Replacing KZG's
  • DarkInferno
    • Feb 2015
    • 23
    • United Kingdom
    Replacing KZG's
    I posted in the asus-mobo forum a few day ago and received no response so I thought I'd re-ask in here as I'm unsure if I've asked the wrong questions or in the wrong place.
    I have a ASUS IPIBL-LB running an intel xeon e5450.
    It has started to hang... and then recover after a while.
    It has 13 KZG's on it, one of which has bloated/vented.
    Having read on here that KZG's are not the best I have been searching for a replacement for all of them.
    (again, excuse the typo of KZG/NZG)
    reading on here has got confusing with a lot of suggestions for caps that I just don't seem to be able to get, or to go poly.
    I can't seem to find any electrolytics that match the kzg specifications available... Closest I've got is :
    NCC KZG 16V 1000uF KZG16VB102M8X20LL 8x20mm esr-0.021 ripple-1,870
    Wrong ESR - Ripple
    RUBYCON ZLH 16V 1000uF 16ZLH1000MEFC8X20 8x20mm esr-0.029 ripple-1500
    Panasonic FR 16V 1000uF EEUFR1C102L 8x20mm esr-0.030 ripple-1560
    Wrong Size -ESR and Ripple still out (by less)
    RUBYCON ZL 16V 1000uF 16ZL1000MEFC10X20 10x20mm esr-0.023 ripple-1820
    I'd certainly interested in polys for replacing the caps right next to the northbridge, they practically touch the heatsink.
    If I do go poly, do I go with the same ESR and change the capacitance or try to find the closest match???
    There seems to be different advice depending on what its for... I assume the caps (that look like polys?) round the cpu and are next to the pci-e slots are for the vrms?
    anyway this really isn't my area... I know enough to worry about getting it wrong...
    So.. any advice please?
    • 31170
    Re: Replacing KZG's
    rubycon MBZ
    1870ma
    0.019 esr
    • DarkInferno
      • Feb 2015
      • 23
      • United Kingdom
      Re: Replacing KZG's
      they do seem to fit the bill regarding esr and ripple. (esr and ripple are an exact match for 5/6)... I'd seen them suggested on here but as I can't find them for sale anywhere, I'd discounted them.
      Googling for them only seems to bring up the news of their discontinuance, ebay amazon and ali-express.
      Any help with sourcing these or finding other suitable caps?
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Re: Replacing KZG's
        What about 10mm diameter caps? The board does not look that cramped...
        You can use Suncon WX then (formerly Sanyo)
        1000uF 16v 0.023Ω ESR 1.82A Ripple
        Or even better Suncon WG if you can find them, but the fact of the matter is that most manufacturers are switching more and more of their production over to solid polymer caps...
        • DarkInferno
          • Feb 2015
          • 23
          • United Kingdom
          Re: Replacing KZG's
          thanks...not in rs or farnell....
          how would I go about identifying suitable replacement polymers?
          or a source of any ultra low esr capacitors that supplies the UK?
          The only ones i've found so far are farnell and I could have some 1000uF nichicon hm... US stock... £0.94 for the capacitors... almost £20 shipping and handling, and that's not even dealing with the actual faulty capacitor, only 5 of the 13 KZG's on the board. They don't have any lower capacitances listed even though they are in the range.
          I'm currently searching through old boards to see if I have anything that would go in... if only just to replace the puffed up 820uf for now so the board doesn't die while I source the caps to recap the board.
          • mockingbird
            • Dec 2008
            • 5484
            Re: Replacing KZG's
            For the 5 16V 1000uF on the VRM high that are 8mm in diameter, you can also use 16V 270uF polymer caps. As for a source for low cost capacitors in Europe, please PM me.
            If you want an updated BIOS for your board, since you're using a Harpertown Xeon, please find one attached to this post, with updated 45nm microcodes (5.43).
            There is also the possibility of updating certain option ROMS, but I'm not sure if this board allows enabling AHCI in the BIOS or not, but if it does, LMK, and I'll see what I can do.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Re: Replacing KZG's
              You can try www.elfa.se
              It's where I source caps that I need fast in Sweden, they do offer reasonable shipping in Europe.
              The cap I listed in my previous post has their partno: 67-234-07
              • DarkInferno
                • Feb 2015
                • 23
                • United Kingdom
                Re: Replacing KZG's
                I have AHCI listed in my bios but I haven't used it yet I was going to use it when I get my ssd, but thats been put on hold since it has been playing up.
