Hello starting a new thread since I had the wrong model on the last one. It is a Sharp Aquos LC-60LE600U not the LC -70LE640U. Anyway, the set has no power period unplugging, holding power down for 10 sec the plugging back in /vol+channel down while plugging in did nothing,. I did pull the power supply and checked the fuse with a dmm which zero'd out buzzed. And will have to find what all the pins should read from the socket that connects to the main board. If anyone else might have any suggestions or what else to check that would be appreciated...
Sharp Aquos LC-60LE600U no power period
Re: Sharp Aquos LC-60LE600U no power period
With the advice of 'dskall', I did back probe the main board plug- plugged in to the power supply and power to the board. I have a picture and illustration of the voltages I found. I have no schematic or diagram or know where to find one. Any input with what I found would be a big help-
ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
The connector PD and the numbers around it tell you what voltages you should have on the pins eg PD-5-6-7-8 should have 13.2vdc when things are working. Next to connector should tell you were pin 1 and 24 are on connector. Take readings and post as p5 13.2v = voltage you get for all pins. Then push power button while probing Pin 14 ps-on and you should get a voltage.I assume no responsibility for any stupid suggestions I might post.Comment
Hi thanks I am just confused as to what slots correspond to what numbers but I did go back and back probed each one again while hitting the power button and didn't see any change. I did accidentally leave out a reading before which was 0.00 that I don't see matters. Do you know where I can locate a diagramAttached Filesif you find these attachements useful please consider making a small donation to the site
If you look at the PD connector on the top side of the board you will see '1', and '2' printed right next to the connector.
The exposed pin you can see on the top side of the board are the ODD number pins, the other pins you cannot see are the even number pins, which you can probe them on the female back side of the connector.
We need the pin name and follow by the DCV reading of each pin so we can see which Voltages and signals are missing.
http://www.shopjimmy.com/sharp-runtk...-led-board.htm
Sharp RUNTKB057WJQZ (DPS-168JP A) Power Supply / LED Board
Pictures provided by shopjimmy.Attached Filesif you find these attachements useful please consider making a small donation to the site
http://www.badcaps.net/forum/showthread.php?t=24809Comment
I don't know exactly which board you have but Sharp did have a problem with D7805 shorting. might be worth checking. original diode is NUR460, change to MUR460Attached Filesif you find these attachements useful please consider making a small donation to the site
Ok so I think I know what pin and its number - when I tested with the dmm with power to the board and compare to what printed around the, they don't add up. I had back probed but the readings didnt change but I will need to run through it again tomorrow. Any other suggestions?
any luck on the 757?Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi thanks I saw the D7805 diode but I did check it and all the ones on the board in diode mode but without removing them from the board. Between all of them there was a range from 300's to 600's with the pos side on the anode side and neg on the cathode side and reversing the probes gave me an l or 1 left on the screen. Does that sound like it may be ok?Comment
The readings aren't supposed to change but you're supposed to LABEL each pin so we know what they SHOULD be.Ok so I think I know what pin and its number - when I tested with the dmm with power to the board and compare to what printed around the, they don't add up. I had back probed but the readings didnt change but I will need to run through it again tomorrow. Any other suggestions?
any luck on the 757?Comment
The readings make no since to me. Look on other posts to see how to format your voltages. Should be
p1 pson =?v
p2 gnd =0v
p3 stby5v =?v formatI assume no responsibility for any stupid suggestions I might post.Comment
https://www.badcaps.net/forum/attach...2&d=1485933978
You count the pin wrong, I guess you did not read my post 7 about the pin '1', '2' and the reporting format.
I do not have the board in front of me so I did the research to find the pictures of the board and study them and give the instruction on how the pins are assign.
What more do I have to do?Attached Filesif you find these attachements useful please consider making a small donation to the site
With Magnavisors on I didn't even see that 1 & 2 tucked in there- in post 7 I thought you were making reference to (PD-1-2) PNL12V since it was at the top of the PD. Anyway, I hope this makes better sense. Also while I back probed all the pins, I tried hitting the power button which did nothing-
Pin 1 PNL12V = 0.00V
Pin 2 PNL12V = 0.00V
Pin 3 GND = -0.00V
Pin 4 GND = -0.00V
Pin 5 UR13.2V = 13.15V
Pin 6 UR13.2V = 13.15V
Pin 7
Pin 8
Pin 9 GND = -0.00V
Pin 10 GND = -0.00V
Pin 11
Pin 12
Pin 13 AC_DET = 3.28V
Pin 14 PS_ON = 2.07V
Pin 15 BU5V = 5.01V
Pin 16 PNL_POW = 0.05V
Pin 17 PWM1 = 0.16V
Pin 18
Pin 19 DIMMER = -0.00V
Pin 20
Pin 21
Pin 22 ERROR = 0.95V
Pin 23
Pin 24 STB = 0.58VComment
BTW, did you see any blinking error codes at all?
For example:
https://www.badcaps.net/forum/showth...&highlight=STB
Pin 16 PNL_POW = 0.05V = No command to turn on PNL12V for running the T-CON
Pin 24 STB (Von) = 0.58V = No BL-ON to turn on backlights circuit
No dimming control:
Pin 17 PWM1 = 0.16V
The key is this one which I do not what it should be for normal operation:
Pin 22 ERROR = 0.95VLast edited by budm; 02-01-2017, 03:23 PM.Never stop learning
I expect error codes since the standby power supply is present, other wise it means the main board is dead due to what I do not know.Never stop learning
tjmethod says pushing power button does nothing. Maybe problem with power to buttons and led on front? I have quick question for you budm if I might and don't want to hijack tread. You say pfc should be >360v if it is 357v will that cause a problem?I assume no responsibility for any stupid suggestions I might post.Comment
Hi yes unplugging and holding power, plug in hit power again or vol and chan down while replugging does nothing. when I saw the key controller is plugged into the main board I figured that might be smoked worse then the power supply- is there some method of testing the main?Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
- No more items.
