HP DV6-7005SP 48.4ST10.021 Goya Balen Bios Dump Needed
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Hello , can someone give me a bios dump for HP DV6-7005SP ?
    Goya/Balen 1.0 DDR3
    11254-2
    48.4ST10.021
    Thanks in advance
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: HP DV6-7005SP Bios Dump Needed
    You must try with this if is 8mb
    • mpikou
      • Jun 2013
      • 58
      • Greece
      HP dv7-7000ev Bios Dump
      I am looking for a HP dv7-7000ev Bios Dump, might anyone have it ?
      • yashjovi
        • Nov 2011
        • 130
        Re: HP dv7-7000ev Bios Dump
        try this
        • mpikou
          • Jun 2013
          • 58
          • Greece
          Originally posted by yashjovi
          try this
          HI,
          Thanks for the reply. I just tried, it didnt work...
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            MOBO Code???
            • mpikou
              • Jun 2013
              • 58
              • Greece
              MOBO Code???
              Goya/Balen 1.0 DDR3
              11254-2
              48.4ST10.021
              Might you need other numbers, near RAM slot's?
              Also tried this without results..
              • mpikou
                • Jun 2013
                • 58
                • Greece
                try this
                I tried again, after 3rd time the screen turned on, a bar with sad flashing loads and after that restart and posted as it should be !
                So, it seems to be working!
                Now, only i must do in to insert numbers or board etc.
                • mpikou
                  • Jun 2013
                  • 58
                  • Greece
                  I have HPBQ138 utility in order to save laptop board data.
                  But at this laptop i got the following message: "Hpbq138.exe This Utility Can not Be Executed On this Platform."
                  Might you know witch utility i must use ?
                  Just used that utility and it seems to work.
                  • mpikou
                    • Jun 2013
                    • 58
                    • Greece
                    I have updated all details, but when laptop starts, i got a message with invalid information:
                    System Board (00A) - Product configuration
                    The Serial, model, and System Board CT Number are 100% correct, and UUID auto generated..
                    Might is a known issue ?
                    • imranromi
                      • Jan 2015
                      • 1290
                      • Pakistan
                      send old bios i fix serial number etc....
                      • imranromi
                        • Jan 2015
                        • 1290
                        • Pakistan
                        if you try yashjovi bios ok i build bios add series number try and reply.
                        • mpikou
                          • Jun 2013
                          • 58
                          • Greece
                          Do you want me to send a backup of the bios i am using right now and all the numbers (serial, CT, etc) ?
                          • lebana
                            • Jan 2015
                            • 81
                            • sudy
                            Thank u
                            • charif
                              • Feb 2016
                              • 28
                              • agad
                              Thank you so much
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                Thank you, working great. Programmed board info with NBDmiFit and no error on startup.
                                A working TV? How boring!
                                • gcomputers
                                  • Apr 2013
                                  • 509
                                  • Albania
                                  hi im working with this model so BURNED first mosfet PU4006 Pchannel (replaced it) but mi mistake second mosfet is PU4004 also Pchannel on schematic but i replaced first all 2 mosfet (PU4004 and PU4006) without looking PU4004 is P or N channel. with N-channel PU4004 machine start Ok but problem is PU4006 to HOT. With PU4004 P channel i have 1v on output and machine not charge is normal with 1v.
                                  • gcomputers
                                    • Apr 2013
                                    • 509
                                    • Albania
                                    any idea?
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Voltage measurement on PU4004/4006 mosfets??
                                      • gcomputers
                                        • Apr 2013
                                        • 509
                                        • Albania
                                        with Nchannel pu4004 have 19v a D+S gate 24 so normall voltage and machinre start Ok but PU4006 warm to much
                                        • DynaxSC
                                          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                                          by DynaxSC
                                          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                                          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                                          11-17-2023, 10:56 AM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          Hi everyone,
                                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
                                        • vinaypundith
                                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                          by vinaypundith
                                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                          08-03-2024, 12:32 PM
                                        • James Maxwell
                                          HP DM1-4000er Bios Dump needed
                                          by James Maxwell
                                          I badly need bios dump for HP DM1-4000er,
                                          Model: HP DM1-4000er
                                          Motherboard: DA0NM9MB6D0 REV.D
                                          Product: QJ490EA#ACB
                                          Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                          10-28-2024, 05:38 PM
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
