Ansmann battery chargers - cheap Chinese junk or German quality ?
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    My Ansmann energy 4 started arching and smelling strange last weekend while charging 4 AA batteries, having a look inside made me think Ansmann bought it from a very cheap Chinese factory.
    Nerver heard of Samcon, Natcon or Chang capacitors before, Ansmann for sure saved a few bucks buying low quality parts.
    The to220 heatsink looks like a mess.
    One of the springs has come loose, springs are used instead of soldered wires to connect the powersupply to the wall contact.
    Even though these springs sit stationary it has somehow come loose,they do not move even when changing wall contact type.
    Also, look hook how dirty the board is.
    Lots of flux left, buying Ansmann you don't get cleaned boards.
    This is the spring that caused arcing.
    This picture show better how dirty the board is, it looks like 'fine sand' that is stuck in the flux residue.
    Topside of logic board looks nice.
    Underneath you can see a few manual touchup jobs on some chips from the factory.
    The Ansmann kids at this factory has been playing with white paint.
    But wait there is more too see, Ansmann struggles with their quality.
    Paying top $ does not give you quality products.
    Had I bought this on Ebay I for sure would think I bought a cheap copy but since I got this from Rs Components I would think this is a genuine Ansmann product and that it reflects the quality of Ansmann products.
    Pretty sure a charger from ebay or dx will be same or better quality.
    Any comments more then welcome.
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Ansmann battery chargers - cheap Chinese junk or German quality ?
    Never had this model but I do have all the others. LOL
    All ANSMANN products are made in China, and the failure rate of their chargers is not that high either.
    I have open and repair some of them.
    Their PCB and all internals was ok.
    Damage can occur in the Mains inverter due Mains over-voltage spike or capacitor failure.
    Other reason could be trying to charge damaged NICAD in which the charging never ends and PCB gets cooked by high temperature.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5008
      • New Zealand
      Had not heard of them before. It is not uncommon for 'good' companies to outsource to China and sell crap.
      At first I thought it was a knockoff from http://www.assmann-wsw.com/en/products/ who sell connectors but I guess not.
      -David VanHorn
      • mariushm
        • May 2011
        • 3799
        It really doesn't look that bad. yes, the capacitors are so-so, especially that 85c capacitor, but otherwise the layout looks good, they use nice components, current sensors for each battery, good microcontroller.
        The spring can be replaced with a wire.. just scrape the insulation over that copper trace and solder a wire.
        The "dirty" on the boards is just flux that wasn't cleaned properly.
        I'm puzzled about that lead that goes into the heatshrink of the fuse... what's the lead for, what component, where does it go?
          It is the lead of the spring, the two springs are used for making contact to the AC PLUG L and N. He should check and see if that fuse is still good.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Yes I don't like the springs.
            Also, in a short circuit or overload, the springs could heat up and cause a fire hazard, along with the fuse's cover being poked by the spring lead.
            Muh-soggy-knee
            • Gabriel
              • Jan 2010
              • 620
              • Norway
              A few more pictures
              Spring lead is almost touching metal end of fuse on the right side in this picture.
              Fuse still ok.
              budm is spot on, the lead is the spring end - took a few more pictures for you to see.
              Hehe reminds me off Kramers licence plate.
              Everyting can fail I guess, I just thought that Ansmann would be better quality - I have noticed this charger is quite warm and that it sometimes gives me error charging Ansmann 9V batteries.
              • Gabriel
                • Jan 2010
                • 620
                • Norway
                Have you tried the MH-9000 from Powerex ?
                I see you have the powerline 4 pro I was thinking to buy but I think I will not choose Ansmann again.
                • Kiriakos GR
                  Banned
                  • May 2012
                  • 940
                  • Greece
                  Powerline 4 pro is their latest, and cost about 35 EUR retail.
                  At that price point of Ansmann, Powerex sales have been exterminated in Europe.
                  I am not here to influence your thoughts, but as consumer to consumer I will say that few things can go wrong when you have two years warranty in Europe.
