Vizio M492i-B2 Won't Turn On
  • John90
    • Aug 2016
    • 27
    • united states
    My girlfriends grandpa asked me to take a look at his TV because it wouldn't turn on anymore. The TV is a Vizio Razor 49" model M492i-B2. I took the back off to access the circuit boards inside so I could inspect them for any obvious signs of damage but I couldn't see anything that really stuck out to me. I took a picture of each board so maybe someone might see something I didn't. The TV doesn't turn on and there is no stand by light or anything. Any help is greatly appreciated!
    Re: Vizio M492i-B2 Won't Turn On
    What kind of tools do you have? We need to test the fuses and some Voltages testing.
    • John90
      • Aug 2016
      • 27
      • united states
      I do have a multimeter. If there's anything else I need let me know.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8351
        So either you got no STBY voltage from the PSU or the main board is bad. All fuses on the PSU are good? When you plug the TV in you get roughly 170V DC on the main filter cap?
        check if you have STBY voltage coming from the PSU going to the main board first.
        • John90
          • Aug 2016
          • 27
          • united states
          Thank you for your reply CapLeaker. The fuse(s) seem to be good. I checked the STBY voltage at the connection on the power board and the main board and I am getting 5v at both connection points. I checked the filter cap as well and I'm getting 170V DC from that as well. What should I check next? Your help is really appreciated!
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Can you list the pin names and the voltages on them when out of standby.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8351
              O.k. so far, you got STBY voltage and that is going to the main board.
              Next you follow dick barton's post above. Do that with the TV off and on.
              A problem is that this TV actually has a separate LED driver board and there are no pinouts that I could find, to see what pin does what. I doubt that if you disconnect the main board (and maybe the LED driver board too), while jumping PSon with a 1k resistor to STBY voltage, that the backlights come on. This is me hoping that the PSU has a pull up resistor.
              I just got looking and SJ has sells all the boards as a repair kit for $75. For now I'd like to see the backlights first.
              • John90
                • Aug 2016
                • 27
                • united states
                If this isn't what you were looking for just let me know.
                With the power cord plugged in these are the voltage readings I get for each pin on that connector.
                NC-1
                NC-1
                NC-1
                Blank-11.8
                Blank-11.8
                GRD-.8
                GRD-.8
                Blank-11.8
                Blank-11.8
                GRD-.8
                GRD-.8
                PS-ON-2.99
                AC_OFF_DET-3.3
                5VSB-4.99
                5VSB-4.99
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8351
                  When the TV is on like that, can you shine a flashlight into the screen to see if you can see a picture? Do the backlights flash on for a second when you turn on the TV?
                  The PSU looks fine, the main board is returning PSon, and the PSU turns on. So either there is still a other fault with the main board, or there is something wrong with that LED driver board or the backlights themselves. Could you measure the pins on CN202? I know there isn't any labeling, but there should be some power going form the PSU to the LED driver board.
                    Check the DCV both ends of 0 Ohm resistor R9008, 9010 with ref..to chassis GND.
                    That LED driver board has two Boost converter circuits.
                    Vizio 75.50070.200 LED Driver.
                    http://www.shopjimmy.com/vizio-75-50...ed-driver.htm#
                    Pictures provided by shopjimmy.
                    • John90
                      • Aug 2016
                      • 27
                      • united states
                      Budm, I checked R9008 and 9010 and get 24.70v on both.
                      CapLeaker, I was able to check the top pins on CN202, the pins on bottom are kind of hard to get too. The pins on top show 24.7v at the power board and the LED driver board. The bottom pins I could check showed 0v, I am guessing these are ground. The backlights don't seem to do anything at all when you try to power on the TV.
                        This is going to be tough because we do not know the signal pins on the CN901.
                        If the board is getting the BL-ON then the DCV on Capacitors TC903, TC901 should jump up much higher than 24VDC.
                        • John90
                          • Aug 2016
                          • 27
                          • united states
                          The 24VDC was on R9008 and 9010.
                          The voltage I am getting on capacitors TC903 and TC901 is
                          TC901=8.84VDC
                          TC903=12.54VDC
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            There's one selling quite cheap @ $14
                            http://www.ebay.com/itm/VIZIO-LAKERS...-/381520240952
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8351
                              Those caps are only rated for 25V. If the get more voltage than that, they are gonna puke. However TC901 is low compared to TC903. Now here is a clue.
                              • John90
                                • Aug 2016
                                • 27
                                • united states
                                With TC901 being low is there something else I should check next? Should I get a new board? Replace TC901?
                                  My mistake, I trace out those two sections with L902, L904, the power MOSFETs, the diodes: it is setup as a buck converter not boost converters, so the output should be <24V.
                                  Need to get the spec of that U900, 904 to find out what the output Voltage should be based on the values of the feedback resistor network.
                                  Also need to P/N of U902, 903.
                                  Also need the pictures of the backside of the TV so we can see how all the boards are connected together.
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8351
                                    This led driver board is a pain in the rear, not having anything marked on the pins.
                                    There must be a ribbon cable going from the main board to that LED driver board. One of these wires must carry the backlight on off voltage. Could you verify this that the main board is putting out the BLon? You would be looking at a 3v signal that appears when the tv is turned on and disappears with the tv off, same as the PSon signal.
                                    Making a mistake is a human thing, I am not perfect either budm. What counts is the will to learn.
                                    • John90
                                      • Aug 2016
                                      • 27
                                      • united states
                                      Having a little trouble trying to find the BL-ON as nothing is labeled on these boards. I did find a pin coming from the main board that had 3V on it but the voltage never changed when I pressed the power button.
                                      Budm, I got a picture of the wiring.
                                        CN901 should be the controller connector which goes to the main board, but as you indicated, they are not labeled, so all you can do is to take the DCV reading when TV is OFF and when TV is turned on.
                                        • Mulp
                                          VIZIO M65-C1 Does Not Turn On
                                          by Mulp
                                          Hi All,
                                          I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
                                          When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
                                          I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
                                          01-13-2024, 09:57 PM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
                                        • masoksian
                                          Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                          by masoksian
                                          Hi everyone,
                                          I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                          The system does not turn on, there is no post.
                                          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                          The problem continues in the same way.
                                          I tried to turn on the Fn key, nothing came to the screen....
                                          02-15-2025, 12:08 PM
