HP DV6-7005SP 48.4ST10.021 Goya Balen Bios Dump Needed
  • mohammed mohan
    • Nov 2017
    • 210
    • F12
    Re: HP DV6-7005SP Bios Dump Needed
    Thank you so much
    Mohammed Mohan
    • hussaka
      • Jan 2015
      • 154
      • italy
      Thank you so much
      • FrozenHaxor
        • Jun 2015
        • 266
        • Poland
        HP dv7-7072ew "Goya/Balen 1.0 DDR3 48.4ST10.021"
        Hello, I have a corrupt bios error, caps lock blinking twice. Anybody having a working dump for this MB? Tried a few from similar boards but no luck. GPU is nVidia GT 630M. Attaching dump of the corrupt bios.
        Thanks!
        • peste
          • 13924
          • ROMANIA
          Re: HP dv7-7072ew "Goya/Balen 1.0 DDR3 48.4ST10.021"
          try..bios extract site HP
          • FrozenHaxor
            • Jun 2015
            • 266
            • Poland
            Thanks!
            • zmeutz
              • Nov 2016
              • 84
              #26
              Thanks!
              I had 2 blink led caps after flash this file, I have one time blink black screen and still doesn't start...
              Anyone with this problem?
              • peste
                • 13924
                • ROMANIA
                #27
                Originally posted by zmeutz
                Thanks!
                bios extracted from HP site update ...
                • zmeutz
                  • Nov 2016
                  • 84
                  #28
                  you think it's from bios?
                  My board it's HP Goya-Balen 1.0 48.4ST10.021
                  I already write HP DV6 Goya-Balen 1.0-DDR3 11254-2 48.4ST10.021 Discerete 3rd Gen i7 2-GB Nvidia U6002 MX25L6406E-25Q64FVSIG KB9016QF A3 682170-001
                  I compare them and it says that are the same ...
                  • zmeutz
                    • Nov 2016
                    • 84
                    #29
                    finally worked ... I found a few bad caps and now it works ...
                    with new bios I get some errors
                    product name
                    product configuration
                    product serial number
                    product number
                    product family
                    system board ct number
                    how I can edit them?
                    L.E.
                    Solved with BIOS Config utility
                    Thanks!
                    • zmeutz
                      • Nov 2016
                      • 84
                      #30
                      hi!
                      does anyone know why BCU gets only 4 items from bios?
                      Code:
                      BIOSConfig 1.0
                      ;   Originally created by BIOS Configuration Utility
                      ;   Version: 4.0.32.1
                      ;   Date="2021/03/03" Time="20:11:11" UTC="2"
                      ;   Found 4 settings
                      Internal Network Adapter Boot
                      	*Enable
                      	Disable
                      Legacy Support
                      	Enable
                      	*Disable
                      Manufacturing Programming Mode
                      	*Unlock
                      	Lock
                      Secure Boot
                      	Enable
                      	*Disable
                      • peste
                        • 13924
                        • ROMANIA
                        #31
                        try this..
                        https://www.youtube.com/watch?v=9T57ktw8n3Y
                        • zmeutz
                          • Nov 2016
                          • 84
                          #32
                          same,
                          Code:
                          English
                          	Enable
                          	*Disable
                          Secure Boot
                          	Enable
                          	*Disable
                          	*Unlock
                          	Lock
                          Legacy Support
                          	Enable
                          	*Disable
                          • zmeutz
                            • Nov 2016
                            • 84
                            #33
                            Re: HP dv7-7000ev Bios Dump
                            Originally posted by imranromi
                            if you try yashjovi bios ok i build bios add series number try and reply.
                            There is any possibility to add serial number, product number, product name and all info in this bin file?
                            https://www.badcaps.net/forum/showpo...28&postcount=2
                            I tried with BCU but it doesn't get them from bios
                            Thanks!
                            • peste
                              • 13924
                              • ROMANIA
                              #34
                              Thanks!
                              try..
                              • zmeutz
                                • Nov 2016
                                • 84
                                #35
                                Hi! It’s second time when you post this video on same problem, like I said on previous post isn’t work because it doesn’t get info from bios, they are missing...
                                • hussaka
                                  • Jan 2015
                                  • 154
                                  • italy
                                  #36
                                  thank you so much . pls guys let us know which bios worked
                                  • poweron
                                    • May 2019
                                    • 371
                                    • italy
                                    #37
                                    hp pavillion dv7 bios bin
                                    hello i am looking for the bios bin of this hp dv7-7080el goya / balen 1.0-ddr3 1154-2 48.4st10.021, i can't find it
                                    Thank you
                                    • peste
                                      • 13924
                                      • ROMANIA
                                      #38
                                      Re: hp pavillion dv7 bios bin
                                      Thank you
                                      post the backup of the original bios.
                                      • poweron
                                        • May 2019
                                        • 371
                                        • italy
                                        #39
                                        Re: HP DV6-7005SP 48.4ST10.021 Goya Balen Bios Dump Needed
                                        this
                                          • 22283
                                          this
                                          Your BID is BID01818 ,use the virgin bios from post #24 ,copy the DMI from your backup and enter it into the new bios using the offsets in the picture.
                                          HxD hex editor - https://mh-nexus.de/en/hxd/
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • TacticalFahrrad
                                            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                            by TacticalFahrrad
                                            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                            06-30-2025, 04:09 AM
                                          • vinaypundith
                                            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                            by vinaypundith
                                            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                            So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                            08-03-2024, 12:32 PM
                                          • James Maxwell
                                            HP DM1-4000er Bios Dump needed
                                            by James Maxwell
                                            I badly need bios dump for HP DM1-4000er,
                                            Model: HP DM1-4000er
                                            Motherboard: DA0NM9MB6D0 REV.D
                                            Product: QJ490EA#ACB
                                            Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                            10-28-2024, 05:38 PM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
