Lg42lw450u back light and sound good. No picture.
  • Cobblers
    • Jan 2016
    • 90
    • Uk
    Hello all. Im trying to work out wether this tv is worth saving. Like the description says i have sound but no picture. I disconnected the ribbons from the t con to the lcd one a a time.
    With the lh one disconnected looking from the back i get half a screen display the other half white. With the rh ribbon disconnected i just one side of the lcd slightly darker than the other but no obvious image.
    If you need any more info let me know. Ive took pics of my tcon board and the screen from testing it. Ive search the forum and found a similar case, but the photos of the screen looked different.
  • Diah
    • Feb 2013
    • 6372
    Re: Lg42lw450u back light and sound good. No picture.
    T-CON fault, ob is repairable i dont think so, but before you start with finger touch on ices on it to check if any goes warm, if not then just reheat the big ic in the middle with hot air gun. or backing it .
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Doubt its Tcon normally panel fault which is not fixable. Wait and see what others think but 90% of the time this is not fixable.
      • Diah
        • Feb 2013
        • 6372
        Panel made by LG self, the 12 volts to turn panel on it keep on the side which had no contact with T-CON. this why it look white by no signal and the other left being white too when no signal,
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          He dissconected the one side which gave full white (half Lcd open due to other side having votage applied) but when the one side is disconnected its dragging down the Tcon there for meaning the panel is probably shorted. Not fixable IMO.
          • Diah
            • Feb 2013
            • 6372
            Take look at LG service manual this fault called Noise , replace T-CON
            • michael dranfield
              • Jan 2016
              • 232
              • England
              I have had this before , half the screen dragging down the voltage and I suspected a Leakey ceramic capacitor on the screen connecting board, but with nothing to lose and now wanting to disassemble the screen I just appiled 12 volts at 10 amps to the rail dragging down the voltage and after a puff of smoke the set came on fine, so I am assuming it was a leakey MLCC on the connecting board and it just burnt up and went o.c. but the set never came back again.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Possibly, I have seen the tab drivers fail which causes this they drag down the B+ from the Tcon causing it to shut down.
                • michael dranfield
                  • Jan 2016
                  • 232
                  • England
                  Quite right, but when you have nothing to lose and the customer says if its not worth repairing you can keep it and they will get a new one why not give it a go !
                  • Cobblers
                    • Jan 2016
                    • 90
                    • Uk
                    Ok well thanks for the advise. I will probably get a t con board aa there not too expensive.
                    I was wondering if both sides of the lcd connectors are wired the same way around so i could cross connect the lcd ribbons to see if it reverses the fault from right to left if you understand what i mean.
                    So i would connect the right hand lcd ribbon connector to the left hand side of the t con?
                    • Diah
                      • Feb 2013
                      • 6372
                      don't do this ,
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        You just going to waste money IMO seen to many not be fixable. Keep us updated.
                        • adamp91gvm
                          • Jan 2014
                          • 699
                          • uk
                          If you dont fix this ill buy the av board if its the one i need
                          • finntricky
                            • Jan 2014
                            • 449
                            • uk
                            i had the same fault with the same tv a few months back, and thought it was t-con, but no, it was a bad screen.,
                            • finntricky
                              • Jan 2014
                              • 449
                              • uk
                              i have a main board from the set here if you need it, as i stripped mine down
                              • Cobblers
                                • Jan 2016
                                • 90
                                • Uk
                                Ok so i stripped the set back a bit further. I took the screen bezel off and the metal cover from the base of the panel.
                                I found what looks like possible moisture damage well thats what it looks like to me. but also there could be a component missing.
                                So what do you all think? It is on the bad side of the screen.
                                • Diah
                                  • Feb 2013
                                  • 6372
                                  water damage, still you can try to clean it, and dry it and check all caps if no short hat, you can still stry to replace thr R , you can read it value from other line. , you will not lost any as it is scrap
                                    One of those LCD panel with tab bonding board on the bottom edge of the panel, people will spray cleaner on the screen to clean the panel and those liquids just seep do to the boards and caused problem. So it is bad panel problem as reece had indicated.
                                    • adamp91gvm
                                      • Jan 2014
                                      • 699
                                      • uk
                                      Anyone still got av boards for this tv
                                      • sordids999
                                        • May 2013
                                        • 2152
                                        • uk
                                        ive got one at the moment
                                        • dronerat
                                          Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                                          by dronerat
                                          Hi Guys,
                                          This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                                          PSU: L48S6 FHS BN44-00807D
                                          T-Con: BN95-01937A
                                          Panel: CY-GJ048HGLVLH
                                          MB: NA (Currently as the TV is assembled and forgot to take picture)
                                          As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                                          It was sent to an authorized service for repairs and returned with the...
                                          05-15-2020, 08:03 AM
                                        • koby058
                                          vostro comes up with back light but no picture
                                          by koby058
                                          Hi people!!
                                          The owner said it showed bad picture once in a while (attached)
                                          I see that there is back light but no picture.
                                          I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                          Also attached schematic and BDV
                                          LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                          07-13-2025, 01:03 PM
                                        • kca
                                          Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                          by kca
                                          Hello all ~
                                          I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                          This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                          No picture. No sound.
                                          I tested all the voltages coming out of the power supply...
                                          10-12-2023, 05:23 PM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • slimsoul
                                          Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
                                          by slimsoul
                                          Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
                                          I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
                                          I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
                                          The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
                                          03-12-2024, 03:55 AM
