JVC JLC42BC3000 screen froze on "JVC" logo.
  • Langston
    • Oct 2015
    • 16
    Hi, I'm trying to repair the logic board " 3642-1302-0150 " on my JVC LCD tv. I'm looking for any help possible. I've repaired another in the past by mailing off the logic board but I'm more interested in learning how to repair it myself. I have the back cover removed, multi-meter, pencil, paper, and a double shot of espresso ready in hand. I do not see any puffed capacitors or burn marks. Currently the screen lights up and the JVC logo sits in the screen. No buttons work and TV only powers down if I unplug it. Where should I start? Thank you in advance-
    Langston
  • Langston
    • Oct 2015
    • 16
    Re: JVC JLC42BC3000 screen froze on "JVC" logo.
    Attached pictures-
      http://www.shopjimmy.com/catalogsear...VC+JLC42BC3000
      There are at least two fuses on that main board that I can see, also Voltage regulator ICs that you need to check.
      Pictures provided by shopjimmy.
      Read the link below my signature on how to test and report the readings that will be easy for us to understand.
      BTW, the main board is made by AMTRAN which is the same company that makes board for VIZIO which has history of bad Voltage regulators 1117 series. This JVC is just a rebadged.
      • Langston
        • Oct 2015
        • 16
        Langston
        Thank you budm. I assume the fuses your talking about are F1 and F2?
        F1=5.28VDC on both sides of gold terminals
        F2=12.29VDC on both sides of gold terminals
        These are the voltage regulators that I located, there may be more that I'm not seeing.
        1084-VI= 5.22VDC VO=3.28VDC GND=2.05VDC (U5)
        1117 #U9: In=5.23VDC Out=3.28VDC ADJ=2.02
        1117 #U3: In=5.26VDC Out=3.29VDC ADJ=2.04
        949D32: In=12.25VDC GRN=0.00 Out=5.04 (U17)
        Also (U5) 1084 only has 2 of the 3 pins attached to the board. I've attached a picture showing this. the voltage on the detach and on the solder point are both the same. It may be designed this way.
        Here are the voltages for the 14 pin connecter:
        VBR_B - 3.22VDC - Orange
        Status - 0.0VDC - Red
        On/Off - 2.63 - Brown
        On/Off - 3.18 - Black
        12V - 12.27 VDC - White
        12V - 12.27 VDS - Grey
        12v - 12.26 - Purple
        GND - 0.01VDC -Blue
        GND - 0.01 VDS - Green
        GND - 0.01 VDC - Yellow
        GND - 0.01VDC - Orange
        5.2VSB - 5.8 VDC - Red
        5.2VSB - 5.29 VDC - Brown
        5.2VSB - 5.28VDC - Black
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8206
          you have an ESR meter or an oscilloscope to check the caps?
            "5.2VSB - 5.8 VDC - Red" This one is probably an error because the other two are the same.
            Your Voltages look normal but I do not know what the status pin is should be HIGH or LO for normal operation, right now it is sitting LO.
            • retiredcaps
              • Apr 2010
              • 9271
              One ebay seller sells a service to repair the main board with exact symptoms. OP might want to send an ebay PM asking what part is replaced? Eeprom? main IC?
              http://www.ebay.com/itm/252044041215
              Shopjimmy, when searching for 3642-1542-0150 returns, (possibly an eeprom problem)
              http://www.ebay.com/itm/251317871119
              Caps on main board still could be bad and have too much ripple which might have caused the eeprom to go corrupt?
              --- begin sig file ---
              --- end sig file ---
              • retiredcaps
                • Apr 2010
                • 9271
                Vizio also has numerous eeprom problems.
                • Langston
                  • Oct 2015
                  • 16
                  Thanks everyone for the replies. After doing some more digging it seems it most likely is an eeprom issue. I called shop jimmy to try and purchase one but they do not carry them. They also said given the symptoms its most definitely an eeprom. I think I see several eeprom's on the main board but I'm not sure. Is there a way to test them to see which is faulty? Do I just start shooting in the dark and replacing one by one? Is there a inexpensive reliable source for these? Thanks again!
                  D-
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    maybe send these a email see if they do one for your main board
                    http://www.ebay.com/itm/EEPROM-FOR-J...item3a814cdf0e
                    • Langston
                      • Oct 2015
                      • 16
                      Thanks! I sent them a message this morning. Is it possible to test an eeprom with a multi-meter?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        not that i know of? they store user data etc, so come pre programmed etc although some times you can re programme them yourself.
                        • Langston
                          • Oct 2015
                          • 16
                          I was able to talk to Ablemantv but as suspected this is how they make a living and he is not willing to tell me the solution. Also they do not sell an eeprom for this tv. I really don't want to give up but Im running out of options..
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8206
                            try to freeze the eeprom (can of air upside down) and turn the TV on. See what happens...
                            • Langston
                              • Oct 2015
                              • 16
                              Your on to something! I first tried freezing the eeproms (or what I think are the eeproms) and no luck so in frustration I sprayed the entire board plugged it in and the logo went away and it went on to "no signal" and worked perfectly. I used the power off button and it turned off normally. No again it is stuck on the Jvc logo. I tried to isolate the problem by freezing in sections and trying to turn it on but no luck. What could this mean? Thanks!
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8206
                                an eeprom MAY work again if cooled good enough. That trick doesn't work on every eeprom, but it does work on a large percentage. You can apply that trick too on a bad eeprom that you want to read out and then program a new eeprom with the retrieved data. So you don't need to go ".bin" hunting.
                                • Langston
                                  • Oct 2015
                                  • 16
                                  I've isolated the area to this corner of the board near the HDMI inputs. Still can't pinpoint the exact problem. If I freeze individual components it doesn't boot but if I freeze the whole corner it boots and works properly. Any idea what component would be fixed by freezing on this corner?
                                  See attachement-
                                    I wonder if the HDMI chip is locking up the processor. How hot does the chip get?
                                    • Langston
                                      • Oct 2015
                                      • 16
                                      Thanks budm, Which is the HDMI chip in the picture you provided from shopjimmy? Also what is the round (capacitor??) CE39?
                                        U18 (80-PIN IC), what is the P/N as printed on the top of the IC?
                                        CE39 is the SMD lytics cap.
                                        • abajor
                                          A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                                          by abajor
                                          Having this very weird issue.
                                          The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                                          I swapped with a working screen from an A2141 waiting for parts.
                                          The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                                          The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                                          04-27-2024, 01:37 PM
                                        • reformatt
                                          Macbook Air M2 A2681 Kernel panics after screen replacement
                                          by reformatt
                                          Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
                                          It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
                                          07-31-2025, 08:37 PM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • Yolojays
                                          HP Zbook Flash Screen Logo question
                                          by Yolojays
                                          Hello everybody,
                                          I cleared the Bios password on a HP ZBook 15u G3 Laptop (i5-6200U​) using HPUnlocker tool. My question is, the laptop has a Custom Boot Logo and can't find a way to restore it to the original HP logo. Anyone by chance know a way to do it?
                                          What I tried and checked:
                                          -No custom logo option in bios
                                          -updating the bios did not help
                                          -Hp client management library method id not work
                                          -ereplogo utility di not work
                                          Thanks in advanced....
                                          03-15-2024, 10:04 AM
                                        • jake-b
                                          dell e6540 boots to black screen (no dell logo)
                                          by jake-b
                                          good morning all,
                                          i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                                          01-08-2024, 10:29 AM
