Sony KDL-55EX620 10 blinks
  • neilc6
    • Nov 2015
    • 1550
    This TV originally had no standby light but there was standby voltage (12V and 3.3V) and all regulated voltages on the main board were present. There is both a service manual and service/training manual (with service menu configuration) available online. Service manual flowchart indicated if there is both standby voltage and AC_DET, the main board is suspect.
    I got a new main board and the front LEDs are lighting up. Shopjimmy and the training manual indicate to update the firmware. With the tv turned on this time, the green and amber leds would flash. I got the firmware to load by extracting the firmware placing the subdirectory above the main file onto the root of a FAT32 flash drive and plugging it into the outermost USB slot with the green and amber flashing. After several minutes, the leds flashed red and amber and I let it finish.
    Now when the TV turns on, it goes green, the picture flashes briefly and I get a 10 blink error code. I tried the service menu sequence (display,5,vol+,power) with the same result.
    Similar scenario with this long post. https://www.badcaps.net/forum/showthread.php?t=75413
  • nomoresonys
    • 12322
    • U.S.
    Re: Sony KDL-55EX620 10 blinks
    Check F6001-3 and F4601 on both mainboards, just to make sure they are good and nothing blew any of them.
    • nomoresonys
      • 12322
      • U.S.
      Did the tv restart during the update process?
      • neilc6
        • Nov 2015
        • 1550
        I checked all the fuses on the old board plus all the regulated output voltages.
        After the firmware update, the red led blinked and it didnt restart. Can try to update again but not sure if it will.
        • nomoresonys
          • 12322
          • U.S.
          https://www.sony.com/electronics/sup...loads/W0010145
          • neilc6
            • Nov 2015
            • 1550
            Yes that's the firmware version I used. If I plug the USB in again with the TV in standby, the led on the USB stays lit up for a few minutes before going out and doesn't appear to reinstall. Front LED stays solid red the whole time.
            This thread same issue even after replacing main board again. https://www.badcaps.net/forum/showthread.php?t=62279
            • Diah
              • Feb 2013
              • 6613
              i don't know from where people bring this description watchdog timer... !
              could you upload clear photo on the original main boards and the replacement one from both side..?
              • nomoresonys
                • 12322
                • U.S.
                Could be a panel issue or lvds or ribbon cable, wonder if the "cut Tape" might get a display??
                • nomoresonys
                  • 12322
                  • U.S.
                  Being a kdl it should have pullups, do you get the backlight on when main and powerboard are not connected?
                  • neilc6
                    • Nov 2015
                    • 1550
                    Tried ribbon cables one at a side. No change. Removed main cable and no backlight but I did have the backlights stay on for awhile while attempting to upgrade the firmware the first time. The flash does seem to indicate a backlight problem though there is a separate blink code for that.
                    I suspect the main boards need to matched to the model number/panel since this board is used on multiple models. I captured a flash of the service menu screen and the panel associated with the main board was LTY46HJ0501 (46" panel).
                    Or possibly it is past some error count and needs to be reset. Tried a few combinations found online including up arrow on remote and power on the back buttons.
                    • neilc6
                      • Nov 2015
                      • 1550
                      Pics of the mainboards. Original on the cardboard. Replacement in the tv. Snapshot of flash of service menu.
                      • Diah
                        • Feb 2013
                        • 6613
                        disconnect the panel total from T-CON then turn on... report if the set stay on
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4540
                          • Italy - Milan
                          It is passed several months from a other user's thread, i don't remember if that blink indicates bad backlight especially bad leds or is 6 blinks.
                          • neilc6
                            • Nov 2015
                            • 1550
                            Both ribbons disconnected, same result.
                            • Diah
                              • Feb 2013
                              • 6613
                              could you write here the ic 8 pin at he left side of HDMI 3 down on PC VGA socket
                              • nomoresonys
                                • 12322
                                • U.S.
                                Backlights are suspect since they didn't come on with cable off.
                                • Diah
                                  • Feb 2013
                                  • 6613
                                  this is Sony not Samsung
                                  • nomoresonys
                                    • 12322
                                    • U.S.
                                    My old kdl4100 had pullups, so I would be surprised if this one did not have them.
                                    • neilc6
                                      • Nov 2015
                                      • 1550
                                      S24cs0?
                                      • nomoresonys
                                        • 12322
                                        • U.S.
                                        And yes, samsung is not the only tv with pullups.
                                        • jason123
                                          Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                                          by jason123
                                          Hi there,
                                          I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                                          So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                                          I see 2 posts that are relevant:
                                          https://www.badcaps.net/forum/troubl...j-oled-5-blink
                                          https://www.badcaps.net/forum/troubl...g-hardware-dev...
                                          10-29-2025, 02:01 PM
                                        • shahnld
                                          Sony kdl 65xg9505 green amber blinking
                                          by shahnld
                                          Good Day.
                                          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                          01-03-2024, 03:05 PM
                                        • matwan
                                          Sony XR-55X90J 5 blinks
                                          by matwan
                                          I have problem with SONY 55X90J. After several check status is as below;
                                          1. Running power board as stand alone:
                                          TCON_12V =~ 12.6V
                                          EVDD V On Max 24V= 19V.
                                          2.
                                          Running power board with TCON as stand alone:
                                          Effect as below, attched.
                                          3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                          "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                          Best regards....
                                          09-28-2025, 04:26 AM
                                        • GoodCapDude
                                          Sony XBR-75X940E intermittent 6 blinks error code
                                          by GoodCapDude
                                          Hi everyone. First post on Badcaps!
                                          I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                          09-20-2025, 06:07 AM
                                        • Nicktronic
                                          Sony XBR-65X850D 2 Red Blinks
                                          by Nicktronic
                                          I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
                                          Any Sony experts out there that can help??...
                                          11-19-2023, 06:51 AM
