hp g6 failure
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    hp g6 failure
    HP G6 failure series
    allready solved plenty board of this type with the same issue .
    just a small resistor which lose connectivity at it power line
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    Re: hp g6 failure
    where is this resistor? label?
    • dycc
      Vision
      • Nov 2011
      • 625
      • Côte d'Ivoire
      Re: hp g6 failure
      only for ROCKY2 Huron River Platform MV Build
      check R1053(1Mohm) connectivity with V15A
      • whaldsz
        • Apr 2013
        • 395
        • Philippines
        Re: hp g6 failure
        Ah ok, without it there will be no +V3S, +V5S, +V1.5S. Thank you for sharing.
        • Francisco.s
          • 686
          • Spain
          Re: hp g6 failure
          Could you please share this schematic?
          • dycc
            Vision
            • Nov 2011
            • 625
            • Côte d'Ivoire
            Re: hp g6 failure
            Here
            https://www.badcaps.net/forum/showth...ighlight=hp+g6
            • Francisco.s
              • 686
              • Spain
              Re: hp g6 failure
              Thanks.
              • robrock1
                • Jul 2013
                • 129
                • Ghana
                Re: hp g6 failure
                my board is a different type from yours its nearly the same but components are different numbers but i still resoldered all the resistors but not working. i have 3.3v 5v and 5 v but still dead i think is from the chipset.
                • dycc
                  Vision
                  • Nov 2011
                  • 625
                  • Côte d'Ivoire
                  Re: hp g6 failure
                  What is your board code
                  • whaldsz
                    • Apr 2013
                    • 395
                    • Philippines
                    Re: hp g6 failure
                    Voltage of SIO chip at pin 112, pin21, and pin23 before and after power switch on? They should be high after power switch is on.
                    Also check INTRUDER#, RTCRST# and SRTCRST# pins if high.
                    • surajndsbadcaps
                      • Dec 2013
                      • 5
                      • nepal
                      Re: hp g6 hwpg power failure
                      HP g6 system power (3.3v and 5.0v) is perfect but still set does not power up. When I pressed the power button then i got the 3.3v in PL23 and 5.0v in PL20 still this board does not power up. There is no hwpg in pin no 14 of the ene kb3930qf a1. So, i replaced the OK tested power ic (tps 51123, pu3) and ok tested ene kb3930 too. but still same case as above. So, anybody post about solution................
                      I need hwpg (hardware power good) voltage help...........
                      • kandyan
                        • Mar 2013
                        • 53
                        • Sri Lanka
                        Re: hp g6 failure
                        I hv same problem in G62 board. all other voltages are ok but HWPG. nothing came out from HWPG. Anyone got a clue about this problem?
                        • dj_ricoh
                          • 2073
                          • uk
                          you need to reprogram BIOS
                          Caps key blink?
                          • mazloum
                            • Sep 2012
                            • 504
                            • Lebanon
                            Re: hp g6 failure
                            hi
                            can you help me please to fix it?
                            thanks
                            • jinu_j
                              Dell 2209WA - power supply - Fusible Resistor replacement
                              by jinu_j
                              Hi
                              I am trying to repair an ancient Dell 2209WA Monitor which suddenly shut off with a pop sound. On investigation found that one of the fusible resistors had blown. Further investigation identified multiple components as faulty because of which the fusible resistor blew. Please refer the attached circuit diagram showing the components that were found to be damaged.
                              1. FR950 - blown fusible resistor - 0.2 Ohm 1W
                              2. Q950 - shorted Q950 MOSFET - 650V 10A N Channel Mosfet
                              3. R835 - Blown Resistor - 20KOhm SMD resistor
                              4. D930 - Shorted Schottkey Diode...
                              05-03-2025, 10:51 PM
                            • mikey5791
                              Need help to replace burned resistor in 350w atx psu
                              by mikey5791
                              Hi to all forum members,
                              Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                              The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                              Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                              Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                              12-26-2024, 04:55 AM
                            • npielawski
                              MacBook Pro late 2016 (820-00239) with multiple failure modes.
                              by npielawski
                              I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                              I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                              10-15-2025, 01:53 AM
                            • MidnightRoller
                              Can a resistor lose resistance after hot air?
                              by MidnightRoller
                              I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                              I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                              02-02-2022, 11:46 PM
                            • artvandalai
                              What resistor ohm will work better to repair this waterpik?
                              by artvandalai
                              The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                              01-05-2025, 04:10 PM
