help please!!!!
					Dell g3 15 cal53 la-f611p rev:1.0
 tryAttached FilesComment
 In the extracted bios update folder are 2 different EC (PHCM) versions. You can find some plain text to ID which EC firmware is which. The text is 086F and 0870 .Your original bios backup has 0870. The bios update has 086F ,so when trying to fix your bios by copying the bios update over yours you end up with the wrong EC firmware and that explains the issues you`re having.
 Attached are 2 different bios versions, both with bios update v1.25.0, the different EC versions, clean ME firmware and no service tag or windows key.Comment
 my g3 works 086f csme, but still has slow keyboard and can't charge battery. after i entered and saved service tag successfully and re-entered win. i tried downloading bios from home page to update system again. and surprisingly, all the trouble was gone. everything is back to normal. hope that with this method can help someone can fix the problem like me. thanks everyone.
			by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
			by Akhlz001Hi,
 Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
							Channel: BIOS Requests ONLY!
			by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
 The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
			by SMDFleaDell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
 Some models have a choice of 2 different firmwares, it depends on the dell SKU.
 The SKU is in brackets (****)
 EDIT: NVM65...-
			by F R 2568Hello all,
 this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
 I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
 If the laptop is only connected to the AC adapter (battery removed):
 When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
 The power/battery...
- Loading...
