HP Omen 15-ax201ns bios dump
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    I need bios dump for this mobo: dag35dmbad0 rev: d
    I attached backuped bios file.
    Thanks.
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: HP Omen 15-ax201ns bios dump
    I check your bios and bid, so this is your bios coming from a paid forum but i want to share here your BID 08217
    • DeniS182
      • Jun 2014
      • 328
      • Slovakia
      Thank you very much for bios files. Where is EC bios located on board? I thought only one main bios chip is there ,but u send me also EC bios. Have someone schematic?
      • String2016
        • Nov 2015
        • 2238
        • philippines
        128kb is for ITE chip try flashing the main bios first
        • DeniS182
          • Jun 2014
          • 328
          • Slovakia
          I flashed main bios, but notebook is totaly dead as before . No lights, nothing. I don't have any voltages , only 19V rail..
          What are these ic's?
          7J-3L
          Z22610
          MT608
          95829 hrtz
          4e=3k
          • String2016
            • Nov 2015
            • 2238
            • philippines
            maybe your problem is not bios issue you need schematic for this maybe someone here in this forum can give you
            • DeniS182
              • Jun 2014
              • 328
              • Slovakia
              Thanks.
              and 7J is RT8816AGQW. No voltages on IC's.. only 19V is on mosfet near DC IN connector. I need schematic..Does anyone have it?
              MOD EDIT: Schematic posts moved to a new thread - https://www.badcaps.net/forum/showthread.php?t=85695
              Last edited by SMDFlea; 06-29-2020, 10:48 AM. Reason: Schematics moved to a new thread in "Schematic Requests ONLY!" sub-forum
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                here is bios for every version of HP Omen 15-ax201ns
                check you BID or try until you match bios
                those are virgin bios, not dumps from boards, so me is clean
                Im Back... sort of...
                • hamid_seta
                  • Mar 2015
                  • 22
                  Thanks.
                  Hi Mate
                  I know it is too late but for Others update, I checked the Bios file and its ok.
                  Tnx
                  • aashish chauhan
                    • Sep 2017
                    • 9
                    • india
                    BID-08217 WORKING
                    • JanoSilva94
                      • Jul 2020
                      • 1
                      • Chile
                      This List BIOS Working in Omen 15-AX250WN? the model board is dag35dmbad0 rev: d too
                      • stingerchamp
                        • Sep 2020
                        • 425
                        • Pakistan
                        Hi, my motherboard is dag35dmbad0 rev: d too can i use these bin files for HP omen 15-ax236tx ?. i do not have prev bios file. my laptop stop booting when i updates bios to F55 latest version.
                        thanks for help.
                        I am receiving 5.3 capslock blink error(5 long led blink ,3 short blinks)
                          • 21868
                          thanks for help.
                          Yes.
                          The Omen 15-ax***** has BID: 0820D, 08209 ,08217.https://www.badcaps.net/forum/showthread.php?t=72828
                          Check your BID number in your bios backup and CPU ID .
                          BID08209 SKYLAKE U
                          BID0820D SKYLAKE H
                          BID0825F SKYLAKE H
                          BID08294 SKYLAKE H
                          BID08213 KABYLAKE U
                          BID08217 KABYLAKE H
                          • stingerchamp
                            • Sep 2020
                            • 425
                            • Pakistan
                            Originally posted by SMDFlea
                            Yes.
                            The Omen 15-ax***** has BID: 0820D, 08209 ,08217 .https://www.badcaps.net/forum/showthread.php?t=72828
                            BID08209 SKYLAKE U
                            BID0820D SKYLAKE H
                            BID0825F SKYLAKE H
                            BID08294 SKYLAKE H
                            BID08213 KABYLAKE U
                            BID08217 KABYLAKE H
                            hi , can i use 0820D or 08209
                            i have intel corei7 7700HQ microprocessor kaby lake and intel HM175 chipset skylake
                            Please Help which one is for my laptop
                            Bios recovery flash has 6 files with 0820D.bin till 08217.bin
                              • 21868
                              Your cpu is a 7700HQ (H) so try the BID08217 KABYLAKE H.If you want to check the BID in your bios backup first ,open it with a hex editor and search for the word BID ,or post your bios backup here .
                              • stingerchamp
                                • Sep 2020
                                • 425
                                • Pakistan
                                THANKS FOR HELP
                                INFO: IN USB FLASH DRIVE i have two folders Hawelet-pack and one HP folder.
                                subfolders are 3 current , previous (empty), devfw(empty).
                                i have attached current folder bin files from HP folder.
                                • stingerchamp
                                  • Sep 2020
                                  • 425
                                  • Pakistan
                                  THANKS FOR HELP
                                  quick update 0209.bin missed my mistake.
                                  should i reupload??
                                    • 21868
                                    should i reupload??
                                    No, ive removed your attachment. Why post the virgin bios thats already posted here ? .Have you made a bios backup using an SPI bios programmer ? .Are you trying to recover the bios from USB ?
                                    • stingerchamp
                                      • Sep 2020
                                      • 425
                                      • Pakistan
                                      trying to recover the bios . my system is dead and i went for a repair but that guy had no idea so i came back and trying my best to recover my laptop to play games. i ahve bought flash re programmer but not sure of which bios bin
                                      • stingerchamp
                                        • Sep 2020
                                        • 425
                                        • Pakistan
                                        Thanks for your help. I will try to use these files to flash on bios chip using flash programmer. it will be last hope for my laptop mobo.
                                        I have done everything to save it but failed now only hope is flashing bios with fresh bin file .
                                        Yes i am trying to recover a bios file from USB or from this forum so i go ahead for flash programmer process.
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • JoWed
                                          Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                                          by JoWed
                                          Hello Community,
                                          I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                                          07-01-2025, 09:32 AM
                                        • mkdj
                                          ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                                          by mkdj
                                          Dear all,
                                          I have a ASUS ZenBook UX480F with the following symptoms:
                                          I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                                          I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
