How to modify old CPU PSU into bench power supply?
  • NeedsMoreFlux
    • Oct 2017
    • 121
    • California
    I've been looking around the interwebs for information to convert my old CPU power supplies into a bench top power supply.
    I've found some places that suggest you use 1x220ohm/10watt resistor on 12v to ground. And 1x100ohm/5watt resistor on the 5v to ground.
    Anyone have any experience on these?
    And the thin green wire just needs to be touched to ground(thick black wire) if I'm not mistaken(?) Or does I need to keep the switch on?
    I made my own air filter for solder fumes, and I will be using it alot, as soon as I get this question figured out.
    Thank you all.
    Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
    I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
    Some of the things I've fixed:
    60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: How to modify old CPU PSU into bench power supply?
    The problem is that there are too many unique power supplies out there to really give a good suggestion on what to do with them. If you don't need voltage or current control, then shorting the green wire to GND on a working PSU will turn it on,and not much more needs to be done.
    Some PSUs don't need minimum load. But those that do, that's what the added resistors are doing. Look at the label and see if there's a minimum load, use that current rating and Ohm's law to calculate a resistor that meets that requirement.
    • Lloyd6202
      • May 2017
      • 59
      I just finished building one..I suggest a buck boost board on your 12 v
      • Lloyd6202
        • May 2017
        • 59
        Nothing fantasy but works for everything I need to do
        • NeedsMoreFlux
          • Oct 2017
          • 121
          • California
          HAHAHA, I just shocked the crap out of myself. I was feeling around for high temperature on the PSU after I modified it.
          I don't think I even touched the transformer. But it felt like my finger was getting hit by a fan. It took a second to register and pull my hand away.
          WTF lol! It has cheap yellow tape around it to insulate it, and my finger was near the top, not the bottom where the solder joints are?!?!?!
          Maybe I should coat it in plasti dip...
            • 31137
            yea, in california you feel like your finger hit the fan - try that shit in europe and you will think your hand got hit with a hammer!
            when you have real mains, you pay more attention to where your fingers are!
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              ^ Yeah bud, the core floats at PFC voltages.
              Like STJ said. Its nothing compared to 200+ volts (277 in my case...)
              Follow the white rabbit.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                Take at look here:
                https://www.badcaps.net/forum/showthread.php?t=32826
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  i have a atx supply ive converted into a bench psu im thinking of adding a usb port so i can charge devices now ive read various posts regarding adding a 200 ohm resistor across the data pins as some devices wont charge without it whats your thoughts.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • shamsudeen
                    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                    by shamsudeen
                    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                    i know that in linear power supply the noise will be very low comparing to SMPS supply....
                    07-19-2025, 07:14 AM
                  • rabsonnjala
                    LENOVO IDEAPAD 100 works only on bench power supply
                    by rabsonnjala
                    Hie I have a Lenovo laptop
                    Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                    it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                    below are my readings
                    with the original charger only
                    JBATT1
                    PIN1 0.22V
                    PIN2 0.22V
                    PIN3 0.45V
                    PIN4 0.45V
                    PIN5 O.43V
                    PIN6 0V
                    PIN7 GND
                    PIN8...
                    11-20-2021, 08:32 AM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                  • JimBanville
                    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                    by JimBanville
                    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                    09-13-2023, 07:21 AM
