Touchpad adhesive
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Touchpad adhesive
    Dear forum members,
    I am replacing the touchpad of Dell Inspiron 5520. I removed the old touchpad. It was glued to the palm rest. Now I should glue the new touchpad by some adhesive to the palmrest. but I do not know what kind of adhesive to use.
    Once I used some wood adhesive. but the touchpad did not work when it was touched. It seems the adhesive blocked the sensing properties of the touchpad. So I removed the wood adhesive.
    By inspecting the smell of the adhesive, I discovered that the adhesive of the old touchpad is not an ordinary adhesive such as super glue, or PVC glue, or plastic glue which we can find in the market.
    what kind of adhesive is appropriate for this purpose?
    thanks
    here is a photo of the touchpad and where it should be glued to.
  • Maciej.Klm
    • Oct 2018
    • 7
    Re: Touchpad adhesive
    Try 3M adhesive double sided tape like this one https://www.ebay.co.uk/itm/3M-300LSE....c101006.m3226
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      b7000 is what i have been using on tablet and phone screens maybe this would work?
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        but this is not a touch screen. have you tested it on laptop touchpads?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          no but i would of thought if it works on a touch screen i would work on a touch pad?
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            thanks for all the replies,
            I am not a phone repairman. Thus, I am not familiar with touch screen adhesives. It may work on touchpads too.
            is the touch screen adhesive placed between screen and touch-panel or above the touch-panel? If it is placed between screen and touch-panel, it does not cover the touch-panel. that is why the adhesive cannot reduce the sensitivity of the touch-panel.
            In laptops, the adhesive has to be placed between touchpad and palmrest (or our fingers). that is why the adhesive may reduce the sensitivity of the touchpad.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              i have just reread post one, yes your rite b7000 glue probably wont work then as yes usually used just around the edges of digitizers etc,not sure what too suggest though too use.
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                thanks anyway.
                gluing a laptop touchpad is very rare among laptop repairshops. usually only factories do it. that is why very few people know about the adhesive.
                the touchpad adhesive is visible on the surface of the touchpad in the second photo in Post#1.
                the touchpad adhesive is similar to a colorless super glue that we use for gluing papers or plastic at home. but it has a different smell. It smells similar to some plant extract.
                • piernov
                  • Jan 2016
                  • 4436
                  • France
                  I've only had to replace a glued touchpad once due to heavy liquid damage. I didn't glue the new one in as it was held in properly with only the guides on the side and clip.
                  I think B7000 would work but I'm not sure.
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3599
                    • slovakia
                    just use some 3M adhesive tape
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      I replaced them a couple of times and usually no adhesive is needed-The adhesive on the surface of touchpad does the job.(Did you cleaned the touchpad after removal??)
                      • petehall347
                        • Jan 2015
                        • 4427
                        • United Kingdom
                        wondering if spray mount will work .
                        • caspian
                          • Oct 2015
                          • 1591
                          • Laptop
                          the old adhesive was not powerful to hold the new touchpad. so I had to remove it.
                          I discovered that if a bit of wood adhesive be on the surface of a touchpad, then the touchpad gets confused in sensitivity and the mouse cursor stops moving, it does not matter the wood adhesive is wet or dried.
                          So I had to forget any kind of adhesive and use a heuristic mechanical method to hold the touchpad in place. I put plastic peaces between the touchpad and the mainboard so that the touchpad is pushed up. I drew a picture of this method for everyone to learn.
                          I wonder if someone discovers the best adhesive which factories use for gluing touchpad to palmrest. touchpad has a very sensitive surface so that its sensing capability is blocked if we use a wrong adhesive.
                          • gabiz_ro
                            • Mar 2011
                            • 167
                            • Romania
                            LOCA ( liquid optical clear adhesive ) was used for replacing glass only on phone displays
                            But need UV for curing. I don't know if UV can penetrate plastic of palm rest.
                            Also OCA tapes or sheets (similar thing but not liquid) but I doubt you can obtain free bubble area and that will affect touch in some zones.
                            Since both are used in glass replacement and touchscreen still works after,maybe is OK for touchpad too.
                            • charasoverride
                              • Mar 2021
                              • 1
                              • South Africa
                              I was also looking for this answer, but in the end I was able to use the glue left on removal, I could stick it back by applying heat and softening the glue. But based on the image of a Dell trackpad replacement, it comes with a 3M adhesive, so if you already removed the glue, you should remove all rest of glue and apply this type of adhesive.
                              • hairulole
                                • Jan 2024
                                • 6
                                • Malaysia
                                I think OCA glue film sheet can be use too. It has been use to stick digitizer and lcd screen (phone)
                                • acedogblast
                                  by acedogblast
                                  11-02-2024, 05:13 PM
                                • B2L_Repairs
                                  Macbook A1706 touchpad and keyboard not working. Please help
                                  by B2L_Repairs
                                  Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                                  10-09-2023, 04:56 AM
                                • Katz993
                                  iMac Display Replacement Adhesive
                                  by Katz993
                                  TL;DR: Looking for as-close-to-genuine as possible iMac Thin Panel (2012-2019) Adhesive.
                                  Long Rant: I run a tech shop that has a specialty in Macs. We've been doing upgrades and repairs on the thin panel iMacs as long as they've been out, and I've always had the issue of being unable to get something close to the OEM Adhesive for the Display Assembly, i.e. a 'two-part' adhesive, extremely thin but durable and can be cut easily with a thin wheel cutter. My replacement adhesive has always been essentially standard thin adhesive. For a long time, the biggest annoyance with this was having...
                                  03-15-2022, 10:31 AM
                                • claws77
                                  lenovo flex5-14itl05, touchpad water damage
                                  by claws77
                                  last night i dropped some liquid over my laptop touchpad, immediately stopped using and tried to dry it up.
                                  the touchpad misclicks, sometimes stops working altogether
                                  i have removed the touchpad assembly cleaned it with alcohol and brush and cotton buds.
                                  can i fully disassemble the touchpad assembly as i suspect some liquid is still lurking inside the trackpad.​...
                                  07-15-2024, 07:34 PM
                                • MichelinMan
                                  CF-20 Toughbook (mk1) Trackpad/Touchpad and USB ports not working
                                  by MichelinMan
                                  Hey guys,
                                  Just purchased a CF-20 (mk1) supposedly was all working. However, the seller had done a fresh install of windows 10 but did not install any driver. Seller was adamant the trackpad/touchpad was working.
                                  The touchpad/trackpad does not work. No led lights near the trackpad. The keyboard works, the USB 2 port on the base does not work, The USB 3 ports will recognise a USB 3 flashdrive but did not recognise a USB mouse. The ethernet port on the keyboard section works.
                                  The USB 3 port on the actual tablet section works with no issues.
                                  07-18-2023, 08:12 AM
