List of pin compatible Laptop ICs
This is a sticky topic.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    In the spirit of this, i propose a list of compatible laptop chips.
    Here's one to get you started:
    Richtek RT8206 = Intersil ISL6236
    Have just performed a replacement of a RT8206M with a ISL6236IRZ in a Fujitsu Lifebook AH531 which had no power. No 3.3v or 5v standby present, no shorted mosfets, no other damage to the board. LDO 5v was present, but no output. Replaced and it fired right up.
    A working TV? How boring!
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    Re: List of pin compatible Laptop ICs
    Here.
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      to support the idea >
      Toshiba L500 froze during bios flash
      i couldn't program bios neither with willem nor cheap SPI programmer
      replaced Winbound W25Q16B with W25X16 and it worked
      must be fauly eeprom
      Im Back... sort of...
      • mohamed.mostafa
        • Sep 2012
        • 40
        • egypt
        Originally posted by whaldsz
        Here.
        thanks
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Yes, faulty eeprom/flash chips are common.
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            Rt8206b = tps51427 = isl6237
            isl6236 = rt8206a = pm6686 = sn0608098 = max8778 max17101 max17020
            • spidey
              climbs
              • Dec 2012
              • 644
              • Cyprus
              SOIC8 interchangeability chips
              32 Mbits (these chips are equivalent and interchangeable)
              A25L032M-F AMIC
              AMIC A25L032M-UF
              MX25L3205DM2 Macronix
              EN25F32-100H EON
              W25X32VS WINBOND
              WINBOND W25Q32VS
              SST25VF032B SST
              16 Mbits (these chips are equivalent and interchangeable)
              A25L016M-F AMIC
              AMIC A25L016M-UF
              MX25L1605DM2 Macronix
              EN25F16-75H EON
              EON EN25F16-100H
              -75H EN25D16 EON
              EON EN25D16-100H
              W25X16VS WINBOND
              WINBOND W25Q16VS
              SST25VF016B SST
              8 Mbits (these chips are equivalent and interchangeable)
              A25L080M-F AMIC
              AMIC A25L080M-UF
              MX25L8005M2 Macronix
              EN25F80-75H EON
              EON EN25F80-100H
              W25X80VS WINBOND
              F25L008A-50PA ESMT
              ESMT F25L008A-100Pa
              SST25VF080B SST
              4 Mbits (these chips are equivalent and interchangeable)
              A25L040M-F AMIC
              AMIC A25L040M-UF
              MX25L4005AM2 Macronix
              EN25F40-75H EON
              EON EN25F40-100H
              W25X40VS WINBOND
              F25L004A-50PA ESMT
              ESMT F25L004A-100Pa
              SST25VF040B SST
              • sanehdeep2012
                • Oct 2013
                • 139
                • india
                can anybody help me to get laptop BGA ALTERNATE LIST
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  It's been posted on here a while back. Search for g86-630 in the forum and you will find it.
                  • masud
                    • Jul 2011
                    • 317
                    • Bangladesh
                    very useful things
                    • degutji
                      • Dec 2012
                      • 173
                      • Indonesia
                      Anyone knows MAXIM 8744E / 8745 cross reference ?
                      Thk's
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Found this one with all the nVidias:
                        http://web.archive.org/web/202110260...rchangeability
                        Last edited by piernov; 09-30-2022, 03:58 AM. Reason: replace broken link with archive
                        • sanehdeep2012
                          • Oct 2013
                          • 139
                          • india
                          THANKS Th3_uN1Qu3
                          Thanks for your helpfull reply
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1490
                            • portugal
                            isl 51120 compatible with wich ?
                            • dj_ricoh
                              • 2073
                              • uk
                              can you put a 8 mb bios chip where was a 4mb?
                              • vvacl
                                • Jun 2012
                                • 22
                                • VietNam
                                Originally posted by th3_un1qu3
                                in the spirit of this, i propose a list of compatible laptop chips.
                                richtek rt8206 = intersil isl6236
                                have just performed a replacement of a rt8206m with a isl6236irz in a fujitsu lifebook ah531 which had no power. No 3.3v or 5v standby present, no shorted mosfets, no other damage to the board. Ldo 5v was present, but no output. Replaced and it fired right up.
                                rt8206 = isl6237 = tps51427a (not isl6236)
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1490
                                  • portugal
                                  dj ricoh , you can't , even if it all the same shit thru SPI , but the size in MB must be exact due to adressing
                                  • lezsimply
                                    The Wanderer
                                    • 657
                                    • Philippines
                                    are there any substitute for tps51123 besides rt8223m? like from maxim? thanks
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1490
                                      • portugal
                                      51123 can be replaced by 51125
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1490
                                        • portugal
                                        max 8731ae , wich one can be compatible ?
                                        • Deby
                                          List of compatible laptop motherboards
                                          by Deby
                                          This is a list of compatible laptop motherboard information that I have been collecting for some time.
                                          And it's still ongoing.
                                          Every time I come across information that a board is compatible with another, I write it down.
                                          Anyone who wants to, can continue to expand the list.
                                          Packed in the rar, is an excel table that has additional information.
                                          Motherboards.rar...
                                          05-31-2024, 04:34 AM
                                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                          09-06-2024, 09:30 PM
                                          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:47 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                          Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:11 AM
