Dell g3 15 cal53 la-f611p rev:1.0
  • zurvanielle
    • Feb 2017
    • 137
    • Philippines
    HalOoh guys.... good day.... need help.. anyone who got a bios bin file for
    DELL G3 15 CAL53 LA-F611P REV:1.0
    thnks in advance
  • Marc97
    • Jan 2016
    • 189
    • Phillipines
    Re: Dell g3 15 cal53 la-f611p rev:1.0
    thnks in advance
    i also nid file for this canu help us
      • 21899
      Post your bios backup .
      • Marc97
        • Jan 2016
        • 189
        • Phillipines
        here is my copy back up invalid file
        • Marc97
          • Jan 2016
          • 189
          • Phillipines
          upload error me
            • 21899
            Post the file in a zip or rar .
              • 21899
              Try this bios .
                • 21899
                G3 15 ME clean
                • Francisco.s
                  • 686
                  • Spain
                  G3 15 ME clean
                  Does not works with this cleaned bios either.
                  It reboots a few times at first, but it's the same as before.
                  Time to moving on to other delayed works.
                  Thanks for all your efforts.
                  • roberthcor
                    • Apr 2019
                    • 8
                    • peru
                    Try this bios .
                    gracias
                    • Etx
                      • Jan 2019
                      • 1
                      • Egypt
                      Try this bios .
                      Can you please tell me where the EC dump is stored on this MB? Looks like my problem is due to EC incorrect FW.
                      • murlee
                        • Nov 2020
                        • 4
                        • china
                        really appricated.
                        • murlee
                          • Nov 2020
                          • 4
                          • china
                          my backup via a direct read from dell g3 3579 winbond 25Q128
                          • alilaptops
                            • Apr 2019
                            • 17
                            • Pakistan
                            pleas clear my bios password file working 100%
                            • AAAC
                              • Jan 2020
                              • 458
                              • Mexico
                              @alilaptops
                              Why you don't try to unlock it by code? I believe this model uses the BF97 suffix, I just checked the bios and that's what I found. BF97 generator has been already released.
                              • alilaptops
                                • Apr 2019
                                • 17
                                • Pakistan
                                bios have no display clear me
                                • lapfix
                                  • Mar 2020
                                  • 2764
                                  • my workshop
                                  Try and give feedback
                                  • digidoid
                                    • Jul 2018
                                    • 6
                                    • Moldova
                                    works - ok - thx
                                    • mferna14
                                      • Jun 2018
                                      • 1046
                                      Hi all, can anyone clean this Original BIOS of Dell G3 15 LA-F611 (Motherboard) Laptop. With the original BIOS the Fans are running 100% & NO DISPLAY, I tried the above BIOS Bin files & the status changed, it went through its self test mode, turning On & Off 2 times & then steady but still no display. If someone can help & kindly update these Bin files for me, I would appreciate. Thanks in advance.
                                      • hardware1
                                        • Sep 2021
                                        • 2948
                                        • N/A
                                        Here's your New bios file, try it and give me the results.
                                        Service Tag: BNZ9YQ2.
                                        all donations are welcome,
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Akhlz001
                                          Dell Pro 13 Plus PB13250 Bios Unlock
                                          by Akhlz001
                                          Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                                          09-20-2025, 07:15 PM
                                        • master3112
                                          Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
                                          by master3112
                                          I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
                                          Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
                                          The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
                                          07-29-2025, 01:55 PM
                                          Dell Thunderbolt Firmware
                                          by SMDFlea
                                          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                                          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                                          The SKU is in brackets (****)
                                          EDIT: NVM65...
                                          01-26-2025, 06:22 AM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
