Need some advice on IT8227E-256 Embedded Controller (EC))
  • SysGhost
    • Mar 2021
    • 12
    • Sweden
    There's this laptop that needs a new EC chip (IT8227E-256). I can buy these on Ali Express. But those would come unflashed/empty. Before I venture into this replacement, I need to dump the firmware of the original EC, and flash that onto a new EC.
    But I can't find any information at all on those.
    Do anyone out there have any pinout/schematics on these chips, and what one needs to dump and flash those?
    Maybe there's a JTAG or something similar I might have missed.
    The computer in question is a Lenovo E14 Gen2 (Quite new on the market)
    Pictures on the motherboard are attached. (See motherboard_back.jpg, middle left, for the chip in question. It's the QFP128 package with the big "Lenovo" print.)
  • m.maher
    • 32
    • egypt
    Re: Need some advice on IT8227E-256 Embedded Controller (EC))
    can this help?
    • mon2
      • Dec 2019
      • 14725
      Not to be Debbie Downer but if this EC is not working, what are the chances the firmware can be extracted over JTAG ? I suppose it is still worth a try.
      No experience with this area yet but thought @SMDFlea or another tech noted that the EC firmware is often inside the host BIOS. If true, would the bios not reflash this firmware onto the virgin IC ? Or can the EC firmware be extracted out of the BIOS dump ?
      Update - see attached portion of the pinout - thanks @m.maher!!
      From what I can gather, this EC is a SPI BUS MASTER. Respectively, the firmware is stored on an EXTERNAL SPI FLASH device. The CS pin is driven by this EC.
      Based on the direction of the arrows on the SPI pins, this EC device is the MASTER and there must be an external SPI flash that offers the firmware.
      Can you confirm this detail ? If this assumption is correct then you can solder in a 'blank' IC which then should fetch the firmware from the external SPI flash device which is still onboard.
      • tahc81
        • Nov 2019
        • 42
        • Slovakia
        Hi all, any update here? Many laptop BIOSes include EC image, but question is how the EC should know, where it is located? Always same base address? Decoding UEFI layout?
        • Antonynl
          • Apr 2021
          • 74
          • Nederland
          From what I now understand the kbc fetches the bios image of the kbc from the Winbond chip via spi. I do have a NM-B911 with the same IT8227 kbc that shows no clock.
          • jamesp
            • Mar 2017
            • 55
            • philippines
            @Antonynl
            we have same scenario but for me, in a different mainboard and EC. my EC is a microchip MEC1310-NU and no spi clock measured upon insertion of VDC from power adapter....its was confirmed by checking with my cheap DSO rigol ds1054z, and no MOSI and MISO decoding happens
            • vgecas
              • Jul 2016
              • 1
              • Lithuania
              Many of these new IO chips have integrated flash memory, that can be accessed via keyboard connector.
              • lpraderi
                • Dec 2017
                • 31
                • Uruguay
                @SysGhost
                View this trying to fix a NM-D151 with no POST/Display.
                ITE IT8227E on NM-D151 autoprogram itself if internal flash is empty from ECROM image embed on BIOS.
                Checked myself dumping, erasing and program an empty image (all 0xFF) with KBC programmer and dumping again after reboot.
                Contents are exact the same as EC image on lenovo bios dump at offset 0x2C8000 lenght 0x20000 (128k).
                Checked also on Bios downloaded from Lenovo website (Bios.cap extracted from e8cn39ww.exe) and the EC rom image is present at different offset but same lenght/content.
                I know maybe is late for you but may help someone else.
                • HOSCARLY007
                  • Dec 2020
                  • 6
                  • ECUADOR
                  Greetings to all.
                  I need some tip, I cannot extract the bin from the KBC IT8227e-256, make all connections with the RT809H and it seems that it has some trick to enable SPI.
                  I get a message to check the connections, the voltage and that the limit is 10cm.
                  Does anyone have any idea how I can extract the bin?​
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    RT8209H often fails to read ITE chips. better programmer is SVOD or Vertyanov.
