Corsair SP2500 parts information required
  • lexwalker
    • Feb 2011
    • 307
    • Malaysia
    Have a Corsair SP2500 power supply board currently under repair, but unfortunately at least two SMD components (R930 resistor and C937 capacitor) has burned to beyond recognition. The main power uses UC3843G I.C with AUK SMK1060 MOSFET driving the transformer. Does anyone here have some information regarding the values of those parts?
    The resistor, to my best guess is either around 10K Ohms or 20K Ohms. Could also be either 1k Ohms or 2.2k Ohms as well (from the usual smaller power supplies using UC3843 I.C I've came across but those are around 45W only).
    As for the capacitor, it looks like a C0G/NP0 type judging by the grey color and looks to be at least 1kV rating judging by the size (around 1206 metric).
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Corsair SP2500 parts information required
    Did you try cleaning the resistor with IPA - sometimes works.
    There are a few diagrams in google images for the UC3843 I.C
    do any of those help?
    • lexwalker
      • Feb 2011
      • 307
      • Malaysia
      Already done that, unfortunately most of top label area on that resistor has been destroyed. Can only see a tiny bit at one corner, looks the edge of the number "3", although can be another number altogether.
      The main cause of the failure is, again, degraded glue which literally fully oxidized some through holes all the way to the bottom (can see clearly from the first picture posted, at the top left there are two solder pads next to each other which were severely oxidized), and literally dissolve leads on the discrete components on the top side. The degraded glue on this board looks shiny with tiny specks of what looks like a sea of crystals or salts, which is very different from usual degraded glue I've came across. To potential buyers, avoid buying this speaker system...
      • lexwalker
        • Feb 2011
        • 307
        • Malaysia
        Here are a few pictures after some degraded glue cleanup (and still in the process of clearing the board of this awful stuff). It ate into the resistor lead, and can see the greenish-blue oxidized stuff in that hole (whatever was left of the lead). Same goes with the lead on the ceramic capacitor in the 3rd picture...
          • 31170
          i may be able to help, but you need to tell me how the parts connect.
          i have a 450w supply with the same chip i need to re-cap this week.
          same chip, but it's a different board.
          • lexwalker
            • Feb 2011
            • 307
            • Malaysia
            I've also have lots of schematics for the same I.C, including those around 230W (which is this speaker's power supply's rating). However none look that similar. Anyway, here's a partial schematic, still tracing most of the circuit. Other faulty parts found are a 12V zener diode (with markings "H2" in SOD123 package) and an unknown transistor. This transistor has the marking "CAGR" which I could not find any reference to. Not sure if the "..GR" is the date code either as the letters are together (as a single 4-letter code). The closest would be BCW61AR which has the markings "CA" for SOT23 package. This one is a difficult part to find, and other sites have suggested BCW30, BC860C and BCX71H as replacements...
            Those marked in red boxes are all found to be faulty. Those capacitors with "?" is because they are SMD type, and as usual no markings at all. Currently looking for R930 and C937...
              • 31170
              CAG = 2sa1980s-g in my book
              • lexwalker
                • Feb 2011
                • 307
                • Malaysia
                As with BCW61AR also. Unfortunately that 2SA1980S-G is not sold on RS Component and Farnell/Newark/element14, thus will be looking for equivalent and/or compatible alternatives. Any recommendations?
                As for the burnt resistor and capacitor, any information or make a guess as to the values of those components?
                My current guesstimates are...
                - R930 is either 10K or 20K
                - C937 is either 1nF or 10nF
                • lexwalker
                  • Feb 2011
                  • 307
                  • Malaysia
                  For that capacitor, I found the largest C0G/NP0 with 1206 package and at least 1kV rating, is 1nF in capacitance. As for the resistor, it still un-decided yet...
                  But for that "CAGR" transistor, will go for BCX71H based on the following datasheet. Unfortunately could not find the A or G version, thus the H version looks to be closest (with overlapping hfe range)...
                  • ouroboros
                    • Aug 2014
                    • 11
                    • Finland
                    R930 has 103 written on it and C937 has no markings on my board. If i was to measure that cap, wouldn't i have to remove it from the board first? If not then i'll measure it for you tomorrow with my ESR60
                    • ouroboros
                      • Aug 2014
                      • 11
                      • Finland
                      I tried to measure C937 for you, but i would have to remove it from the board. Which i won't be able to do.