                  • Gabriel
                    • Jan 2010
                    • 620
                    • Norway
                    New 9V battery charger, still looking for a new AA and AAA charger.
                    Charges 7.2V,8.4V and 9.6V perfect for my metall detector.
                    • Gabriel
                      • Jan 2010
                      • 620
                      • Norway
                      Having a look inside the Powerex C490F.
                      Looks very clean, I like that the 9V contacts is a attached directly to the board instad of using springs as Ansmann did.
                      The two biggest electrolytics caps are made by Jackcon, the one in the left corner is a Fuhjyyu sadly.
                      Very nice layout, no mess and very clean.
                      Looks splendid.
                      Comes with wall charger and 12V vehicle charger.
                      For charging 9V batteries Ansmann uses these 4 springs that connect to ..
                      ..these
                      ..so you can fit batteries here.
                      • Gabriel
                        • Jan 2010
                        • 620
                        • Norway
                        Sent a mail to Ansmann.
                        Hi
                        I bought a energy 4 and it started to arching and smell, looking inside your build quality is not the best using low quality capacitors and these quite useless springs for AC plug.
                        I uploaded some pictures of my defective unit for you to see.
                        https://www.badcaps.net/forum/showthread.php?t=36645
                        Does all your energy 4 units use the spring solution for AC plug ?
                        As you can see the spring almost make contact with the metal end of fuse, have you changed this in newer build of the energy 4 or does all energy 4 units have this problem ?
                        And Ansmann reply.
                        with this device (which is out of production for a few years) we had no complaints about the springs or the capacitors.
                        Best regards
                        • Rulycat
                          • Apr 2010
                          • 724
                          • United Kingdom
                          The guy doesn't seem to understand that you're making the complaint!
                          • kaboom
                            "Oh, Grouchy!"
                            • Jan 2011
                            • 2507
                            Originally posted by Gabriel
                            And Ansmann reply.
                            Best regards
                            Just like Antec "never had complaints" about their StupidPowers?
                            "pokemon go... to hell!"
                            EOL it...
                            All style and no substance.
                            guilty,guilty,guilty,guilty!
                            guilty of being cheap-made!
                            • dalek1967
                              Chinese made 12v 6 amp lead acid battery charger info
                              by dalek1967
                              I posted another thread like this for a TV power supply. This is for information purposes for anyone who has a bad one and wants to repair instead of replace. There is no model number on these but internally they appear to be the same, fan being the only difference I can find. If a component is damaged and can't be identified, this may help. One I have has the brand name XinJieBao on the front above the display. The other isn't marked.
                              My impressions. I can't say for sure on the chips and such but the HV capacitor is a very low quality one if I think. I tried to google it and also...
                              05-10-2023, 12:42 AM
                            • Petr0x
                              Bosch 12V and 18V chargers modification
                              by Petr0x
                              Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                              You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                              Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                              05-24-2024, 01:00 PM
                            • DXseekerMO
                              Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                              by DXseekerMO
                              Hello everyone!
                              Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                              I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                              Yes
                              0%
                              1
                              All backlight strips are the same quality
                              0%
                              1
                              No
                              0%
                              0
                              12-16-2021, 03:58 PM
                            • valente222
                              help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
                              by valente222
                              Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
                              05-12-2025, 03:42 PM
                            • Topcat
                              Nihon Kohden (Tyco Electric) ET2400LM 24" Restoration
                              by Topcat
                              This was rescued from a recycle gaylord from a hospital along with some other things....
                              I don't have to explain the significance of restoring this; 16:10 Aspect Ratio, 1920x1200; very high end Samsung LTM240CT04 panel. Add in it's blonde (will pair nice with a retro rig) and also ELO touchscreen. It is very well made, very heavy. Even used these are hard to find and expensive....but it had some problems...
                              Problem one, the external PSU was missing. I found one in my stash that had the correct voltage (12V) with the goofy 4-pin plug it used. It however was light on the...
                              08-02-2023, 10:07 PM
