Sony KDL-50w829b
  • ronhayes
    TV Engineer
    • Mar 2014
    • 458
    Sony KDL-50w829b
    Hi All
    I know this is a long shot as from what i have seen with these sets the LCD panel are of very poor standard.
    This set comes on when powered up and when i connect a DVD player via scart i get sound but no picture just a black screen.
    I have tried two t-con boards but still no results same black screen with all three t-con boards ?
    I have tried removing each ribbon from t-con to panel which does nothing at all the screen stays the same ? I have tried this several times and at one time i did get half of a picture with one of the ribbons unplugged and it was a good picture very clear. But when i reconnected the ribbon it went back to a black screen and it does not matter how many times i have tried to remove the ribbons i just can't get it to display half of a picture again you can see the backlights are on.
    I have also connected my lcd tester to the t-con board and switched on but you need to disconnect the lead from the power board to get the backlights on with the lcd tester connected but can not get any test patterns to display.
    I am aware that these sets are prone to lcd failure.
    I have even tried flexing the screen but nothing.
    I am including some pictures and one is of two t-con boards as i had to return one to supplier as it gave me a red flashing light when connected.
    I have read in some posts that you can put tape over a certain track on the ribbons and this would give you a picture but have never done this and would not know which tracks to isolate ? If this was possible any pointers as to which tracks i would need to isolate or do you think this lcd is toast ?
    Any help would be much appreciated.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sony KDL-50w829b
    Have you shone a bright light on the screen to see if there is an image or do the backights come on when playing the DVD with no image displayed. Is there an image when you use the Panel Tester again shining a light on the screen?
    • ronhayes
      TV Engineer
      • Mar 2014
      • 458
      There is defiantly no picture as the backlights come on you actually see the screen light up but no picture not even with the lcd tester connected.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Have you checked that you have voltage at the tcon fuse?
        • ronhayes
          TV Engineer
          • Mar 2014
          • 458
          Yes 12.5v
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            https://www.youtube.com/watch?v=j7vl7-vZEL8
            • ronhayes
              TV Engineer
              • Mar 2014
              • 458
              After removing the right ribbon looking at the back of tv then powering up i get what you see in the attached photo's but when re-fitted the screen slowly goes black again , then if you remove the left ribbon and power up the screen stays black.
              • ronhayes
                TV Engineer
                • Mar 2014
                • 458
                Could any one tell me if i get picture to one half of screen but not other does this mean that the lcd panel is ok ? and the t-con board is at fault ?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  there is a pcb board bonded to the lcd panel, theirs been a few cases where a smd capacitor/etc has shorted out and caused no screen image on that side of the lcd panel
                  • ronhayes
                    TV Engineer
                    • Mar 2014
                    • 458
                    Ok so now i have removed all the fixtures to expose these boards.
                    Now what i need is a schematic to give me the values of these components for me to test them !! If any one could help with that?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      Can you upload a picture of that board ron, the few i have seen you can usually test the components on say the left of the pcb and then compare same parts on the right hand side, this may not even be your issue with your tv like you say it could be a tcon/lcd panel/tab bond fault,but it has been mentioned in a few threads. Does anything get hot on the bad side of the panel pcb?
                      • ronhayes
                        TV Engineer
                        • Mar 2014
                        • 458
                        Hi Vinceroger69
                        Here are a photo of each board hope they are clear enough to see ?
                        When you say does anything get hot do you mean by running your finger along board when ribbon is connected and tv on ?
                        • ronhayes
                          TV Engineer
                          • Mar 2014
                          • 458
                          I can't feel anything getting hot ?
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            im not sure then, maybe a more experienced member will have some more tests you can carry out maybe it is a lcd panel failure?
                            • ronhayes
                              TV Engineer
                              • Mar 2014
                              • 458
                              Yes Vince maybe you are right it may well be the lcd panel but now i have stripped it down this far would be interested in checking the components on these boards to see if any have failed? a schematic would be handy.
                              It seems all to common now with these new smart TV's lcd failure !! How can these manufacturers be allowed to get away with the crap they are now producing !
                              When flat panels were first produced they would be good for ten to fifteen years now all the manufacturers are giving is a one year warranty and you are lucky if their new products last two years.
                              This is no doubt so buyers would have to replace more often even more money in the manufacturers banks.
                              Sony used to be a name to look up to but sadly not any more.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                hopefully a more experienced member may of seen this issue before and give some advice , did you try a replacement tcon board?
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  you need to look at the tab bonds that attach to the panel ... ie. the other side of the panel that you are showing. further, connecting / disconnecting the tcon to panel cables while powered is probably not a great idea depending on how well / steady your effort is since there are powering pins happening in very small spaces.
                                  finally, the fact that you get some form of picture with one cable attached while the "opposite" scenario gets you nothing indicates that the "opposite" has significant issues.
                                  Having said that even the "one working scenario" gives you a "less than good picture" isn't a good sign also.... especially seeing vertical lines.
                                  can you provide some history of the set. My first guess is that someone was washing the screen and has contaminated the tab bond connections either at the edge boards or at the panel edge itself.
                                  still further, you can do some simple testing / checking of the components on the edge boards by just comparing results between the two sides / halves... concentrating on capacitors and resistors.
                                  • ronhayes
                                    TV Engineer
                                    • Mar 2014
                                    • 458
                                    Yes Vince
                                    I sent for one that did not produce a picture so i ordered another thinking that may be it was also faulty, when that arrived and i installed it gave me a red flashing light so i contacted the supplier (spares2repair) and they sent me a replacement one out and that was the same no picture !
                                    So maybe i have had all faulty t-con's or maybe it is lcd panel the only way i would be sure is if i tried a guaranteed new t-con board.
                                    But that would be another costly chance to take.
                                    • ronhayes
                                      TV Engineer
                                      • Mar 2014
                                      • 458
                                      Thanks for the info budwich looking at the panel with all the trim removed the bottom edge looks very clean no stains at all and the tab bonds are on the back of the screen so would have to completely remove screen to check the tabs, looking closely at the removed trims there is no sign of water stains at all.
                                      I fear to completely remove the screen would be a bit tricky maybe i am wrong.
                                      I am now getting ready for work as i am on nights this week .
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        I don't believe you have to "completely remove the screen" (don't know on this set... I worked on a 46). there was a metal bezel going around the screen that has a "dozen" screws holding it in place. The set / panel needs to be sitting face up. the bezel lifts off and exposes all the panel connections that need to be looked at. The pictures that you show of the tabs do not show the connections at the panel so its hard to tell if there are issues there.
                                        further... what is the history of the set?
                                        • iglitare
                                          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                          by iglitare
                                          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                          Backlight seems to work, Sound (Setup menu after reset) works.
                                          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                          With my small knowledge i would think at least the cables are good.
                                          Can this happen because of a bad tcon board?
                                          Or is it always a bad/shorted...
                                          09-04-2025, 07:13 AM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
                                        • noisykid
                                          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                          by noisykid
                                          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                          12-30-2024, 07:15 PM
                                        • bbrain
                                          Sony KD-55AG9 TCON?
                                          by bbrain
                                          I have this problem with my Sony 55' AG9.
                                          It flashes 4x.
                                          I have found the service manual, and seems it is the TCON.
                                          Before I buy a TCON can someone check the vid?
                                          Thanks in advance!...
                                          09-19-2024, 10:50 AM