                      • lexwalker
                        • Feb 2011
                        • 307
                        • Malaysia
                        10K was one of my guesses and looks like I was right. Thanks a bundle, mate..
                        If you do not have any hot air soldering equipment, then you could try de-soldering one of the transformer pins (as this capacitor is parallel to the transformer).
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          The capacitor probably is in the pF range, as the transformer operates at a high frequency, so I wouldn't expect it to have significant capacitance.
                          In the picture "C32", You should also check the large resistors which are standing near the heatsink. Also, it looks like one of the through hole resistors has a burnt spot on the top. (The one next to the 220K resistor)
                          (Oh, and is that a yellow Lelon capacitor?! Never seen a yellow one before!)
                          Muh-soggy-knee
                          • ouroboros
                            • Aug 2014
                            • 11
                            • Finland
                            Did that and my meter showed 0,2nF for the C937.
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Did you zero your meter first? just having the probe wires closer together, when measuring this low of a capacitance, can have quite an effect on the reading you get.
                              Muh-soggy-knee
                                C937 and C? are part of the snubber circuit so the value have to be so that the ringing voltage will exceed the break down voltage of the MOSFET.
                                Typical value for the Gate-Source resistor is 10K.
                                • ouroboros
                                  • Aug 2014
                                  • 11
                                  • Finland
                                  I used 37XR-A and i followed it's manual and it didn't say anything about zeroing. But i did put the leads together before measuring...
                                  • lexwalker
                                    • Feb 2011
                                    • 307
                                    • Malaysia
                                    Thanks! Sounds like 220pF, a little smaller than expected (for high power output unit) but will try that value.
                                    Yups, I did use 10K. However for the capacitor, I used 1nF instead. Was working very well, but then it suddenly blew again after about an hour. Took out the PWM I.C (again) and one 10 Ohm resistor driving the MOSFET, plus possibly a signal diode as well (that 1N4148). Not sure if the MOSFET has failed though as there are no shorts detected between the pins. I think the current sense resistor survived since it measured OK, and was using a 5W one instead of following the original 2W resistor (that failed)...
                                    Already known that. Check one of my earlier posts above, the one with the schematics.
                                    Pretty busy at the moment (repair work overload), thus some delays in replies (and also did not post much here lately)...
                                    • ouroboros
                                      • Aug 2014
                                      • 11
                                      • Finland
                                      Could you measure the resistance between positive and negative of connector CN101 for me? it's on the amplifier board...
                                      • ouroboros
                                        • Aug 2014
                                        • 11
                                        • Finland
                                        nevermind the above, found the short that caused the problem and got it working.
                                        • Sephir0th
                                          DELL XPS 15 9560 - No VCore, Power Off after few seconds
                                          by Sephir0th
                                          Hello Community,
                                          i'm troubleshooting this one since days and actually i'm really lost because i believe i'm Missing the required experience for an issue Like this...
                                          It is a Dell XPS 15 9560, i7-7700HQ, GTX1050 Board Number LA-E331P Rev 1.0, Most similar to LA-C361P so i use this Schematics.
                                          Issue: Starts and shuts Off after a few Seconds. Basic Troubleshooting (Adapter,RAM,BIOS/EC Flash from alisaler) of course already done, which didn't Changed anything.
                                          I have another working Board with i5-7300HQ and GTX1050, with It's Help i can compare...
                                          05-09-2021, 11:22 AM
                                        • narf
                                          Epson EB-U42 projector / Caps with 0.7 ohms ?!
                                          by narf
                                          hi all,
                                          first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                                          i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                                          what i've found so far:
                                          - the PSU does its job and supplies 12V to the mainboard via the connector.
                                          - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                                          - not far away, there's the first cap with a resistance of 0.7 ohms....
                                          07-02-2024, 03:53 PM
                                        • Mark D
                                          Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                                          by Mark D
                                          The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                                          10-29-2024, 03:15 PM
                                        • h0m3w0rk
                                          Random Shutdowns/Startup Failure with Corsair SFX 450
                                          by h0m3w0rk
                                          I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                                          For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                                          02-09-2025, 03:19 AM
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
