’m not sure how to check if the inductors are good. Some are measuring low resistance and others are measuring as an open.
    Also, I’m not sure, but these IC’s look kind of dodgy too. One might be a little malformed.
    Last edited by Ren01; 08-30-2021, 01:51 AM. Reason: Pictures didn’t show up correctly
  • ivtec
    • Dec 2008
    • 1967
    Re: Please help me fix my beloved Panasonic TC-P65ST30
    https://www.badcaps.net/forum/showthread.php?t=77174
    https://www.youtube.com/watch?v=EShySnyZl1E&t=139s
    • Ren01
      • Aug 2021
      • 33
      Thank you! Your second link in particular seems to have a similar failure. I replaced the cap on mine already and it still doesn't power on :/
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4346
        • Italy - Milan
        These photos are way too few to understand something of the board without a schematic... Don't use that method of posting picture, use paperclip in advanced editor, first to upload them, second to attach..
        • Ren01
          • Aug 2021
          • 33
          Thank you, I'll edit the first post. What additional photos would you recommend?
          EDIT: Seems I can no longer edit the first post.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4346
            • Italy - Milan
            Total and some zoom in..
            • Ren01
              • Aug 2021
              • 33
              Hopefully my updated last post will suffice. Please let me know if there are any other photos I can provide.
              • Ren01
                • Aug 2021
                • 33
                The circled red components are showing low resistance.
                C403 ~3.5 Ohm. This has already been replaced, but short persists.
                C411 ~1 Ohm
                C408 ~100 Ohm
                C404, the blown capacitor, has been replaced with a 470pf 1KV capacitor too.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4346
                  • Italy - Milan
                  Now the goal is to show you where to test with a cellphone..
                  Do you know how to test diodes, mosfets and diode bridges and how to identify them? If yes start to test them, all the ones under heat sinks.. then test all varistors, them are two legs black round items, all in primary seems..
                  C404 is across high voltage and low voltage pins of the I401 that is a power oscillator for the transformer, its inside power mosfet is in short.. check if under heat sink there is a 2W resistor low ohm open...
                  • Ren01
                    • Aug 2021
                    • 33
                    Not super sure how to test those. I only have a basic multimeter, but I think diodes should be low resistance one direction and open the other way? Mosfets just shouldn't be shorted? Don't know what a diode bridge is haha.
                    • Ren01
                      • Aug 2021
                      • 33
                      Will do!
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4346
                        • Italy - Milan
                        yes for the diodes/mosfets, diode bridges are groups of 4 power diodes integrated in a chip, you can find inside draw on the web, you have 4 of them, two in the slim ac input board and two to the secondary to left of two transformers. Test them so, there's a mark on board for the - and +, there are 4 pins, put black to - pin red to the near pin, must read open, shift both probes one pin to the right, read open, so on until red probe is on the +, now swap probes and restart from - pin, repeat the same but must read low ohms in ohm, low volts in diode mode..
                        • Ren01
                          • Aug 2021
                          • 33
                          Thank you! There's no resistor under the heat sink, only one diode. Do you think I should go ahead and remove it and try to source a replacement?
                          • Ren01
                            • Aug 2021
                            • 33
                            Desoldered the mosfet and heatsink It went by surprisingly easy! No idea how to test it though lol. I'll try pulling up its data sheet.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4346
                              • Italy - Milan
                              first dismount it, then measure between the leg connected to transformer and the one to negative if there is a short, swap also probes, if short or open then must replace it..
                              • Ren01
                                • Aug 2021
                                • 33
                                Do you mean the two pins circled in red? I think, but I'm not sure it's pin 1&2 or drain and source according to the data sheet?
                                When the two circled pins are checked for continuity I get 1 or 2 ohm regardless of which probe touches which lead, but it also seems to take some time, a few seconds, to reach that figure.
                                Edit: Oh, awesome! the short on the capacitor C403 disappeared after I removed the mosfet! It's now 125 ohm one way and open the other! Thank you so much! C411 is still shorted though, should I replace it too?
                                • Ren01
                                  • Aug 2021
                                  • 33
                                  If I’m reading the datasheet for the str y6766 correctly and following pcb traces correctly c411 only connects source to ground. What would be an appropriate value to replace the shorted capacitor?
                                  I think this is a bypass or decoupling capacitor?
                                  • Ren01
                                    • Aug 2021
                                    • 33
                                    Odd that the sample circuit off the mosfet data sheet doesn’t have a capacitor from source to ground. Do I even need to replace this surface mount cap?
                                    • Ren01
                                      • Aug 2021
                                      • 33
                                      This diagram from the data sheet has me second guessing c404’s capacitance which I guessed as 471pf and 1kv when it is 100pf 2kv in the diagram :/ someone in a previous YouTube comment said it was 330pf at 1kv
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4346
                                        • Italy - Milan
                                        Yes for the 1 & 2 pins, but since there is a source pin there is / are also a 2w less than 1 ohm resistor connected to source or many smd resistors in parallel (1/2 ohm). Why you have guessed 470pf?
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • aa10aa10
                                          Panasonic Toughbook CF-33 mk1 BIOS repair
                                          by aa10aa10
                                          Good day,
                                          I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                          I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                          01-21-2025, 06:13 AM
                                        • Mnawar27
                                          Panasonic CF-H2AU24EF3 bios locked
                                          by Mnawar27
                                          Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                                          I need help to remove it,
                                          thankyou all.
                                          SN; 2FKCA26876...
                                          11-16-2024, 08:00 AM
