USB chargers that give more than 5V?
  • Tom41
    • Oct 2005
    • 339
    • England
    I recently bought a portable label printer with a USB port that allows you to charge the internal battery. It comes with a USB-A to Micro-USB cable, but no charging plug. A sticker next to the charging port says "Warning! Do not use adapter with voltage over 5V!"
    Thing is, are there any USB chargers that give out more than 5V, and in what situation would that be used? Just to be on the safe side I used a multimeter to measure my chargers - one is giving out 5.11V, the other is giving out 4.9V. The warning sticker suggests the printer doesn't have any overvoltage protection circuit, which could be a nasty surprise for someone...
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • m1ch43lzm
    • Mar 2019
    • 1033
    • Peru
    Some mobile phone chargers with USB-A port do have multiple output voltages, example: Qualcomm Quick Charge 2.0/3.0 or other competing standards before USB PD was standardized among phone manufacturers
    Check the label of your charger if it lists multiple output voltages
    At least on QC2.0/3.0 chargers they start at 5V, when a compatible phone is connected it negotiates higher voltage, can't speak for other "fast charge" standards
      • 31283
      all usb chargers are 5v -even QC types are 5v unless they recieve commands to up the output.
      the real thing to watch is the current.
      how much does the printer need?
      most cheap chargers are 1A, old ones from companies like samsung, nokia etc arent even that much sometimes.
      widgetinstance 457 (Related Topics) skipped due to lack of content & hide_module_if_empty option.
