help with wine cooler-something buzzing
  • buchman
    • Aug 2015
    • 294
    • greece
    Hi everyone,
    I have a wine cooler that I suspect the transformer is buzzing.
    How can I test the transformer to be sure that it's the culprit (I have tested it for resistence and it was fine, no shorts).
    Is there another test?
    photos attached.
    Thanks.
    • 31246
    Re: help with wine cooler-something buzzing
    my suspect would be the choke coil next to the heatsink.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      replace ALL lytics.
      i have a fridge with that exact board and the caps are all shot.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        caps can look A1 from the outside, but still have high ESR. I recapped a fridge board a half a year ago, because of strange behavior...
        • buchman
          • Aug 2015
          • 294
          • greece
          Originally posted by kc8adu
          replace ALL lytics.
          Did that already. I have an ESR meter.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Take out the transformers and coils, dip them in lacquer/varnish for a few hours, take them out and allow to dry for 24 hours, solder them back in. Your buzzing problem should be solved.
            A working TV? How boring!
            • buchman
              • Aug 2015
              • 294
              • greece
              Can you mark it please?
              • buchman
                • Aug 2015
                • 294
                • greece
                One more thing I have noticed that, one of the transistors (13009-2) on the heat sink is getting very hot while the other one (which is the same one) isn't getting hot at all.
                Circled in red.
                P.S. I have replaced both of them, replaced a few caps, diodes, resistors and still, the transistor is getting hot and I hear buzzing on the transformer.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8340
                  Does the fridge work? Sounds like there is a high load on that transistor. Maybe DL the datasheet of the AZ494 and probe around it? Can we see the bottom side of the board? Can you circle all the parts you have changed so far on the pic?
                  • buchman
                    • Aug 2015
                    • 294
                    • greece
                    the fridge work but the display is flickering.
                    parts that I have changed:
                    2 big caps, 5 diodes, 2 resistors, 2 transistors and a fuse.
                    • R_J
                      • Jun 2012
                      • 9606
                      It's a good chance those small caps. around the transformer or more likely the ic are bad. They can look ok but be bad.
                      were the parts you replaced bad?
                      • buchman
                        • Aug 2015
                        • 294
                        • greece
                        I have tested all the capacitors out of circuit with an esr 70+ meter, they are all fine.
                        All the parts circled in red that I mentioned before were bad.
                        • R_J
                          • Jun 2012
                          • 9606
                          I was just going by the bottom of the board and it did'nt look like the caps like C4 and the 2 between the ic and heatsink had been out
                          • buchman
                            • Aug 2015
                            • 294
                            • greece
                            Then it probably showed a good reading while in circuit.
                            • buchman
                              • Aug 2015
                              • 294
                              • greece
                              How can I test the ic AZ494AP-E1 with a DMM to be sure that it's the bad part?
                              • R_J
                                • Jun 2012
                                • 9606
                                If the power supply is working at all, the ic will be good
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8340
                                  Maybe there is nothing wrong with the psu and just something else drawing too much current from it? So if you plug in the psu into mains by itself with nothing connected, that transistor that got hot should stay cool.
                                  • ajshoe
                                    ajshoe
                                    • Dec 2012
                                    • 477
                                    • usa
                                    you may think you bought a wine cooler but on reality it is a wine chiller that slowly over time gets weaker and weaker. The dielectric media or whatever gets cold from that control board slowly dies. Buy a wine cooler (has a compressor) and you won't have to keep fixing the garbage your working on now. Those "electric chillers" are garbage
                                    • buchman
                                      • Aug 2015
                                      • 294
                                      • greece
                                      That's why I bought it in the first place. I love fixing things (at least trying to fix). even if I fail, each and every time I am trying to fix something I feel a spark in my heart and it's exciting me every time.
                                      I fixed 2 wine chillers successfully and even though I am spending lots of money on the components I am thrilled every time I touch electronics.
                                      I can't find a transformer for a descent price over the internet maybe someone can help me, I think that it's the culprit.
                                      The part number is JBC-983-EEL-19
                                      Thanks a lot guys.
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        Doubt that you will find a replacement transformer. Check my other post above.
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
                                          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 04:40 PM
                                          ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 12:00 PM
                                          ASUS Transformer T304UA-GN042T Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T304UA-GN042T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-GN042T boardview and T304UA-GN042T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 11:50 AM
