Sony KDL-55EX620 10 blinks
  • Diah
    • Feb 2013
    • 6437
    Re: Sony KDL-55EX620 10 blinks
    Originally posted by neilc6
    S24cs0?
    okay we get it... please wait and don't do any things until i write back for you again..
    • neilc6
      • Nov 2015
      • 1550
      Two sets of 4 wires going to the edge lit backlights from the middle board. With my LED tester figured out the wiring and measured 191V on each of the 4 pairs and they lit up as well.
      • Diah
        • Feb 2013
        • 6437
        give me please the exact link you downloaded before the update you run on the set--
        • nomoresonys
          • 12276
          • U.S.
          So your sticker numbers match on both mainboards?
          • Diah
            • Feb 2013
            • 6437
            please don't disturbed conversation we want to to solve this 10 blinking error..
            S24cs0?
            resolder the 2EPROM from your old ( original ) board to the replacement one
            • neilc6
              • Nov 2015
              • 1550
              Both boards are A184571B.
              I have a CH341A programmer with clips but there is no profile for IC2500 S-24CS02AFJ-TB-G listed in the service manual. Tried something close but couldn't read anything off the old board.
              The schematic shows this chip interfacing only to the VGA connector. Little hesitant on swapping this IC since I may want to return the replacement board.
              • nomoresonys
                • 12276
                • U.S.
                #27
                Good call, I think diah's on the wrong path yet again. If the boards are a match there's no need to change out IC.
                  It is for the EDID info so the source can tell what the capability of the TV is.
                  https://www.extron.com/article/uedid
                  • neilc6
                    • Nov 2015
                    • 1550
                    I strongly suspect you need to match the model/panel type since this board is used in multiple models. The supplier I bought this from (they had 5 in stock) just groups them together since they have the same part number. It's a crap shoot if you get a compatible one.
                    From the service/training manual, 6 blinks is backlight error and there are 24 different panel options in the service menu. For my model, there are still two different panels.
                    On another note - Netflix is no longer supported on this model from Dec 1 2019 adding to the list of removed apps which includes both YouTube and Amazon Prime.
                      https://www.badcaps.net/forum/attach...8&d=1577566778
                      So what P/N number did you go by, the P/N PCB assembly as printed on the sticker?
                      • neilc6
                        • Nov 2015
                        • 1550
                        Part number on sticker is A184571B.
                        Didn't order from shopjimmy but they only show one main board part number.
                        https://www.shopjimmy.com/sony-a-181...e-required.htm
                        What worked for me upgrading the firmware was turning on the TV, confirm green and amber flash, and then plugging in the USB drive. Flashed red and amber when complete after a couple of minutes but then the red led blinked instead of restarting.
                        • nomoresonys
                          • 12276
                          • U.S.
                          #32
                          Your panel number matches one of the two in your sj link?
                            I still cannot find error code for 10-blink in the service manual or the training manual for this chassis.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4462
                              • Italy - Milan
                              #34
                              Sony led TVs goes in protection with leds problems...
                              • neilc6
                                • Nov 2015
                                • 1550
                                Panel is LTY550HJ0301. The shopjimmy link has 46" panels.
                                Yeah, the service manual only goes up to 8 blinks.
                                • Diah
                                  • Feb 2013
                                  • 6437
                                  exact this chip 24CS0 are used as EEPROM on many samsung tvs. and it was responsible for fault blinking no turn on. standby ok. also the diagram close as pin 1-4 goes to GND as address 0
                                  i used method of resetting it by make bridge wire on pin 5 & 6. plug the tv on count 1 2 plug out - remove the bridge from standby go direct to service menu.
                                  for this we don't use the knob switch on/off on the TV. just use RC
                                  • nomoresonys
                                    • 12276
                                    • U.S.
                                    #37
                                    Seems that you need to reconfigure thru service menu, did you try display,5,volume down,power?
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4462
                                      • Italy - Milan
                                      #38
                                      I don't know where Diah wants to go, how can a VGA edid eprom to block the picture from appearing and end in protection? Don't seems logical, the screen config can't be bad as you have seen a picture for short. With the help of connector's markings or srv man. force the backlight on so we see if i' m wrong. And members please use commas, the reading is too difficult whithout...
                                      • neilc6
                                        • Nov 2015
                                        • 1550
                                        The tv won't stay on to enter the service menu. Will flash for a second and blink error code with on button or service mode sequence. Get the same error code even with the backlights disconnected. Before the firmware upgrade, I was able to have the backlights stay on for 10 to 15 seconds after the startup Sony logo but it never completed booting. After the update, it shuts down right away.
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4462
                                          • Italy - Milan
                                          #40
                                          Why don't you do the test that i've said?
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • matwan
                                            Sony XR-55X90J 5 blinks
                                            by matwan
                                            I have problem with SONY 55X90J. After several check status is as below;
                                            1. Running power board as stand alone:
                                            TCON_12V =~ 12.6V
                                            EVDD V On Max 24V= 19V.
                                            2.
                                            Running power board with TCON as stand alone:
                                            Effect as below, attched.
                                            3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                            "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                            Best regards....
                                            09-28-2025, 04:26 AM
                                          • GoodCapDude
                                            Sony XBR-75X940E intermittent 6 blinks error code
                                            by GoodCapDude
                                            Hi everyone. First post on Badcaps!
                                            I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                            09-20-2025, 06:07 AM
                                          • Nicktronic
                                            Sony XBR-65X850D 2 Red Blinks
                                            by Nicktronic
                                            I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
                                            Any Sony experts out there that can help??...
                                            11-19-2023, 06:51 AM
                                          • x_orange90_x
                                            Sony KD-60X690E 6 Blinks, no image
                                            by x_orange90_x
                                            I just got this today and it has the infamous 6 blink code. I've read it's quite possibly bad backlights, and I intend to check them soon. However, I was just curious if the Sony logo should it's shouldn't be appearing briefly between powering on and the light starts flashing. I've read at least one other person had the logo flash quickly, but mine does not show anything at all, not even a flicker. The green light comes on and after about 5 seconds the red light flashes. So I'd expect in this 5 seconds to see the logo. This leads me to believe it could be a power supply issue.
                                            I...
                                            12-10-2024, 09:10 PM
