LG 65UH5500 Momentary Flash Of BackLights
  • Michale32086
    • Nov 2011
    • 1453
    This is the 3rd TV today that has this issue..
    Momentary flash of the backlights.. Display is fine, just not backlit..
    My first instinct is that it's a bad backlight strip... But that hasn't worked out for me so well recently, so I decided to do some more checking before I break....er... break open another display panel..
    Glad I did..
    With my LED Tester, I was able to determine that the LEDs are good... I did some measurements on the Power PCB and the middle Inverter Board...
    Let me see if I can map this out coherently..
    On the Power PCB, the top 4 pins show 90V and the fifth one is marked NC... When the Power PCB is plugged into the Inverter Board, I get 55V on all 5 pins.. The 4 marked 90V and the 5th pin marked NC...
    When I check the pins WITHOUT the Inverter Board plugged in, I get the 90V on the 4 pins marked 90V and 0V on the 5th NC pin..
    I should note that the Inverter Board connector is marked 80V on the first 5 pins and shows 55V when the TV is powered up..
    Does all of this indicate a bad or shorted Inverter board??
  • Michale32086
    • Nov 2011
    • 1453
    Re: LG 65UH5500 Momentary Flash Of BackLights
    I should also note that on the Power PCB, pin 1 (STB) has 3.5V and pins 2, 3, 4 that SHOULD be 13.2V is 7.5V.....
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      First of all, If this TV is a LED TV that is an LCD TV with LED backlights then that thing you are calling an INVERTER is really called a LED DRIVER. Inverters were found in the older LCD TVs that had CCFLs as backlights.
      So if you disconnect the connector from the PSU to the Main Bd. does the backlights come ON and stay on?
      • Michale32086
        • Nov 2011
        • 1453
        DOH!! Yea, my bust... It definitely is an LED...
        The Main Board is not directly connected to the PSU... The LED Driver board is in between... But when I disconnect the Main Board from the Driver board, I get nothing. No flash, no nuttin..
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          OK. so disconnect the connector from the Driver to Main Bd. and see if backlights come on.
            OK, so I am a little confused.
            Have everything connected
            1) When TV is OFF, What Voltage do you have on 80V pins of the power supply board.
            2) When TV is turned on what do you have on 80V pins?
            3) When TV is turned on, what do you have on PS-ON pin on the power supply board?
            4) When TV is turned on, what do you have on DRV_ON on the LED power supply board?
            5) What Vf readings do you get on all six LED strings?
            • Michale32086
              • Nov 2011
              • 1453
              Nothin...
              • Michale32086
                • Nov 2011
                • 1453
                Funny thing.. I can't turn the TV off... Either by remote or by holding the power button.. The TV goes off then comes back on...
                The 80V pins (on the DRIVER board) are at 55V...
                On the Power PCB, it's marked STB (marked PS-ON on the DRIVER board) which is 3.3v
                The only DRV-ON is on the DRIVER board and it's at .9V
                .6v
                  .6v
                  That must be an error with Vf reading of the LED string, they cannot be 0.6V if each of the LED string lighted up using the LED tester/ What kind of LED tester is it?
                  BTW, if you cannot turn the TV off, then at least you do have main board problem, plus DRV_ON signal also looks too low to turn on LED power supply.
                  • Michale32086
                    • Nov 2011
                    • 1453
                    See attached pic
                    Yea, it's beginning to look like a Main Board issue??
                    • fcisolutions
                      • Jan 2017
                      • 205
                      Do you think it is the mainboard or the driver board. I am getting the same issue. Can you get any sound .
                        See attached pic
                        Then the Vf of the LED string cannot be showing 0.6V and light up.
                        That built-in Volt meter will show what the Vf of the LED/LED string are.
                        I.E. if the LED string has 10 3V LED then the Vf showing on the meter should be 30V, but since that LED puts out about 30mA, then the Vf will be a little leas than 30V.
                          BTW, since you do have PS-ON, what DC Voltage do you have between the two legs of the main filter caps?
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            Classic symptom of an O/C led in the panel. I did a 47" LG today exactly the same issue.
                            It only takes 1 to be dead to cause 1 sec to black on these LG's....
                            TELEFIX
                            • nomoresonys
                              • 12330
                              • U.S.
                              Hmm, try unhook leds, then see if tv turns on and off with power button.
                              • nomoresonys
                                • 12330
                                • U.S.
                                You say all leds lit up with proper voltage with your tester or you couldn't tell if they did?
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  I think I would be looking to see why there's only 7.5V and not 13.2V before doing anything else.
                                    The 7.5vDC for the 13V STBY may be normal in standby mode, since there is no separated standby power supply so they may keep the Voltage low just enough to run the main board, and when PS-ON is present and then the PFC Booster circuit kicks in then the 13V and the 80 will be normal.
                                    That is why I ask OP to see what DC V he has on the main filter cap since the PS-ON is present.
                                    • nomoresonys
                                      • 12330
                                      • U.S.
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        Thanx to all the replies.. I had grandpa duty that took me away from the shop early..
                                        I'll try all the suggestions when I get to the shop first thing in the AM...
                                        • ekozeko333
                                          [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                          by ekozeko333
                                          I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                          🔥 The Problem Started After Suspected ESD/PD Fault
                                          I experienced a power issue or ESD event through a USB-C charger
                                          After that, the NX20P5090 power switch was visibly burned and was replaced
                                          Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                          🧠 What I’ve Done So Far
                                          Flashed...
                                          06-21-2025, 02:48 AM
                                        • corrize
                                          Nikon D800 camera - flash don’t work and capacitor don’t charge
                                          by corrize
                                          Hello, I'm stuck in troubleshooting…
                                          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                          10-01-2022, 10:02 AM
                                        • philtvman
                                          LG 65UH5500 Momentary Flash Of BackLights (Occasionally)
                                          by philtvman
                                          Had the issue where the screen flashes for a second when plugged in, but turns off instantly. It won't do it again until the power is dispersed from the boards (unplugging and holding power button down). Figured it was likely just a bad LED somewhere based on the symptoms and other threads I found here. When watching it flash, it was clear there were a couple strips not coming on at all.
                                          I cracked it open to check the LEDs and every one of them turned on with the tester (which was pretty annoying to be honest). I plugged the set in with the dispersion panels off to see exactly which...
                                          03-05-2019, 09:34 PM
                                        • JunkmanJimbo
                                          RCA led50b45rq tv backlights flash then shuts down
                                          by JunkmanJimbo
                                          First of all I looked at the other posts on this model but didn't really see a solution. This is where I am so far. I have replaced the power supply and the mainboard (both used). I'm still having the same problem. The tv standby light comes on, I push the power button, the backlights flash and the tv shuts down. The tv can't be turned off unless I unplug and reconnect the power cord. I have tested the backlight strips with an LED tester and all of them are working fine. I can unplug the led connector from the power supply and the tv turns off and on like it should. Also with it unplugged, and...
                                          05-23-2022, 04:07 PM
                                        • spmetroil
                                          Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                                          by spmetroil
                                          I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                                          The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                                          I have a CH341A programmer and I already attempted the following steps:
                                          1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                                          2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                                          3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                                          08-19-2025, 09:23 AM
