Is It Normal for the Capacitors to Get Warm in Operation?
  • The_Doctor
    • Oct 2008
    • 1
    I've just got two new Intel D865PESO motherboards off of eBay, one is to replace a failed board in a friend's P4-3.2Ghz System, the other one is to replace the motherboard on a p4-2.4Ghz system that originally had onboard video. That computer is being used to run a CNC milling machine, and apparently onboard video oftentimes does not work well with the machines real-time functions. Enough about what I'm doing with them, let's get down to the question.
    I installed the 3.2 GHz Pentium 4 onto one of the boards, along with one gig of memory. I did not install it in a case, it's just laying out exposed and hooked up to a power supply and monitor, just to make sure the CPU and memory actually still work. Well, it boots into Windows no problem whatsoever and shows absolutely no instability, but I accidentally bumped one of the capacitors up near the CPU voltage regulator, and noticed it is quite warm. I then started feeling several of the capacitors near the CPU, they are all quite warm, actually a bit warmer than the CPUs heatsink. You can hold your bare finger on them, but they are warm enough that it is not comfortable. I also noticed that some of the other capacitors, not located near any components that all these we use a lot of power, are at least moderately warm.
    I have never actually checked the temperature of capacitors in a switching power supply, so I don't know for sure, but this does not seem normal to me. I am used to large electrolytics that are simply rectifying 60 Hz AC, and they never seem to get warm at all unless they happen to be located near one of the power tubes. Is it normal for several of the capacitors on a motherboard to get rather warm like I'm seeing, or do I have a motherboard which is basically ready to die right out of the box?
    Thank you
    Ed
  • stevo1210
    • Oct 2006
    • 4156
    Re: Is It Normal for the Capacitors to Get Warm in Operation?
    The capacitors that around the CPU tend to get quite warm. So that would be normal and I would not be concerned about it if I were you. If they are getting really hot, I'd be wary as the hotter caps get, the shorter thier life becomes.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      much of the heat is conducted to the caps from vrm parts and the cpu itself through the board.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        As said caps will get warm due to the heat from nearby components.
        Also caps dissipate ripple as heat.
        A cap that's dealing with excessive ripple will be hotter than one that isn't.
        A cap that's failing will also get hot.
        As they go bad the current through them goes up and that creates more heat,,
        which causes more damage -> more current -> more heat in a cycle until it burns open or shorts.
        Mann-Made Global Warming.
        - Dr Seuss
        • Loretto
          Samsung SMPS BN44-00339A
          by Loretto
          this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
          I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
          I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
          I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
          03-29-2025, 08:30 AM
        • Loretto
          by Loretto
          03-28-2025, 10:28 AM
        • survivalbloke
          Dell EC chip warm/hot before power-on - normal?
          by survivalbloke
          This is a shot in the dark, and if you need more info, I'll give it all to you. I've already asked for the schematics and boardview.
          This board won't power up. Has 3.3v on BIOS chip pin 8, 3.3v on power button, confirmed voltage to 0v when pressed power button. The EC chip is quite warm just with the power adapter connected and nothing else. Board is out of the machine and everything disconnected. I'm guess that's abnormal and probably the reason for not powering up. I'm still learning and have been fault tracing with my level of knowledge.
          Just wondering if the EC...
          02-06-2023, 05:20 PM
        • redbaron1007
          Yamaha HTR-3065 No power/No Standby
          by redbaron1007
          I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
          S9 13.7V
          Pwr Ry 0V
          AC Det 9.1V
          Mgnd 0V GND
          The two pins on the transformer for the operation...
          09-12-2024, 03:04 PM
        • c_corr
          Asus P4C800-E VRM issues
          by c_corr
          This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
          This board uses mext ICs and Mosfets in VRM:
          - ADP3180 PWM controller - in 3 phase mode
          - ADP3418 as Modfet drivers
          - High side Mosfets STD38NH02L (from ST)
          - Low side Mosfets STD90NH02L
          Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
          I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
          02-08-2025, 11:59 PM
