Bad Ceramic in a Dell 390SFF PSU
  • cruzinforit
    Rin is my waifu
    • Apr 2015
    • 22
    This thread is also over at JG, I just posted it and don't feel like reposting it over here. We have a lot of these SFF PSUs fail the same way, this little Ceramic blows with a snap crackle and pop. Wonder what's causing them to blow.
    http://www.jonnyguru.com/forums/showthread.php?t=12806
  • linuxguru
    • Apr 2005
    • 1564
    Re: Bad Ceramic in a Dell 390SFF PSU
    That's the capacitor in the primary-side RC snubber for the main MOSFET switch. It has to be low-ESR as well as have a good surge voltage spec. If not, it will likely overheat and eventually fail. If possible, it should be replaced by an X7R or X8R ceramic with decent voltage specs (at least 1 KV or higher).
      • 31163
      i have talked extensivly about these shit psu's a long time ago here.
      the cap is 1kv and needs to be 2 or 3kv to survive.
      if it fails your in for a world of pain, the cap, the fet, the fuse, the fuseable resistor, the controller i.c. on the sub-board and a shitload of smd resistors are gonna smoke.
      • cruzinforit
        Rin is my waifu
        • Apr 2015
        • 22
        Do we happen to know if the 80plus gold variant (H240ES) of these has the same problem?
          • 31163
          no idea,
          all the ones i'v seen are H240AS
          • cruzinforit
            Rin is my waifu
            • Apr 2015
            • 22
            Hmmm. I took one of the units to be trashed because of a bad motherboard, and replaced the motherboard. I had ordered a new capacitor for it. But then I realized this is an 80plus gold unit, the H240ES. I want to make sure to fix it pre-emptively if it's still a problem, since I'm using it now as my HTPC.
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • Akhlz001
              Dell Pro 13 Plus PB13250 Bios Unlock
              by Akhlz001
              Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
              09-20-2025, 07:15 PM
            • master3112
              Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
              by master3112
              I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
              Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
              The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
              07-29-2025, 01:55 PM
            • F R 2568
              Dell Latitude 5420 does not start (no post) need help to find the reason why
              by F R 2568
              Hello all,
              this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
              I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
              If the laptop is only connected to the AC adapter (battery removed):
              When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
              The power/battery...
              01-08-2025, 05:45 AM
            • diamon
              Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
              by diamon
              I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
              Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
              Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
              Pictures of these boards:
              Dell Latitude 5520 https://www.ebay.com/itm/256052956663
              Dell Latitude 5530 https://www.ebay.com/itm/125844181534
              Dell...
              02-28-2024, 12:51 PM
