CyberPower 1500AVR - Repair
  • crash-cyberdrive
    • Jun 2013
    • 62
    • US
    My CyberPower 1500AVR endured after a long power instability in the past weeks, must have been on the way out. (about 7-9 years)The batteries no longer held a charge nor the UPS were charging them. Batteries are about a year old, but they are good and holding charge from an external SLA charger.
    I found thread 785895 and it helped determining what components were damaged.
    On this unit the charger circuit just got overheated to and extent I could not see was components where what.
    Like I wrote in that thread the traces are in good condition and the UPS was powering up and providing protection until the batteries no longer held a charge. Because this board is hard to get a replacement, I was thinking of repairing the section that got damaged by removing the components and filling with epoxy resin and re-drilling the holes. Also I have a stock of capacitors that if all works the ones on the board will be replaced.
    I like this unit better than the new model. I think it can be accomplished. Opinions Welcome.
    A Picture of subject is always Welcome
    Things saved from the e-landfill:
    Vizio VA26LHDTV10T 26" - Bad EEPROM Cap
    Asus PTGD1-LA Full Recap - Cha1 DDR socket damage
    MSI PM8M3-V Unstable CPU Recap CPU VRM circuit
    ViewSonic VA712B - still working on it
    Kindle Fire USB Connector
    MSI G31M-F Full Recap - Record Breaker done in 3Hrs.
    MSI P67A-G43 BIOS chip Reprogram - Tested and Happy
    The list will go on thanks to the people of this forum and many hours of reading.
  • Behemot
    • 4845
    • CZ
    Re: CyberPower 1350AVR - Repair
    Yeah try cleaning it with what's in english called a "white spirit" and see how it looks like beneath the condensed plastic
    • Relayer
      • Nov 2017
      • 35
      • Earth
      Re: CyberPower 1500AVR - Repair
      Hello crash-cyberdrive,
      I have to say that you are brave in regards to taking this on.
      I would check the transformer to make sure that it hasn't gone open circuit before you start.
      You'll have to test quite a few components, both on the primary and secondary of the transformer.
      You MUST ensure that you remove ALL the carbon off the PCB, especially where the carbon is extending between two or more components.
      Please keep us updated on how you get on.
      Good Luck!!!
      Regards,
      Relayer
        • Jul 2011
        • 6046
        Yes good luck to you cleaning and repair this power supply keep us updated on how your coming along with it
        • crash-cyberdrive
          • Jun 2013
          • 62
          • US
          By looking at this PCB material, I don't think would be too good to use "white spirit" (aka Mineral Spirits"). I could try in a piece I have very similar to the one I working on.
          All related components where removed and tested a F4 fuse found blown, C1 a 22uF 50v capacitor is way out of specs it gave a reading of 2.5uF@120hz the cause of damage.
          The rest was reading good but the surrounding components will be replaced as they where too close to the damaged area and are inexpensive.
          There is one diode D3 that I cannot make the number it is because it was on top of the heat source partially charring it. the only digits I could make out is 24
          Any tips on testing the transformers?
          T2 has continuity and read 1.2ohms on legs 3-4 and .5 ohms on legs 1-2, to me something is off; could be a choke and not a transformer? Could be me During the writing of this post I found T2 is a common filter choke and .45uH @ 100kHz on 3-4 and .55uH @ 100kHz on 1-2 not far off.
          I will be testing more of the critical components.
          Will keep you posted.
            Are you able to read the P/N of that SMPS IC at all? Viper22?
            • crash-cyberdrive
              • Jun 2013
              • 62
              • US
              Yes, luckily I was able to read "Viper22A". STMicro discontinued the one that has been removed but the substitute for is "Viper22A-E". I have been reading datasheets to try to determine what has been enhanced. But I think overall it will work with the circuit.
              • crash-cyberdrive
                • Jun 2013
                • 62
                • US
                Today's update
                Started the PCB cleanup process with a small dremel drum sand paper to remove most of the carbon. Later finished using a very small tipped dremel tool to clean most of the carbon on one of the ic leg hole. It did exposed a little bit of the trace underneath but was not torn.
                Also was able to identify the diode that was "charred" it turn out to be a rl207 diode.
                About to make a digikey order for some parts finally.
                Keep you updated.
                • Relayer
                  • Nov 2017
                  • 35
                  • Earth
                  Could you please see your modified picture below:
                  You need to remove the glue that's shown by the red circles. Search the rest of the PCB, top and bottom for this glue and remove it ALL.
                  That garbage has been known to become conductive.
                  Companies that used that glue during assembly didn't do their research in regards to the long term effects it may cause over the years due to heat and age. They apparently couldn't care less.
                  By the way, did you check Q4 as shown by the green arrow?
                  You need to perform a thorough check for shorts, OC's and leakage.
                  I ask this due to the fact it doesn't seem that it's ever been removed from circuit.