                    • SirangKap
                      • Feb 2020
                      • 29
                      • Philippines
                      luckily i read this message before purchasing a PEB-1 expansion board for my RT809F programmer. thanks
                      • jasko_jacker
                        • Oct 2014
                        • 1140
                        • italy
                        Some of these chips are self-programming, while others need to be programmed. However, the self-programming chips may only do so if they are empty. If they are not empty, they might not self-program. Nevertheless, even an older version like Vertyanov 2.x should be sufficient to manage this type of chip. You can find more information on the dedicated Vertyanov programmer forum.
                        https://*******/viewtopic.php?f=170&t=15912&start=3510
                        • narsil
                          Enas
                          • Dec 2017
                          • 86
                          • france
                          It was managed by RT809H
                          PIN 87 CLK
                          PIN 88 DATA0
                          GND
                          VCC (Connect the charger)
                          • Jse Enrique
                            • Feb 2021
                            • 38
                            • cuba
                            thanks for this apointing
                            • SirangKap
                              • Feb 2020
                              • 29
                              • Philippines
                              PIN 87 CLK
                              PIN 88 DATA0
                              GND
                              Woww that's a good news. How about RT809F programmer,will it able to read that EC chip as well?
                              • DeXXter
                                • Aug 2023
                                • 114
                                • Chile
                                @SysGhost
                                Nice, I got a lenovo legion 5 with a blown up EC it8227e-256 and I will get a blank one, I hope it will program itself (I don't have a programmer).
                                • noipi
                                  • Aug 2017
                                  • 84
                                  • Singapore
                                  some can read and write, but the new chipset ICs might not. usually we use SVOD programmer
                                  • Viktor-x
                                    • Oct 2023
                                    • 8
                                    • Украина
                                    PIN 87 CLK
                                    PIN 88 DATA0
                                    GND
                                    Hello, tell me how you managed to read the chip, there are instructions?
                                    • narsil
                                      Enas
                                      • Dec 2017
                                      • 86
                                      • france
                                      PIN 87 CLK
                                      PIN 88 DATA0
                                      GND
                                      SMBUS (rt809h)
                                      • master3112
                                        ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                                        by master3112
                                        I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                                        When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                                        10-29-2024, 09:32 PM
                                      • Spikeman
                                        Dell Precision 3440 support for CPU 11th gen
                                        by Spikeman
                                        Hi, since both the Dell Precision 3440 and the Precision 3450 have the same chipset W480.
                                        I ask you if it is possible to add the correct microcodes for the Precision 3440.
                                        I am adding the list of files that I have extracted from the Bios in order to help you understand if it is feasible.
                                        Precision_3440_1.31.0.exe_extracted Precision_3450_1.31.0.exe_extracted
                                        03-11-2025, 09:54 AM
                                      • titomno2
                                        Surface Pro 7 type 1866 PD controller firmware issue
                                        by titomno2
                                        Hi guys,
                                        Hope you are fine.
                                        I'm struggling to fix a small issue with one of the tablet Surface Pro 7 type 1866 i'm fixing (windows 11).
                                        The boot time is so long (up to 5-10 minutes).
                                        After several attempt I finally find one thing is not right (PD controller firmware is 0.0.0 it can't update to 3.6.1) under device manager I have a yellow mark, code 14 and error as decribed on picture attached.
                                        I don't find any information regarding the error code 0x1803 (and sometimes it change to 0x1804.
                                        In the past I have found that if the update is a success, the boot...
                                        04-27-2025, 01:02 AM
                                      • Robby-Gr
                                        TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                                        by Robby-Gr
                                        I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                                        However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                                        The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                                        Additional issues:...
                                        09-27-2025, 12:02 AM
                                      • stikerun12
                                        G814JI / G614JI MP2960R Firmware (CPU Power Controller)
                                        by stikerun12
                                        HI! Can anyone share a dump from MP2960R Firmware with 8+1 Phase ?
                                        Laptop model is G814JI with 13650HX Core, RTX4070 GPU.
                                        Also the mobo is the same as G614JI.
                                        G614J-PMV-GBM 6050A3438102-MB-A01
                                        09-14-2025, 12:46 PM
