Acer AL2423W LCD Monitor - Bad caps
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Yup, Badcaps.net got hit with bad caps.....the irony!! This is the monitor on my office machine, and man I hate working on my own stuff....but I fired it up this morning, and only about half the image was showing, and the part that was showing was dark and illegible... I have a 22" spare that I plugged in to use in the mean time while I decided what to do with this one.... I was temped to just trash it, it is almost 4 years old.....but upon looking, a good spec 24" 16:10 monitor is still $400+ new, and this one has good specs. I hate 16:9 for anything other than a TV, and 16:10 aspect ratio monitors are getting harder and harder to come by, so I decided to crack it open and see what was amuck inside it...
    A few pics of it in pieces:
    Anyway, I get it apart and start in the PSU.....low & behold, there's 2 bad Capxon 100uF 25v caps in there. The rest of the caps in the PSU were UCC and Rubycon, all appearing ok.
    The power supply caps:
    I then remove the video processor board which was right next to the power supply, and there was the paydirt..... 8 bad teapo 330uF 16v caps and one more 100uF 25v capxon.
    So now time to replace..... The closest thing I had to 330uF 16v 8mm was 330uF 35v 10mm or 470uF 16v 8mm. I opted to use the 470uF 16v 8mm to replace the 330uF caps, as fitment would be better and 470uF in place of 330uF won't cause any problems. The 100uF 25v caps I have in Samxon, the 470uF caps I used Rubycon.
    After the new caps:
    The junk.....what a pain in my ass capxon and cheap-o-teapo are...
    Back in action and looking crisp and brighter than I ever remember!! YAY!!
    I bought this monitor new back in late 2006 and used it on my main system my at the house. A month ago when I built my new home system, this one began acting quirky. I sprung for a 27" 16:10 LCD, and this one was moved out to the office computer, I figured I'd use till it died and then get a new one. I just couldn't trash a 24" monitor though, so I fixed it....and it lives on!!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • Colt45ws
    • Jan 2009
    • 174
    Re: Acer AL2423W LCD Monitor - Bad caps
    Nice. I think those were well cooked. Shame they cheap out a few pennies and the thing dies before any of the major components go out.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      this is why i often preemptivly fix things i intend to keep.
      last thing i want to do is fix my own stuff.no money in that ;-)
      • japlytic
        • Oct 2005
        • 2086
        Great repair job.
        I think there are DC-DC converters on the video processing board, which is probably why the caps on this board went bad.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          just got one of these off cl $10.
          will only run if the room is warm and you leave it on according to the p.o.
          (turns on soldering stuff and opens a few cap drawers)
          • c_hegge
            • Sep 2009
            • 5219
            Originally posted by Colt45ws
            ... Shame they cheap out a few pennies and the thing dies before any of the major components go out.
            Let's say you save $1 by cutting corners and using cheaper parts. If the manufacturer sells 1000 units, there's $1000 saved and $1000 in extra profit, and they still usually last for a year (the warranty period). It may seem minor for 1 unit, but it adds up if they sell thousands of them.
            • deadlyquasar
              • Mar 2010
              • 1
              Hey guys, I've got the same acer as the op with possibly the same problem. Would anyone be willing to give me a rundown on how to properly test the caps and how difficult soldering on a pcb is?
              So far my electronic tinkering skills are rc cars, led's, and what my hs electronics class taught.
              -edit
              Oh hey, theres this need fourm here dedicated to this kind of information, who knew? =p
              Last edited by deadlyquasar; 03-30-2010, 02:51 PM. Reason: dumb dumb didn't check the fourm
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                Just take it apart and look for bloaters, that's the best way to tell. Apparently, this issue is common for this particular Acer model. Also note the brands. Our FAQ section will give you a rundown on what brands are good and what brands are bad. There's no real easy way to test them in-circuit, and if you remove them to test them, may as well just replace them.
                C_Hegge, the warranty was 3 years on this monitor, it lived 6 months past the warranty. I wouldn't have sent it in for warranty service anyway over bad caps. Not worth my time and money to ship it and hope I get it back within the next 6 months, when I can fix it myself with better parts in about an hour.