                Right... I've just cannibalised a few old motherboards that I've been keeping for.... some reason.... I kept all the caps that I thought I'd heard on here, I have :
                Fujitsu Yellow and black FP?
                5 x 4v 560uf
                Rubycon MBZ
                3 x 16v 1800uf
                12x 6.3v 1500uf
                Nichicon HM
                3 x 10v 2200uf
                2 x 6.3v 1800uf
                Nichicon HD
                4 x 16v 1200uf
                and a Panasonic FJ 6.3v 820uf
                Any of those any good? other then the Panasonic the seem too large but I'm going to have a look through some datasheets.
                  • 31170
                  Re: Replacing KZG's
                  the fujitsu's are polymer!
                  • DarkInferno
                    • Feb 2015
                    • 23
                    • United Kingdom
                    Re: Replacing KZG's
                    would they safely go in the place of of my 820s though? I thought they were too low voltage... but I don't know if they would likely be on 5 volt or 3.3... or lower?
                    • mockingbird
                      • Dec 2008
                      • 5484
                      Re: Replacing KZG's
                      No, what you have won't work. The KZG on the VRM high are 8mm. What you have are all 10mm. Check your PM.
                      • DarkInferno
                        • Feb 2015
                        • 23
                        • United Kingdom
                        Re: Replacing KZG's
                        the fujitsus and all the rubycon 6.3v's are 8mm..
                        • mockingbird
                          • Dec 2008
                          • 5484
                          Re: Replacing KZG's
                          Yes, but you can't use them to replace the 6.3V 820uF KZG because you're not sure whether those caps are sitting on a 3.3V or 5V rail. As for the single 16V 470uF KZG by the PCIe slot, it is definitely on the 12V rail.
                          You can't use the 8x20mm 6.3V 1500uF caps because the VRM high is 12V.
                          • mockingbird
                            • Dec 2008
                            • 5484
                            Re: Replacing KZG's
                            DarkInferno -
                            If you're interested, you can order these parts locally from Farnell that are suitable replacements, the catch being that these capacitors are "awaiting delivery". This way you shouldn't have to pay exorbitant shipping for the US stock.
                            1) 16V 1000uF, 8x20mm, UCC KZG
                            this, or this.
                            2) 6.3V 820uF, 8x11.5mm, UCC KZG
                            this, or this, or this.
                            3) 16V 470uF, 8x11.5mm, UCC KZG
                            this
                            • DarkInferno
                              • Feb 2015
                              • 23
                              • United Kingdom
                              Re: Replacing KZG's
                              Thanks a lot, I had looked at them I didn't notice that they were awaiting delivery but as I haven't seen or know anything about wurth elektronik (I'm possibly showing myself up there) so I'd practically discounted them...
                              • DarkInferno
                                • Feb 2015
                                • 23
                                • United Kingdom
                                Re: Replacing KZG's
                                Having a look at wurth caps.. the 470 you gave was 10mm? Had a look on RS and they have stock of wurth caps.
                                Would it be possible for you to check these are sensible before I buy please.
                                270μF 16 V 8x8mm
                                820μF 6.3 V 8x8mm
                                470μF 16 V 8x11.5mm
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  Re: Replacing KZG's
                                  So it was. Sorry about that.
                                  Looks good to me.
                                  Go for it.
                                  Wurth Elektronik seems to me to be a re-brander, so they mght not be Japanese polymers, but they should do the job.
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    Re: Replacing KZG's
                                    I have no clue if they are good or not. I do know that Wurth makes inductors... actually I never knew they made (or "made") capacitors!...
                                    Muh-soggy-knee
                                    • DarkInferno
                                      • Feb 2015
                                      • 23
                                      • United Kingdom
                                      Re: Replacing KZG's
                                      So.... recapped
                                      Seems stable... I have ran IntelBurnTest on Very High stress level and it passed.
                                      Currently have FurMark running and all seems fine.
                                      Is there any way of specifically loading up the board to induce failure if the caps are not up to par?
                                      • mockingbird
                                        • Dec 2008
                                        • 5484
                                        Re: Replacing KZG's
                                        Good job.
                                        Try OCCT. That's the most strenuous benchmark I've ever seen.
                                        Don't forget to update the BIOS microcodes. If you run Harpertown on this platform, you'll miss out on some CPU features.
                                        Here's what my Harpertown looks like in CPU-Z after a microcode update:
                                        Using a very similar board to yours (Asus P5B).
