iMac Display Replacement Adhesive
  • Katz993
    • May 2020
    • 5
    TL;DR: Looking for as-close-to-genuine as possible iMac Thin Panel (2012-2019) Adhesive.
    Long Rant: I run a tech shop that has a specialty in Macs. We've been doing upgrades and repairs on the thin panel iMacs as long as they've been out, and I've always had the issue of being unable to get something close to the OEM Adhesive for the Display Assembly, i.e. a 'two-part' adhesive, extremely thin but durable and can be cut easily with a thin wheel cutter. My replacement adhesive has always been essentially standard thin adhesive. For a long time, the biggest annoyance with this was having to re-open the iMac, the replacement adhesive was gummy and didn't come off as cleanly as apple's. This was bearable. Since 2020, they seem to have dropped massively in quality just about everywhere I can supply them. Some of our more serious customers, production studios and music producers, are even having issues where the screens just fall off after being on particularly hard working, frequently high-heat iMacs.
    My shop and I have tried looking around everywhere, ordered from different vendors, even gotten desperate and tried ordering batches from eBay to see if anything would be better. We've called the companies to complain and it's the typical BS that we must be doing something wrong. We've tried heating up the adhesive and letting it seat with extended clamping pressure but we continue to have issues. I would just like something closer to the OEM strips. Durable, reliable, and preferably easy to cut in warranty events or second upgrades/repairs. I don't care if we have to cut it ourselves. Anyone else have experience, or can even point me in a direction of somewhere?
    Any help would be appreciated, thank you!
  • mon2
    • 14634
    Re: iMac Display Replacement Adhesive
    We have done some iMAC repairs and use the strips sold on Aliexpress. So far, have not had this fault of the screen falling off.
    However, consider to review the 3M brand from authorized sources or even give them a call to discuss with one of their engineers for the best solution. We did this ages ago for sourcing and selecting 3M branded filament tape for packaging and another project. The solutions are being used to this day.
    https://www.mobilesentrix.com/catalo...mNzvU3q&q=tape
    • ryogadan78
      iMac A1418 - No LED, no power after overvoltage on Ethernet port
      by ryogadan78
      Hi guys, I need your help again.
      I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
      When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
      06-10-2025, 03:49 AM
    • Stephen
      iMac M1 DFU restore issue
      by Stephen
      iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
      this is the message it gives me with the error
      Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
      Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
      03-07-2025, 12:19 PM
    • Stephen
      iMac 27” 2020 Boot issue
      by Stephen
      Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
      08-16-2024, 09:32 AM
    • the_rem
      Unknown transformer : how to find a good replacement part ?
      by the_rem
      Hello guys,
      I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
      I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
      04-23-2025, 01:48 AM
    • ezenia
      PS4 controller left stick potentiometer replacement issue
      by ezenia
      Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
      So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
      I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
      09-30-2023, 02:19 PM
