Why does this Antec squeal
  • c_hegge
    • Sep 2009
    • 5219
    I got an Anted SP-400 from work. It had bad caps (fuhjyyu) and would squeal when running. On all the other antecs I've re-capped, the squealing goes away after the re-cap. On this one, however, it persists, even after the re-cap. I have used the following caps:
    1x 3300uF 16v Panny FC
    1x 4700uF 6.3v Nichicon HE
    1x 3300uF 6.3v Panny FJ
    1x 2200uF 6.3v Panny FC
    1x 1000uF 6.3v Ruby YXF
    2x 1000uF 6.3v (for 5vsb) Chemi-con KZE
    Does anyone know why the squeal persists with this PSU?
  • c_hegge
    • Sep 2009
    • 5219
    Re: Why does this Antec squeal
    Oh, and I forgot to add, the pitch and volume of the squeal vary depending on the load.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      look for a 22@50 on the same side as the +5stby.its along the edge behind the opto.
      • c_hegge
        • Sep 2009
        • 5219
        OK, I found it. What should I replace it with? My only options for Low ESR are Panny FM or Nichicon HE
        • 999999999
          • Sep 2006
          • 774
          Either of those caps should be ok.
          Squealing is caused by a switching frequency that puts loose magnetics' windings into a resonant frequency. All it necessarily requires is the loose windings, though since it is a regulated circuit a change in load can cause it, increase or reduce, change pitch, etc. Failing capacitor can effectively seems like a change in load since it's using feedback in a loop the capacitor is in.
          In other words, if all else fails you either locate and replace the squealing part or fix the coils in place better with a dip in lacquer, putting epoxy over them, etc. Not so easy to do the latter if it's a transformer already wrapped up. Some manufacturers used to put heatshrink tubing over them with a limited amount of success, and/or for only electrical insulation depending on who you ask.
          • c_hegge
            • Sep 2009
            • 5219
            I replaced that cap with Nichicon HE, and the squeal still persists. I'm using it now in a computer and it's REALLY annoying. What now?
            Also, do you think that whatever is causing the squeal could cause worse damage to the PSU? or is it just an annoyance?
            • c_hegge
              • Sep 2009
              • 5219
              Hello? anyone?
                • 31058
                you should change all the electrolytics, not just the big ones.
                if it still screams then there is a fix using anti-corona laquer, or epoxy resin.
                • Toasty
                  • Jul 2007
                  • 4171
                  Does it use SMD components on the solder side? I had a cold joint on a SMD resistor cause that.
                  Can you localize the squeal with a paper towel roll used as a stethoscope?
                  veritas odium parit
                  • ss627
                    Super Member
                    • Mar 2008
                    • 52
                    Take the rubber eraser end of a pencil or any other suitable thing and press down on the coils to see if it stops the noise or changes pitch.
                      • 31058
                      SP series is covered in smd, and if they are all like mine then the soldering is crap.
                      (and that's being insulting to crap!)
                      • c_hegge
                        • Sep 2009
                        • 5219
                        I'm not going to plug it in with the cover off. I've been electrocuted one too many times doing that.
                        • Toasty
                          • Jul 2007
                          • 4171
                          Then pitch it in the trash. Most of these require some checking with the cover off and probing to repair. It don't get done by magic.
                          veritas odium parit
                          • c_hegge
                            • Sep 2009
                            • 5219
                            I'm not giving up just yet. I'll try stj's idea of replacing all of the small caps. If that doesn't fix it, then it goes in the bin.
                            • Khron
                              • Sep 2006
                              • 1350
                              • Finland
                              I've persevered in trying to revive an SP-500P (with a bunch of burnt parts), and i've eventually succeeded, without getting shocked, as you might see in the thread i started a bit below I think i read in one of these threads about "1oz of prevention > 1lb of cure", so if you're just careful and don't rush things, you should be fine.
                              I insisted on reviving mine. Dad got it for free from my cousin, it's worth at least 50eu / 70us$, and i managed to source all the parts i needed. Plus, it's CWT-made Talk about "Value for money"
                              Also, you might find some useful tips in this thread .
                              Good luck with the repairs
                              • Pyr0Beast
                                • Feb 2009
                                • 406
                                It would perhaps be good to check the input capacitors. Those 200/400V ones.
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  I'm also not willing to touch the primaries. They rarely fail and, since I'm not an electrician, it's illegal here.
                                  • Wizard
                                    • Mar 2008
                                    • 2296
                                    Illegal? Explain?
                                    Cheers, Wizard
                                      • 31058
                                      i wouldnt worry,
                                      from what i'v seen, licensed electrician's are more dangerous than mokey's
                                      arent your reg's that house wiring (lighting circuits) should have all wire joints twisted, soldered (with a blowtorch) and taped-up?
                                      • ss627
                                        Super Member
                                        • Mar 2008
                                        • 52
                                        I still think you should put a small load on the PSU and plug it in with the cover off and press down on coils etc with a non conductive stick to see if the noise pitch changes. There is absolutely nothing that can go wrong unless you have a seizure and start poking fingers inside or put a prolonged heavy load on the PSU with no fan. You wont be touching anything inside except with a nonconductive stick.
                                        • RetroComputingGrotto
                                          Viewsonic VA2010wb (High Pitch Squeal At Power On)
                                          by RetroComputingGrotto
                                          I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                                          On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                                          The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                                          What component(s)...
                                          02-03-2025, 06:00 AM
                                        • sirpsychol
                                          Antec Earthwatts EA-380 smd element type/value
                                          by sirpsychol
                                          While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                                          09-03-2023, 07:58 PM
                                        • ajdrenter
                                          Picking caps for Antec SU-380
                                          by ajdrenter
                                          In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                          https://www.badcaps.net/forum/showthread.php?t=14159
                                          It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                          05-13-2023, 10:40 AM
                                        • CWEastwood
                                          Antec Smart Power SL300S capacitor replacement.
                                          by CWEastwood
                                          I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                                          The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                                          I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                                          Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                                          03-25-2023, 12:18 PM
                                        • s_henya
                                          Antec VP-600P and NE550M dead
                                          by s_henya
                                          Got in these 2 nice PSUs, both died after power surge.
                                          Both seems to be suffering from the same fault.
                                          Blown main fuse
                                          Shorted N mosfet 550v
                                          VP-600P: 5R280CE short between GDS
                                          NE550M: MDF18N50 short between GDS
                                          In terns of board layout these seems pretty identical.
                                          From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                                          I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                                          Is it worth to try and replace the mosfets? is there a chance that the...
                                          12-03-2024, 10:00 PM
