LVDS Cable Removal
  • RDC55
    • Dec 2017
    • 180
    LVDS Cable Removal
    Looking for some help to remove the LVDS cable. Could someone please explain how this cable is removed? Thanks, Rich
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: LVDS Cable Removal
    if it wont pull out look at the clip looking bit .. sort of u shaped
    • RDC55
      • Dec 2017
      • 180
      That sort of u shaped (white part) is sort of floppy loose. Does it pry up allowing the cable to be removed? Just don't want to break anything.
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        cant blame you ..not seen one like that ..or does cable simply pull out ?
        latched ones i have seen the latch is straight across .
        please wait for someone else to comment .
        • ducky29
          • Dec 2015
          • 370
          • Europe
          Slightly push the white part towards yourself and then you should be able to remove the cable.
          • RDC55
            • Dec 2017
            • 180
            It doesn't really seem to move in that direction.
            I did manage to get the cable out by pushing down on the white part, but it still seemed to take a bit more tugging than i would have liked. It might be a case where you need a 3rd hand or shaped tool to push down on the white area while gently pulling on the LVDS cable. Not sure this was proper but it did seem to work. Always amazed at what engineers can manage to design.
            And thanks for the replies.
              What is the make and model number of this TV?
              • RDC55
                • Dec 2017
                • 180
                It is a Sharp Aquos LC-60LE640U.
                • R_J
                  • Jun 2012
                  • 9548
                  Here is a picture from shopjimmy, you can see which parts stay with the connector, pushing down on the white part likely releases the cable
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Ah yes, I too was slightly embarrased when I was faced with one of those connectors at my new job at a service center which mostly fixes Sony, that was until my co-worker taught me: you push DOWN ("into" the board) onto the white U-shaped bit and pull the connector. Yes, it seems to take a bit more force than it ought to, but that's normal, as the cable seems to have some sort of reinforcing plastic foil on the end which keeps it rigid. Likewise, when you plug it back in, it clicks slightly to let you know you did it right and you don't need to do anything else. Cheers.
                    Wattevah...
                    • NolesFan
                      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                      by NolesFan
                      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                      10-24-2024, 06:36 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • ResoluteHawk
                      Connecting an LVDS/eDP cable into a live motherboard
                      by ResoluteHawk
                      Could anyone explain the reasoning behind why connecting an LVDS or eDP cable into a laptop motherboard, with the battery still connected, kills the CPU/PCH/SuperIO/GPU?
                      Today I had a customer with a Lenovo Legion 5 that I diagnosed as a dead iGPU inside their Ryzen 5900HX. They told me that they connected their screen to the motherboard without first disconnecting the battery.
                      I want to understand the nitty gritty behind why it kills components if power is not disconnected first.
                      08-04-2025, 04:39 PM
                    • alfredomfr1
                      HP M32f FDH Monitor: 12v missing after connect the LVDS ribbon cable to the LCD circuit
                      by alfredomfr1
                      12v pin is shorted to ground in the LCD board (1st picture) if the LVDS cable is disconnected, 12v are OK in the Main Board (2nd Picture)
                      06-04-2025, 10:23 AM
                    • mon2
                      A1466 Macbook Air (Liquid damage repair)
                      by mon2
                      Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                      Macbook AIR Model A1466 Diagnostic 09-01-2021
                      Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                      Problems & Resolutions
                      1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                      09-01-2021, 09:31 AM
