Bad Ceramic in a Dell 390SFF PSU
  • cruzinforit
    Rin is my waifu
    • Apr 2015
    • 22
    This thread is also over at JG, I just posted it and don't feel like reposting it over here. We have a lot of these SFF PSUs fail the same way, this little Ceramic blows with a snap crackle and pop. Wonder what's causing them to blow.
    http://www.jonnyguru.com/forums/showthread.php?t=12806
  • linuxguru
    • Apr 2005
    • 1564
    Re: Bad Ceramic in a Dell 390SFF PSU
    That's the capacitor in the primary-side RC snubber for the main MOSFET switch. It has to be low-ESR as well as have a good surge voltage spec. If not, it will likely overheat and eventually fail. If possible, it should be replaced by an X7R or X8R ceramic with decent voltage specs (at least 1 KV or higher).
      • 31213
      i have talked extensivly about these shit psu's a long time ago here.
      the cap is 1kv and needs to be 2 or 3kv to survive.
      if it fails your in for a world of pain, the cap, the fet, the fuse, the fuseable resistor, the controller i.c. on the sub-board and a shitload of smd resistors are gonna smoke.
      • cruzinforit
        Rin is my waifu
        • Apr 2015
        • 22
        Do we happen to know if the 80plus gold variant (H240ES) of these has the same problem?
          • 31213
          no idea,
          all the ones i'v seen are H240AS
          • cruzinforit
            Rin is my waifu
            • Apr 2015
            • 22
            Hmmm. I took one of the units to be trashed because of a bad motherboard, and replaced the motherboard. I had ordered a new capacitor for it. But then I realized this is an 80plus gold unit, the H240ES. I want to make sure to fix it pre-emptively if it's still a problem, since I'm using it now as my HTPC.
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
              Dell Thunderbolt Firmware
              by SMDFlea
              Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
              Some models have a choice of 2 different firmwares, it depends on the dell SKU.
              The SKU is in brackets (****)
              EDIT: NVM65...
              01-26-2025, 06:22 AM
            • F R 2568
              Dell Latitude 5420 does not start (no post) need help to find the reason why
              by F R 2568
              Hello all,
              this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
              I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
              If the laptop is only connected to the AC adapter (battery removed):
              When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
              The power/battery...
              01-08-2025, 05:45 AM
