Panasonic TC-P65VT30 No Power, No LED
  • pokepoke0610
    • May 2014
    • 28
    A friend of mine experienced a power surge that damaged his Panasonic Viera TC-P65VT30 Plasma Television. The symptoms are no signs of power and no blinking LED code nor is the LED lit. After taking off the back, I inspected the boards and performed the testing advised on pages 25-27 of the Service Guide for Panasonic Plasma TVs. In ohming out each of the pins on the SS, SC and A boards I didnt find a short circuit to GND. I made these
    measurements unpowered with each connector disconnected from the power board. This seemed to indicate that I should replace the main power board.
    I did inspect the power board (PDF and photos attached) which showed some damage. Feeling good I ordered a new main power board, plugged it in and experienced the same result. No change. No LED, no blinking, no clicking of either relay, nothing.
    WIth the new power board installed, I measured the voltage of connector P6 on the main power board. All pin voltages were 0V except pin 6 which measured 5.06V. I am assuming this is the standby supply.
    The voltages on connect P35 were all 0V. The voltages on pins 1 and 3 on "connector" P34 was 15.66V and 0V on pin 2.
    I have inspected the A board with a magnifying glass and cant see any signs of damage (like on the power board), although that doesnt mean there isnt any but I didnt see anything obvious.
    Any suggestions or ideas would be greatly appreciated as to what the next step(s) is. Thanks!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Panasonic TC-P65VT30 No Power, No LED
    I see a bit of flux residue in photo 3 but no damage.
    Did you check all the fuses on the power board ?
    What about the other two power boards ?
    • R_J
      • Jun 2012
      • 9551
      If you have STB+5V on P6(6) going to the main baord, and you don't have any voltage (or voltage change) on P6(1) PANEL_MAIN_ON when the power button is pressed, I would start checking the main board, I suspect that's where your problem is. Likely that pos PEAKS ic. But there are a number of 0Ω resistors off the STBY+5V line that should be checked, maybe one might be open. also check ic5000, looks like it supplies stb1.2v and stb3.3v
      • Beau28713
        • Feb 2018
        • 50
        Check your MosFets on the SC and SS boards for shorts across the Drain and source.
        • pokepoke0610
          • May 2014
          • 28
          Thanks for the responses.
          diif: I checked all the fuses I could find on the power boards including a few surface mounts and all were fine. I will go back and look for the all the fuses called out in the
          service manual again. I have checked the fuses on the PSUB board. I have also applied power to the 2 relays with the board removed and heard them click at around 8V (and hold at much lower voltage) so my guess is that board works.
          R J: Am I correct that you are asking me to check pin 1 of P6 on the power board. Is a voltmeter going to register a significant enough change or does it require an oscilloscope (which I dont have)? I will try that.
          Without a schematic (and any voltage labels on the board) it is a bit cumbersome to trace out the STBY+5V but will do my best. I will do my best to find ic5000 and find stb1.2v and stb3.3v.
          Beau28713: Do you know specific mosfet instance numbers to check on the SC and SS boards?
          • R_J
            • Jun 2012
            • 9551
            pin1 of P6 is the power supply on/off pin, it will change from 0 to 3.3 volts or 3.3 to 0 volts when the power button is pressed, IF the main board is working, but I suspect the main is bad
            Look at post #2... a service manual. its not the best but it is better than nothing. There is no point checking the ss and sc boards if the main is not even turning on the power supply. (disconnect them from the power supply if you suspect them) If the main was working you should at least get the front led, flashing an error
            • Beau28713
              • Feb 2018
              • 50
              I agree with above post
              • pokepoke0610
                • May 2014
                • 28
                R_J: There was no change in the voltage of pin1 of P6 (it stayed at 0V) when the power button was pressed. I still need to find IC5000 (and STB1.2v and STB3.3v). Will try and get to that this weekend. It seems as though the main board is damaged and should be fixed/replaced, but am wondering what the likelihood of other boards being damaged is.
                • pokepoke0610
                  • May 2014
                  • 28
                  I ended up buying a new main board and installed it with the original power boards. TV powered up and worked great!
                  One interesting note, I originally powered up the TV with the new main board through my dim bulb tester (with a 100W incandescent bulb) and the TV didnt power up at all (didnt hear any relays click). Only when I plugged it in directly to the wall did the TV work properly.
                  Thanks for the advice!
                  • R_J
                    • Jun 2012
                    • 9551
                    The whole tv will draw too much current and too much voltage will be droped across the bulb for the tv to work, the lamp test is more for just testing the power supply by itself.
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • JDC
                      (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                      by JDC
                      ONN 100012588
                      Issue: No Power, Then Rebooting After Main Board Change
                      Short answer: replace main board and power board
                      Technical answer: replace main board and Q306 & Q307 on power board.
                      Long answer:
                      TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                      07-15-2022, 07:39 AM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • cheeky2
                      by cheeky2
                      05-25-2024, 03:27 AM
                    • edugimeno
                      LG 43LJ594V main board not providing stby power
                      by edugimeno
                      I there!
                      I have this TV set that doesn't even light up the st by led. I fully checked the PS board and this one is fine, it provides 8.9V when Stdby and 13V when ON (forces by DRV_ON pin according to service document)
                      So I checked the main board and it is not able to even light up the stdby led and of course it won't obbey to ON button or remote signals
                      I checked all caps on board, none of them is shorted. I took some voltages at those caps, some of them have 8.9v on one side, some don't have any voltage. I see some coils and smalls IC's near banks of SMD...
                      05-14-2023, 12:41 PM
