Dell p28f 3537 LA-9982P bios need
  • mehmood muhaish
    • Sep 2013
    • 37
    • pakistan
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: Dell p28f 3537 LA-9982P bios need
    can you upload your BIOS dump?
    • dspok
      • Jan 2014
      • 553
      • Nepal
      save your bios and use attached one.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        here
        Im Back... sort of...
        • mehmood muhaish
          • Sep 2013
          • 37
          • pakistan
          Thanx.i try then i report u
          • narinder
            • Jun 2015
            • 1
            • India
            Originally posted by ala_borbe
            here
            thank you for bios
            • dilip.pawar31
              • Nov 2014
              • 59
              • india
              thanks............thanks A lot.......
              • balu457157
                • Oct 2015
                • 19
                • India
                is inspiron 5537 Also refer the same bios?????????
                • nassimhamdi
                  • Feb 2016
                  • 150
                  • algeria
                  thank you so much
                  • Nasir Raja
                    • Mar 2014
                    • 21
                    • United Kingdom
                    Cheers thanks a lot for sharing:-)
                    • iris61
                      • Oct 2016
                      • 2
                      • türkiye
                      thanks friends
                      • techwizard
                        • Feb 2015
                        • 16
                        • Malaysia
                        thanks
                        • techwizard
                          • Feb 2015
                          • 16
                          • Malaysia
                          this is the schematic
                          • fsc2003
                            • Mar 2015
                            • 30
                            • turkey
                            thanks very much
                            • indu
                              • May 2015
                              • 30
                              • srilanka
                              thanks
                              • LUKMAN
                                • Dec 2016
                                • 3
                                • india
                                V good help
                                • abbas_govani
                                  • Jul 2013
                                  • 89
                                  • India
                                  hey guys,
                                  can any one tell me what should be +VCHGR. Or how much volt should be on pl701 ?
                                  m having 13.5v.
                                  thanks in advance.
                                  • smali
                                    • Sep 2014
                                    • 287
                                    • Pakistan
                                    Originally posted by abbas_govani
                                    hey guys,
                                    m having 13.5v.
                                    thanks in advance.
                                    if your battery is connected then its depend on your battery voltage..and the charging voltage be continuously rising on multimeter if your charging section is ok....and if your battery is not connected it may be 2 or 3 volatge showing.
                                    • Attif
                                      Attif
                                      • Dec 2016
                                      • 49
                                      • pakistan
                                      thanks bro
                                      • rohitmc6
                                        • Feb 2016
                                        • 3
                                        • nepal
                                        Thanks soo much.
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          Dell 9010 MT BIOS Update Always Fails
                                          by mikeybass
                                          Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
                                          04-23-2025, 04:30 PM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
                                        • Akhlz001
                                          Dell Pro 13 Plus PB13250 Bios Unlock
                                          by Akhlz001
                                          Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                                          09-20-2025, 07:15 PM
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          10-28-2025, 07:49 AM
