hp g6 failure
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    hp g6 failure
    HP G6 failure series
    allready solved plenty board of this type with the same issue .
    just a small resistor which lose connectivity at it power line
    __________________
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    Re: hp g6 failure
    where is this resistor? label?
    • dycc
      Vision
      • Nov 2011
      • 625
      • Côte d'Ivoire
      Re: hp g6 failure
      only for ROCKY2 Huron River Platform MV Build
      check R1053(1Mohm) connectivity with V15A
      • whaldsz
        • Apr 2013
        • 395
        • Philippines
        Re: hp g6 failure
        Ah ok, without it there will be no +V3S, +V5S, +V1.5S. Thank you for sharing.
        • Francisco.s
          • 686
          • Spain
          Re: hp g6 failure
          Could you please share this schematic?
          • dycc
            Vision
            • Nov 2011
            • 625
            • Côte d'Ivoire
            Re: hp g6 failure
            Here
            https://www.badcaps.net/forum/showth...ighlight=hp+g6
            • Francisco.s
              • 686
              • Spain
              Re: hp g6 failure
              Thanks.
              • robrock1
                • Jul 2013
                • 129
                • Ghana
                Re: hp g6 failure
                my board is a different type from yours its nearly the same but components are different numbers but i still resoldered all the resistors but not working. i have 3.3v 5v and 5 v but still dead i think is from the chipset.
                • dycc
                  Vision
                  • Nov 2011
                  • 625
                  • Côte d'Ivoire
                  Re: hp g6 failure
                  What is your board code
                  • whaldsz
                    • Apr 2013
                    • 395
                    • Philippines
                    Re: hp g6 failure
                    Voltage of SIO chip at pin 112, pin21, and pin23 before and after power switch on? They should be high after power switch is on.
                    Also check INTRUDER#, RTCRST# and SRTCRST# pins if high.
                    • surajndsbadcaps
                      • Dec 2013
                      • 5
                      • nepal
                      Re: hp g6 hwpg power failure
                      HP g6 system power (3.3v and 5.0v) is perfect but still set does not power up. When I pressed the power button then i got the 3.3v in PL23 and 5.0v in PL20 still this board does not power up. There is no hwpg in pin no 14 of the ene kb3930qf a1. So, i replaced the OK tested power ic (tps 51123, pu3) and ok tested ene kb3930 too. but still same case as above. So, anybody post about solution................
                      I need hwpg (hardware power good) voltage help...........
                      • kandyan
                        • Mar 2013
                        • 53
                        • Sri Lanka
                        Re: hp g6 failure
                        I hv same problem in G62 board. all other voltages are ok but HWPG. nothing came out from HWPG. Anyone got a clue about this problem?
                        • dj_ricoh
                          • 2073
                          • uk
                          you need to reprogram BIOS
                          Caps key blink?
                          • mazloum
                            • Sep 2012
                            • 499
                            • Lebanon
                            Re: hp g6 failure
                            __________________
                            hi
                            can you help me please to fix it?
                            thanks
                            • jinu_j
                              by jinu_j
                              Hi
                              05-03-2025, 10:51 PM
                            • mikey5791
                              by mikey5791
                              Hi to all forum members,
                              12-26-2024, 04:55 AM
                            • MidnightRoller
                              Can a resistor lose resistance after hot air?
                              by MidnightRoller
                              I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                              I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                              02-02-2022, 11:46 PM
                            • artvandalai
                              What resistor ohm will work better to repair this waterpik?
                              by artvandalai
                              The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                              01-05-2025, 04:10 PM
                            • chth96
                              Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                              by chth96
                              I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                              Since then, This AC/DC adaptor have been out of order.
                              But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                              After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                              And Is there any possibility that it will suddenly explode as well as to be out...
                              12-03-2023, 04:40 AM
