Story of another dead deer and a doppleganger.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    I found one of my machines had died and it had an Allied 250W PSU in it...another Deer it looks.
    5VSB is dead. Figures.
    Anyway as I was searching around for that DR-0183 switch controller chip (DR=Deer? Did they get their own chips?) I found someone had a 400W supply with the same chip. Well, that's not that surprising, TL494/KA7500's are used everywhere.
    As I looked closer at the guy's pictures...his 400W PSU looked very uncanny...it was an exact copy of my 250W-rated supply! Same 470uFx2 input caps, placement is identical... Well, almost. Mine has input filters, his has a (possibly fake) PPFC choke. And then looking at it even closer, it seems his just has a bigger TO-247 diode packs instead of the TO-220's in mine.
    And his was working apparently, but wanted to mod it for a higher output voltage. I suspect his PSU would probably soon end up like mine soon anyway... dead.
    Alas most likely another worthless repair coming right up! Once I figure out why the 2-transistor oscillator is dead...
    TBC...
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: Story of another dead deer and a doppleganger.
    470uF, if within spec, would be good for 250W, but not for 400W. Unless the switch transistors are beefed up, the transistors that were OK for 250W would have probably brief violent lives at 400W. And if the same heatsinks and fan are used, they probably would not be good for 400W. Then there's the output inductors and caps. Using the same PCB for uprated power levels can work, but components have to be uprated.
    You probably know this, but check small electrolytics in the Stby primary circuit.
    PeteS in CA
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      Yep, the heatsinks are the exact same, a flat piece of aluminum with a comb cut and fanned out of the top. The absolute cheapest heatsink - not even an extruded heatsink with holes. All in all, I agree, this should do 200-250W just fine, but have my doubts of that 400W. However I'm grateful the placement/schematic are the same.
      A cursory check with the ESR meter indeed indicates a boatload of bad caps, not only of the 5VSB but also including the primary outputs. Now the question is whether it's worth to repair or diagnose further, I'm hoping the DR0183 isn't fried as collateral damage as I have no spares. Studying the schematic a bit, this circuit is funny, it looks like it was designed so that the same board could take both BJT and MOSFET primary switching transistors which makes it more difficult for me to bypass the 5VSB to see if the rest of the circuit works.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8706
        BTW: the doppelganger is at http://www.webx.dk/oz2cpu/radios/psu-pc400.htm
        Attached is my PSU.
        Looks like the 5VSB caps are in the upper/center just to the left of the fuse, and the small cap between EEL-19A transformer and the low voltage heatsink is dry. It's not alone, lots of high ESR caps in there...
        • PeteS in CA
          • Aug 2005
          • 3583
          With those heatsinks I'd be nervous about greater than 200W continuous. Some of those output caps look preggers.
          PeteS in CA
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            Yeah, a bunch of caps are bulging. Need to be replaced as well.
            I wonder how many watts I can (safely) pump through this if I *just* replaced the heatsinks with some larger ones that I saved from other dead PSUs, and swapped the output rectifier diodes with larger ones...
              • 31278
              a well assembled shit design!
              fuse in clips instead of soldered in,
              fan using a plug/socket assembly,
              but the actual design - i would use it for parts myself!
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                and gobs of evil brown glue.
                  • 31278
                  and hotglue - i hate that wax-based stuff!
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8706
                    I thought hot glue was low melting point plastic and not actually glue or wax? It feels waxy however, but not actually melting at finger temperatures like real wax. Feels almost like set RTV.
                    Are there really any parts worth saving in this? I don't think this even has overvoltage shutdown, or I can't tell if it's included internally within the DR0183.
                    I was kind of surprised - it even has a full complement of noise filters - full pi filter on output and filter on input, unlike its doppelgänger.
                      • 31278
                      white spirit will liquify hot glue - whatever that indicates!
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8706
                        Gasoline and other hydrocarbons dissolve polystyrene, which isn't a wax.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8706
                          Okay...This sucks.
                          Multiple failure time.
                          I got 5VSB to work again but PSU is still broken. I want you guys to take the wildest guess what the problem was with the 5VSB. I couldn't believe it myself but when all the usual suspects are ruled out, the only thing that remains must be the problem.
                          Useless hints:
                          transformers are all good
                          V+ (the voltage across the main caps) is good, unlike that other PSU I fixed.
                          The burned area across the 1K resistors have nothing to do with the 5VSB failure.
                          I did replace a part.
                          Take a wild guess of why the 5VSB was dead, while I figure out why the main supply is going into shutdown right away... So it looks like quite possibly the DR0183 does have over/under voltage protection...
                          Oh well, guess wasn't enough time as I figured out the shutdown. And the supply has been completely rootcaused: the mystery part and bad capacitors on +5 (main) and +3.3 lines. Supply is deemed fixed as I stuck a capacitor in parallel with the bad ones to test my theory. I just need to solder new capacitors in...
                            • 31278
                            wire broken loose from the board??
