JVC JLC42BC3000 screen froze on "JVC" logo.
Re: JVC JLC42BC3000 screen froze on "JVC" logo.
Usually the bad cap will have high ESR when it is cooled and the ESR will go lower when it is heated up.
So right now it is a matter of pin pointing the bad part/s which is not easy when the board is crowded with parts.
There are parts on the bottom side of the board also.Never stop learning
That looks like to be switching power supply or switched Power MOSFET, and those two are the filter caps, they look like to be 22uF 16V.
Can you read the P/N of that 8-pin IC?Last edited by budm; 10-09-2015, 11:17 PM.Never stop learning
Nand Flash.
Were you able to do pin point cooling?Never stop learning
Thanks, I'm doing my best to try and only cool the Nand flash. I taped the surroundings off but i'm sure its not 100% pin point. If I purchase a Nand flash is it a simple re-install or do I need to load it somehow with info? Sorry I'm very new to electronics.Comment
ISTM that the NAND flash IC would contain the firmware for the TV. Therefore you would need to copy its contents.
If the problem is indeed the flash IC, then ISTM that it may be affected by bad blocks. One way to recover from this would be to update the firmware, but that would require access to a factory utility.
Edit: AISI, the NAND flash contents would be copied to SDRAM at bootup, and program control would then be transferred to the code in SDRAM. The SoC would not need to access the NAND flash again until the next boot. This means that the TV should keep running without issue after it has booted. If this is indeed what is happening, then that would point to the flash as the culprit.Last edited by fzabkar; 10-20-2015, 02:34 PM.Comment
Edit: AISI, the NAND flash contents would be copied to SDRAM at bootup, and program control would then be transferred to the code in SDRAM. The SoC would not need to access the NAND flash again until the next boot. This means that the TV should keep running without issue after it has booted. If this is indeed what is happening, then that would point to the flash as the culprit.Comment
I found one for sale-
https://secure.m.newegg.com/ShoppingCart
Is it a simple de solder and re solder? How do I program the nand flash? Thank you!Comment
I'm confident that the NAND flash IC is the problem, but I don't have much experience in repairing flat panel TVs, so I'm hoping that someone will provide a second opinion.
That said, if you decide to replace the chip, then you will need a chip reader/programmer to read it and copy it. The following article shows you what might be involved:
https://cdn.badcaps-static.com/pdfs/...c21b9c088a.pdf
It might be worth considering a different brand of NAND as a replacement (eg Samsung, Intel, Micron), but you will need to ensure that it is compatible.Comment
Thanks for this thread. I found the bad NAND chip using the freeze spray method and then I just cut to the chase, and sent the board to Ableman tv in Vancouver and they replaced the chip and updated the firmware. It works great, and I didn't have to buy a programmer for a one time job etc.Comment
I have recently discovered this old but very helpful discussion. I hope that somebody more knowledgeable than me is still watching! I want to remove the main CB from the TV, which has the "stuck on JVC logo" problem. I have figured out how to disconnect all cables from the board, except one, a tiny ribbon cable, second from the bottom on the left side of the CB, as one looks at it from the back of the TV. The connector on the CB has a black part (the one farthest from the cable), which seems permanently attached to the CB, and a white part (the one closest to the cable). I thought that the white part is a plug that I could pull straight out, but I do not see how it can separate from the black part of the connector. Should it? Or should I pull the tiny ribbon cable itself out of the connector?? I want to post a photo, but I do not yet know how to do it.
