Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 12-06-2016, 01:36 PM   #1
capwizard
capwizard's Avatar
City & State: Arizona
Default LED TV dummy load.
Any help will be appreciated. I try to built "universal TV LED screen dummy load." .
Basically, put a lots of LEDs try to cheat LED driver to work. So we can distinguish the problem is at LED screen or LED driver.
capwizard is offline   Reply With Quote
Old 12-06-2016, 02:55 PM   #2
ReeceyBurger123
Never Give Up !
ReeceyBurger123's Avatar
City & State: Telford
My Country: Britain
Line Voltage: 240 VAC 50Hz
I'm a: Student Tech
Default Re: LED TV dummy load.
Just use some 10w leds in series to match the output load of the driver easy
ReeceyBurger123 is offline   Reply With Quote
Old 12-06-2016, 04:19 PM   #3
capwizard
capwizard's Avatar
Maybe some 10w leds and some 3v leds, but for some critical driver we will need exactly same current.
TV LED screen dummy load version I : This is work OK, but customer will think you still in school.
TV LED screen dummy load version Il : add some protection.
TV LED screen dummy load version Il: 10 x10 =100 leds, some TV have 8 strips, I need 8 of them.
TV LED screen dummy load version Iv: use Edge tv strips but is hard to solder
Best way to do it probably have customer made PCB . (last two pic)
File Type: jpg pl3921121-metal_core_led_tube_pcb_assembly_led_panel_pcb_boards_75ra_or_80ra.jpg (147.1 KB, 28 views)
Old 12-06-2016, 04:33 PM   #4
ReeceyBurger123
Never Give Up !
My Country: Britain
I'm a: Student Tech
Awesome
Old 12-06-2016, 04:53 PM   #5
capwizard
capwizard's Avatar
Maybe modified form this. cheap. Pic 1
https://www.aliexpress.com/item/SMD-...999.414.kjp8Qb
Old 12-07-2016, 01:55 PM   #6
capwizard
capwizard's Avatar
Instead of LEDs, can I use this:
http://www.eevblog.com/forum/project...-load-project/
http://www.eevblog.com/forum/project..._next=prev#new
Old 12-13-2016, 09:22 AM   #7
capwizard
capwizard's Avatar
Must-have Sharp LG Vizio edge led tv dummy load.
I need to make 100% sure Sharp LC60LE660U TV problem is caused by edge LEDs .
The easy way is to use the same one as a tester.
What happened to test different size TV, I will need universal LED dummy load!
Sharp LC-52C6400U LC-52LE640U LC-60C6400U LC-60LE640U LC-70C6400U LC-70LE640U LC-80LE633U
at picture 2: the tester got hot in second will needs heat-sink like pic 3 (too long to carry around.)
Pic 4,5 : Connector pin out
Old 12-13-2016, 11:14 AM   #8
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
The key is trying to figure out how many LEDs there are in the string without taking the panel apart to get to the LEDs.
Also need to find out if the LED strips are connected in series to form one big string or each strip is driven by its own driver.
You can tell by looking at the PWM Controlled MOSFETs for the Cathode return for the LED string, if it has two PWM controlled MOSFETs then two drivers circuits are used.
http://www.badcaps.net/forum/attachm...5&d=1481642097
I can see that it has four drive circuits for the LEDs' strings.
budm is online now   Reply With Quote
Old 12-13-2016, 11:23 AM   #9
capwizard
capwizard's Avatar
Thanks for your reply.
Over this Sharp tv has 4 drivers 34 LEDs each.
Can I use something else instead of LEDs to test ?
Old 06-19-2019, 04:17 AM   #10
ZXCVBS
City & State: Buenos Aires
My Country: Argentina
Sorry to revive an old thread, but I just wanted to ask.
I know i can calculate led resistance knowing the loaded voltage, and current.
i.e if i the power board outputs 200v 250 mA to the leds
I could use ohms law:
R= V/I 800 ohms. W = i*i*v 12.5W. An replace leds with a 800 ohm 12.5 W resistor
But if i lower those 200v (250 mA) to 20 v 2.5 A
can i connect that output to an electronic load, and start at minimal values until the led backlight is on its working condition range?
Don't know if i'm shooting a mosquito with a shotgun.
ZXCVBS is offline   Reply With Quote