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Useless hints:
                              Well, if I remember correctly, those 1K resistors go to the Vcc of the DR0183 PWM chip. When they burn, that's a sign that the secondary-side auxiliary rail from the 5VSB has been going over-voltage, typically either due to a bad critical cap (22 uF, 50V, I believe) or the output caps going bad. Thus, I'm putting my money on either bad critical cap for the 5VSB, bad output caps on the 5VSB, or possibly the 5VSB FET/BJT died to save the rest of the 5VSB circuit. Yes/no???
                              Yup, don't expect more than 200-250 Watts, depending on your room temperature.
                              JEE, what else did you expect!
                              It's not that bad of a PSU, actually. Once recapped, these older Deers and L&Cs are pretty dependable. But they are extremely basic PSUs - UVP and OVP trip points are quite low/high, and I think the 12V doesn't actually have either OVP or UVP (forgot which). Also, the efficiency of this platform is just sad nowadays - maybe 75% on a good day, if even that.
                              But like I said, they are dependable PSUs, once recapped fully. I've been using mine (a Deer DR-250ATX) for 5 years now (after recapping it, of course). Granted I don't have it running 24/7... heck, not even 1/7 - I use it maybe for one to three weeks every year when at my grandmother's house. After that, I turn off the PC, disconnect it from the wall, and store away.
                              That's shouldn't be the case. These old Deers are based on the classic half-bridge design with BJTs. Only the 5VSB may use either a MOSFET or a BJT, but that's a different story.
                              I think those chips are either an early version of the 2003/2005 "chip-of-the-year" ICs or perhaps a close variant of the AT2005B or ATX2005. In any case, the difference between those and the TL494/KA7500 ICs is that TL494/KA7500 only have two comparators inside them that can be used for the protections, whereas the earlier mentioned chips like the DR-0183 pretty much take the 3.3V/5V/12V output directly through a resistor to handle SCP/OVP/UVP.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8706
                                I guess it's gone long enough, and dang you momaka, you took my JEE joke for the solution to this puzzle
                                OK. At first due to those 1K'ers frying, I did think either the 5VSB output caps (1000uF C18/C19) and the critical 22uF C9 caps were bad. They were indeed bad but I had a bad feeling that it wouldn't fix the problem. Since their ESRs were awful, I swapped them anyway.
                                I powered up...
                                Still dead. Bummer.
                                So I went through finding other parts that were bad, testing a few out. After pulling a lead of R3, a FREAKING 1Mohm resistor, I found that this resistor was OPEN.
                                This would totally explain why 5VSB was dead. So I replaced it, and 5VSB came right up. So the solution to the puzzle was the replacement of R3 (or R5, since the two are in series) was open.
                                So I went ahead and shorted GREEN to GND with a load... a pulse of life...and dead again. Waited a few seconds and tried again, same. => Yes this thing is shutting down due to OVP or UVP or something.
                                For the heck of it I scoped the outputs and sure enough, the 3V3 line was going way overboard.
                                Now the joke that was taken away from me: JEE, I wonder why. 1 ohm of ESR.
                                And that was the end of the story.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  Oh. Sorry!
                                  Crap, that would have been my 4th guess!
                                  I've seen this happen a few times, but it seemed like the failures were all random (no sign of the resistor overheating to become open-circuited).
                                  Well, joke stolen or not, I still smiled at that one.
                                  JEE is one of those names that is just asking for someone to poke fun at it, just like Canicon, PowMax, and Powork. Couldn't help it!
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8706
                                    Yeah I was dumbfounded when I found that dead resistor, how could it be? 1M has no way of dissipating much power with the voltages we're dealing with here, even with 340VDC. Plus no burn marks. I have to chalk it down to perhaps bad resistor manufacturing.
                                    So the bad units were JEE IM 2200uF/10V, Jun Fu HK 1000uF/10V, CapXon KM 10uF/50V (ESR was bad compared other 10uF caps I had but I think this one was in a "don't care too much about ESR position", and Fuhjyyu TM 22uF/50V.
                                    Lest we not forget Fuhjyyu
                                    • PeteS in CA
                                      • Aug 2005
                                      • 3583
                                      Really high value resistors can sometimes break down internally and open up. Another possibility is that resistors do have a maximum rated voltage. It usually is way higher than the circuit voltages, but on the primary side or in snubber circuits it can be relevant and a cause of failure.
                                      PeteS in CA
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8706
                                        The other thing is that there were two of these 1M resistors in series, so as a voltage divider, only half would appear on either one. Still very unexpected for it to fail.
                                        It is, however, on the primary side. They're virtually but not completely across the voltage doubled mains. The bleeder resistors flow more current (2x220K vs 2x1M+47K).
                                        The 1M'ers were standard 1/4 W carbon composite resistors, and I thought most of them were rated about 500V, mostly due to arcover from terminal to terminal. Then again at 500V, the 1/4W 1M resistor would be dissipating 1/4W...
                                        • khalillll
                                          maxipower 400W Dead power supply repair
                                          by khalillll
                                          The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
                                          After checking, I replaced the UTC7606D IC to restore the 5VSB.
                                          I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
                                          Replaced it again with another UTC7606D.
                                          Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
                                          After checking again, I think the issue was with the UTC7520D IC.
                                          Replaced it with a WT7520.
                                          Result: PSU fully working again
                                          09-27-2025, 05:06 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