                Team : 49813
                Join in!!
                Team Stats
                • faxmonkey
                  • Apr 2010
                  • 1
                  My 3 year warranty also just expired. I had these vertical lines and wigged out picture for a while that would get better after a minute. Now the monitor won't even turn on. I'm going to try to replace all the bad capacitors. Is there a kit for this fix?
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16959
                    Sounds like what mine did. Take yours apart and see what caps it needs. It seems these monitors have different cap brand configs, which result in different types of failures. Take some pics if you can.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • c_hegge
                      • Sep 2009
                      • 5219
                      What I was trying to say was that, to the manufacturer, the $1 they saved on cheaper parts is worth it to them, just as long as it lasts the warranty period, which in this case, it did, since they don't have to fix it for free.
                      Also, I realise that you, myself and most of the other members of these forums wouldn't bother sending it back, but the average computer illiterate end user would, since they would have no idea what the problem was and how to fix it.
                      • 25jai
                        • Apr 2010
                        • 3
                        hi, my al2423w died last month, but it had the problem with starting up and showing weird things until it warms up. This got worse and worse (and takes longer time to warm up) until one day it didnt even turn on....
                        And i was researching and found out what is wrong, as suggested in this site some capacitors were bulging. So i just replaced them, and reassembled back to the display, but it still didnt' turn on...
                        Does anyone know what i did wrong?
                        • dsa44
                          • Apr 2010
                          • 1
                          Mate, I feel your pain, however, no one can really tell what you did wrong. Just double check, tho, did you know the caps have a + and - and have to go in the pcb with the right polarity? Don't dis me if you already knew that, cuz I did not until I just fixed a bunch of bad caps on my acer 2423 power supply.
                          Cheers, and hope that you find the problem maybe by going backwards from what you did.
                          • 25jai
                            • Apr 2010
                            • 3
                            yes, actually i didn't know about the polarity until my friend helped me out cuz i was so bad in the soldering/desoldering and he told me. I followed the capacitor's polarity and they were all matching before. So i don't think that is the problem right there. Any other suggestions?
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              checked the fuses and the psu output voltages?
                              and the caps on the controller board..
                              • andy smethurst
                                • 49
                                The failing of the caps on the invertor board can kill the F.E.T's (field effect transistors) in this monitor. Check these and pico fuse. This happened to me after changing the caps.
                                • 25jai
                                  • Apr 2010
                                  • 3
                                  which one is the inverter board? and where is the pico fuse?
                                  • zapit
                                    • Jun 2010
                                    • 1
                                    My monitor comes on white for a second or two then a series of colored vertical lines travel across the screen then it shuts off (& amber lite?)
                                    Anyone else have this problem? Bad caps? Nothing obvious to the naked eye...Thx.
                                    • nuhhht
                                      • May 2010
                                      • 21
                                      Open it up and check the PSU caps. Post high quality pictures if possible.
                                      • xiphias
                                        • Jun 2010
                                        • 1
                                        Hi, i just had my AL2423W die on me,
                                        While the acer warrenty was still valid, the inbetween company is bankrupt.
                                        For the first time, i opened up my hardware, identified the popped caps (3 bad teapos, 2 bad capxon). accidentally ripped a cable out of the socket, but that was fixable.
                                        My monitor works now, thank you for the inspiration everyone!
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • keepread
                                          Dell monitor PSU vs Dell laptop PSU
                                          by keepread
                                          Hi there!
                                          Someone gave me their old monitor, it's Dell S2715ht.
                                          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                          10-30-2025, 04:45 PM
                                        • wattage
                                          AOC AG493UCX 49-inch monitor - Firmware request
                                          by wattage
                                          Hello Badcaps Community,
                                          I purchased a preowned AOC monitor that is not working and out of warranty. It was sold as not working. I am looking for guidance on self-repair. In particular, I am after the firmware for the monitor. At the end, I have included monitor model information and links to pics and vids of the issue.
                                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                          07-13-2025, 04:41 PM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