                  Could you please look at the next picture:
                  Can you remove the burned glue shown in the red circle.
                  Also, it is vitally important that you remove ALL carbonization between component holes, as show by the green rectangle.
                  I have to admit you've done a great job so far.
                  Regards,
                  Relayer
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    the damage was caused by arcing under that dammed brown glue.
                    remove it ALL!
                    • Behemot
                      • 4845
                      • CZ
                      Not sure about arcing, it usuelly is not so conductive to transfer some signifficant amounts of power to blast anything directly.
                      I however thought about how it used to kill FETs especially in Enermax Liberty units and I think it acts as resistor divider, in time able to transfer voltage enough (with 380V input) onto the gate to keep the FET(s) open the whole time. Sometimes the controller manages to shut the unit down when it only takes longer to turn the FETs off but it is still not able to keep them on the whole time. After some time it will happen and the transistors explode as being both on at once, it is basically a short between primary high side and return.
                        Btw, those two rectifier diodes and the two filter caps is setup as Voltage doubler circuit to to run that SMPS IC. The diode right next to the transformer is part of RCD snubber network.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          i suggest you look at the carnage in samsung boards caused by arcs through glue.
                            Like this?
                            https://www.badcaps.net/forum/showth...ight=bad+glues
                            Been there many many many times before.
                            • crash-cyberdrive
                              • Jun 2013
                              • 62
                              • US
                              Like this?
                              That post do contains valuable data, it's like that glue is timed failure in case the capacitors don't do just that. Another tip well learned, thanks.
                              Will continue the clean up and remove that Q4 and test it out, but there is a high chance it will be replaced too once off.
                              • Behemot
                                • 4845
                                • CZ
                                Like this?
                                When it's already degraded to almost plain carbon (never seen it so black myself though), than I guess yes, it conducts pretty much everything.
                                Otherwise it seems it always has resistance of at least few kiloohms, don't think it can arc with normal operating voltage (about 380 V DC with active PFC). Probably when there is some overvoltage spike which the varistor does not fully catch, than maybe a kilovolt could appear for an instance and than it could arc?
                                  It never turns to carbon by itslef. It turned to carbon after the arc and burnt occurs.
                                  Using Ohm meter to test the conductivity is not going to give you the real conduction test.
                                  Try 400V or more in real world where those glue are being used in.
                                  It is like testing 1000V rating diode with your meter that only puts out 3~6V (depend on batteries), it may show good but it fails when exposed to working Voltage.
                                  Been there done that many many many times before. I have dealt with these glue since the 70's, long enough to know better and see what it can destroy, I still get the request the Chinese OEM asking to use them in place of the more expensive Electronics grade Silicone RTV, I show them the pictures.
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    You can use a Megger to test the glue.
                                    Not a multimeter as budm stated...
                                    In my picture below a multimeter shows no conductivity in the glue.
                                    But a Megger set to 1kV does, along with some buzzing.
                                    In this case it might not be a problem, as this is the PWM/PFC controller and thus sees low voltage.
                                    However the same glue is all over the PSU, this was just the area that was most blackened.
                                    And worse: if it where to become conductive even at low voltage here, due to for example increased moisture level.
                                    Then the whole PFC stage will go kaboom!
                                    • Behemot
                                      • 4845
                                      • CZ
                                      Guess it's even worse than I thought
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        it develops a carbon track that rapidly grows and gets exponentially worse.
                                        pretty soon you have a big hole in the board or worse a fire.
                                        i bet if a major mfr gets sued and a huge judgement this shit will go away overnight.
                                        unfortunately that means folks die over this.
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • quickname
                                          Cyberpower 1500AVR UPS repair
                                          by quickname
                                          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                          Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                                          I decided to verify that the batteries were...
                                          11-12-2023, 09:57 AM
                                        • carrzkiss
                                          Cyberpower cps1500avr not charging batteries
                                          by carrzkiss
                                          Hello, all.
                                          Cyberpower Battery Backup Unit.
                                          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                          Checking the voltage, it was down to 22v.
                                          I quickly removed everything...
                                          06-15-2024, 02:10 PM
                                        • BTubbs200
                                          Dell Latitude 5420: No charge, no boot; amber LED for as long as the power button is held.
                                          by BTubbs200
                                          Dell Latitude 5420 P137G
                                          Board model LA-K491P REV A01
                                          Laptop is stone dead and only reacts to the power button being held while the charger is plugged in, in which case a dim amber LED fades in and immediately fades out when I let go. Battery being plugged/unplugged does not change anything.
                                          CMOS battery was removed and reinstalled; no change.
                                          No shorts to ground have been identified on the board whilst probing the power rails in resistance mode. No visibly damaged components.
                                          No indication that the CPU is receiving power; CPU fan does not activate.
                                          Of...
                                          01-23-2025, 10:45 PM
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
