Cheap eBay CPU 4-Pin Power Extensions FAIL
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    After two of these in a row melted in my friend's Server 2012 domain controller within six months (a lightly loaded self built 2U server with very good cooling based on a Xeon E3 processor) we upgraded to a higher quality cable. We cut one of the melted ones open (not pictured), and wow, it's maybe four strands of copper! What's amazing is that the wiring melted in three seperate places and at the connector. Ridiculous!
    And no, I don't use any of these on my servers, before somebody asks.
    • 31287
    Re: Cheap eBay CPU 4-Pin Power Extensions FAIL
    if your pulling serious current, you should crimp your own.
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      Worse than "Deer shit."
      Shoulda got extras and cut em open back when for "inspection."
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        was this from a china ebay seller? cuz the chinese are infamous for doing shit like that. might wanna examine your supply line to trace where exactly it came from. copper is "expensive" so they penny pinch with that as much as they can. the result? kaboom lives up to the sound of its name. (no offense meant to kaboom, the guy)
        its hard to trust stuff on ebay these days. too much chinese shit poisoning the supply lines. if it were me, i'd ghetto rewire some unused 16-18 awg ac cables and make my own cpu 4-pin extension like stj suggested. its even cheaper doing it that way... hahaha~ yea take that penny pinchers... if it still goes kaboom, i will self-terminate my own miserable existence with a 120v-240v transformer.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          yep, they came straight from china
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Wow. Was the wire 20 AWG? I'm guessing it probably didn't have any labels either. I've seen this with the really dirt-cheap PSUs.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Probably 22AWG. 20 is legal as per ATX standards IIRC.
              sigpic
              (Insert witty quote here)
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                take a magnet to those.
                wait for it......copper washed steel!
                i tossed several that came in in buggy machines.+12 ok on drive and pcie cables.
                bsod and vrm getting hot on a board that usually runs cool.
                +12 at vrm input around 7v!
                i snipped a 4 pin off a junk supply and soldered it.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Oops, that statement of mine above meant to be Was the wire even 20 AWG?
                  No way!
                  That is absolute shit!
                  I have some really strong Neodymium magnets from a car throttle control - I can pickup a screw driver with them right through my hand. Should come handy if I come across suspicious wires in the future, thanks .
                  • caphair
                    • Nov 2011
                    • 1249
                    Random curiosity, when a high current supply line is used I've noticed thick multiple thin strands of copper and other times just one thick strand.
                    Is there a difference? I imagine multiple strands allow better flexibility but other than that?
                      • 31287
                      multiple strands will need a larger diameter to handle the same current, but the advantage is flexability.
                      if the power is not DC then it's a different story and you need lots of strands anyway.
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16959
                        I havent seen that since the Clawhammer Athlon days....
                        <--- Badcaps.net Founder
                        Badcaps.net Services:
                        Motherboard Repair Services
                        http://folding.stanford.edu/
                        Team : 49813
                        Join in!!
                        Team Stats
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          To add to that...
                          Not only do you want more strands, but also have them isolated from each other. With high-frequency AC current, the electron flow moves almost entirely on the surface of the conductor. Therefore it doesn't matter how thick the wire is but rather its outer surface area size only. So to get more HF AC current through a thinner wire, the wire needs to have more and thinner strands than less strands that are thicker.
                          Just curious... why that specific time period?
                          • Sus256
                            HISENSE 65E7KQ PRO - no boot
                            by Sus256
                            Hi all!
                            HISENSE 65E7KQ PRO
                            RSAG7.820.13512 - chassis
                            MT9618BAATAB - cpu
                            RSAG7.820.12059 - power
                            HD650Y3U77 - panel
                            KLM8G1GETF - emmc
                            The TV does not turn on, the standby indicator is on. All voltages are present.
                            Emms is dead. Not readable, not detected.
                            Replaced emmc.
                            But with another dump there is no launch
                            Terminal log
                            UART
                            AC_ON
                            RPMB key is not yet programmed
                            HASH1_VERSION=0x00000000 64bit
                            E-B
                            FDE enabled
                            layout pattern onebin by SAR7,0...
                            06-01-2025, 02:11 AM
                          • myth77
                            how do you resolve problems with ebay (and other shop) scammers!?
                            by myth77
                            When i need to replace cpu or gpu or pch ...i mostly order reballed chip from china, but lately there are more broken ones then working.
                            So lately i tried with ebay "not working motherboards". I ordered a few broken motherboards from ebay but i have found out that there are many scammers on ebay. The most of them are selling already destroyed motherboards with pictures in low resolution, some of them are being scammed and just scam forwarding...
                            First board i ordered last month was ok. Cpu was dead but i could use gpu and pch. The second arrived 2 weeks ago...and it was...
                            09-02-2022, 04:53 AM
                          • dragometin
                            Hitachi 40HYC42
                            by dragometin
                            TV Model: Hitachi 40HYC42
                            Power Supply: 17IPS71
                            MainBoard: 17MB95M
                            Panel: VES400UNDS-2D-NO3
                            When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                            I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                            Is there any variants on 17IPS71 power supply's?
                            UART output pins 10 and 12 on scart connector:
                            Code:
                            12:24:04.595
                            08-08-2024, 05:53 AM
                          • Perry Babin
                            Capacitors of the same make/series that consistently fail in one amplifier while they rarely fail in a different make amp
                            by Perry Babin
                            This is for car audio amplifiers but I doubt that matters. There are amplifiers that use the same make/series capacitor as a different manufacturer and they consistently fail in one brand. In the other they are OK. The amplifiers are from the same era. Is it possible that the heating profile used when flow-soldering the boards could be the reason for the failure? If not, any ideas on what the difference could be?
                            04-03-2024, 10:40 AM
                          • remizbushka
                            Dell inspirion 5775 bios "Unlock Setup fail"
                            by remizbushka
                            Hi sirs. please help
                            Dell Inspiron 5775 bios locked "Unlock Setup fail"
                            After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                            What I did:
                            I read the bios dump.
                            Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                            03-24-2025, 09:07 AM