Thank you in advance for any help.Comment
Thank you RJ. No, it's another connector. I'll post a photo as you suggest. Hm, I uploaded the photo, it tells me it's an attachment, but I do not see it here as part of my message! I'll click "submit" and see if it shows up. If it does not, I'll try to figure out what I am doing wrong. Sorry for my ignorance. I am really new to all this.Comment
Well, since I did not know how to disconnect that little ribbon cable (see last posting), but I wanted to try to fix the "stuck at JVC logo" problem, I carefully turned the main CB upside down and rested it on a soft foam slab. (I had tried all the things recommended on this site, but nothing made the TV turn on normally. However, I had noticed that the capacitances of CE1 and CE22 on the main CB were unsteady with no power applied to the TV. I was aware that one cannot measure capacitance reliably while the cap is in circuit, but I thought I would give it a shot, since nothing else worked.) I replaced those 2 caps (it was hard to remove the old solder!). Beginner's luck: The TV turns on and off like a charm!!
Does anybody know what those caps are doing and why, if one or both are bad, the "stuck on JVC logo" problem will occur?
On the attached photo, the CE1 cap is circled. The CE22 is just to its left. Their nominal values are 220 uF/16V and 220uF/25V.Comment
They are filter caps for the 5V and the 12V power suppliers, you should check the caps on the power supply board too.
According to post #4
F1= is for 5V power supply
F2= is for 12V power supplyLast edited by budm; 06-19-2019, 09:47 AM.Never stop learning
Thank you, budm. I will when I have the opportunity to open the TV up again.
I have difficulty identifying the three components that are attached to the relatively large heat sink on the upper right quadrant of the PSU (please, see photo). I copied their labels and tried to identify them by searching online. They are:
Q201: 1615AU FQPF 13N06L. Online search found this to be a MOSFET.
D201: MBRF 10U160CT 122. Online search yielded nothing!
D202: MBRF 20U165CT 104 Online search yielded nothing!
If somebody could tell me what these are and what they do, I'll be grateful. I am trying to learn.
The 3 pins of Q201 have voltages 12.28, 13.15, and 14.47, but I am not experienced enough to tell which pin is the Source, which the Drain, and which the Gate.
Similarly, I cannot tell which pin is the Base, which the Emitter, and which the Collector for D201 and D202. (I assume that they are diodes, because JVC uses the symbol D for such.)
I measure strange voltages relative to the metal back of the TV for D201 and D202.
For D201: Pin 1: -0.06V, Pin 2: 13.15V, Pin 3: -0.06.
However, the voltage between Pins 1-2 is 2.8 - 3.2 V (i.e., it varies!), and that between Pins 2-3 is 2.6 - 3.4V (also variable). I feel lost.
For D202: Pin 1: -0.05V, Pin 2: 2.27V, Pin 3: -0.05V.
The voltage between Pins 1-2 is 5.30 V (steady), and that between Pins 2-3 is 5.33V (steady).
Thank you in advance for any help with this.Comment
https://www.shopjimmy.com/vizio-0500...t-inverter.htm
Looks to be your power supply board.
Q201 () is the power MOSFET, it is used as a switch to provide switched 12V when PS-ON control signal from maia board is present.
D201 is the common Cathode diode, it is used for providing switched 12V.
D202 is the common Cathode diode, it is used for providing 5.2 VSB.
Look at the bottom of the board and you can easily see how those parts are connected and for what they are for if you have basic knowledge of electronics.
Are you 100% sure that the P/N you see on the diode is correct? Can you take good clear pictures?
MBRF 10U160CT
MBRF 20U165CT
Example of MBRF diode:Last edited by budm; 06-20-2019, 09:54 AM.Never stop learning
by abajorHaving this very weird issue.
The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
I swapped with a working screen from an A2141 waiting for parts.
The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by YolojaysHello everybody,
I cleared the Bios password on a HP ZBook 15u G3 Laptop (i5-6200U​) using HPUnlocker tool. My question is, the laptop has a Custom Boot Logo and can't find a way to restore it to the original HP logo. Anyone by chance know a way to do it?
What I tried and checked:
-No custom logo option in bios
-updating the bios did not help
-Hp client management library method id not work
-ereplogo utility di not work
Thanks in advanced....-
Channel: BIOS Requests ONLY!
by jake-bgood morning all,
i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other... - Loading...
