New soldering station/setup!
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    I originally used the kit that my old work had, a Weller WD1 station. That one was 85W, and was a great iron so I wanted to get something similar.
    I finally got around to buying this one, a Weller WD1002. Very similar but this one is 95W. It works like a dream. This thing does not care how big any joint is!
    Also got the same but new desoldering pump. I know some people like it, but I am not a fan at all of desoldering wick.
    Got all my regular tools as well, and then moved them over to that desk, which I got for free! The computer (which I'm on now) is the "research" and "play music" workstation. It's a sleeper too. That's an actual desk-top chassis made in November, 2000, with a Haswell Pentium 3.00GHz, 4GB RAM, 120GB Intel 530 Series SSD, and a recapped KME PSU. This one: https://www.badcaps.net/forum/showpo...2&postcount=13
    I plan on getting more tools, and doing tons of soldering
  • c_hegge
    • Sep 2009
    • 5219
    Re: New soldering station/setup!
    Nice. I still use desoldering braid. I'd love to get myself a decent desoldering pump or gun one day, but I'm using my soldering iron less and less nowadays.
      • 31281
      put hellerman sleeve on the end of the pump.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Nice station!
        Hey, I am trying to do some plumbing in the house. Do you think I can use your station for a bit?
        By the way, does it use 900M or T12/T15 tips? Just curious, because it does look a bit like 900M tips, and I personally have never been as satisfied with them as with T12/T15. Then again, I've only used cheap 45W and 65W Weller/Hakko clones with those, so maybe thats' why.
        I've used that desoldering pump before. Probably the most powerful you can get. Definitely works well.
        Me neither. It never seems to work on multi-layer boards... and that's what I work on like 80% of the time. I only find braid/wick useful for BGA cleaning / rework.
        On the other hand, used braid makes for great SOT-223 and TO-252 heatsinks. Got a hot 1117 regulator somewhere? Or perhaps an Intel-style "hands-in-the-air like you don't care" free-standing CPU VRM MOSFETs?
        -No problemo! Just solder some used braid onto their tabs and you get a really good heatsink. Not to mention it's a good way to recycle waste copper that way .
        Wow, that is a sleeper indeed. Must be pretty zippy with that SSD.
        Cool.
        I'm working on a little "project" right now. Not sure when it will take off... if at all, since it's still in experimental stage. But if it does, I think you will be the first to give one to, or at least give you instructions how to make it. After all, you work on a lot of PSUs, so I think you will find it handy .
        By the way, is that bag full of resistors all minimum load resistors from PSUs?
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Nice station!
          I'll have to check when I get back in town. Either way, I'm very pleased with the functionality of it. It only came with the one tip though, and it can be a little too big for some joints. Definitely going to get a smaller one the next time I do a Digi-Key order.
          Yes, I absolutely love it. Can you believe I got it brand new in the packaging for $8.99 with free 2 day shipping across the country?
          That's exactly how I feel. Yeah it's less messy but not worth it in my opinion.
          I actually did some mixing up a week ago. I ended up putting that Pentium II machine in that chassis ( https://www.badcaps.net/forum/showthread.php?t=46856 ) and then put the SSD machine in an emachines chassis from 2005
          Awesome I'm very interested in what you're "cooking up" all the way over there.
          It sure is
          • armini
            18VDC PSU completely dead - ZD-915 desoldering station
            by armini
            Hi everyone!
            Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
            Due to a lack of time, I set it aside and didn't look at it.
            Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
            According to replies in 18VDC PSU has dropped to...
            04-25-2023, 07:49 AM
          • chth96
            What soldering station should I purchase for 900M-TJ-I tip?
            by chth96
            hello.
            A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
            https://ko.aliexpress.com/item/4001275635593.html
            Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
            Any reply would be appreciated.
            11-24-2023, 05:08 PM
          • caprider
            Recommendations of quality soldering station and (separate) hot air station
            by caprider
            Hey,
            I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
            I now have a TS100 and some soldering irons and looking for some better tools.
            1. Soldering station, budget around 200-240€
            JBC BT-2BWA seems to be a good product in the budget.
            2. Hot air station, budget around 200€
            Up to now I've found ATTEN ST-862D to be a good option....
            01-15-2022, 02:05 AM
          • mkbehbeh
            KSGER C245 Soldering station PSU 220V only?
            by mkbehbeh
            I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
            I am...
            04-17-2023, 03:11 PM
          • Peter_1402
            Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
            by Peter_1402
            Hi Everyone,
            I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
            1. Soldering iron works great
            2. There is a burnt mark on the hot air gun handle.
            I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
            Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
            Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
            Reed switch tested ok with a magnet.
            From the above test, I can conclude...
            07-12-2025, 11:50 AM
