Sony Bravia KDL-32BX300 No Standby Light
  • 1beertap
    • Mar 2009
    • 219
    I received this TV from a co-worker in order to fix. He claims that the TV got hit by lightning. The unit has no standby light turned on but the power supply does have standby voltage of 3.3v. I am thinking that the main board has a problem. Any ideas?
  • capkid
    • Oct 2010
    • 1339
    Re: Sony Bravia KDL-32BX300 No Standby Light
    Do you have any other voltages? I'm trying to think through this: Is anything different if you disconnect the main board from the PSU?
    LG Plasma Mal-Discharge Correction Service
      There are two yellow fuses on the power supply board by the white connector that goes to the main board, are they OK?
      You should download the service manual:
      http://elektrotanya.com/?q=showresul...oria=&kat2=all
      • 1beertap
        • Mar 2009
        • 219
        main board plugged in
        STBY = 3.3v
        ACOFFDET = 2.0V
        POWERON = 3.28V
        everything else = 0v
        main board unplugged
        STBY = 3.3V
        ACOFFDET = 3.29V
        POWERON = 0V
        • 1beertap
          • Mar 2009
          • 219
          Both fuses check good
          • 1beertap
            • Mar 2009
            • 219
            Hey guys, any other ideas?
            • philliesfan30m
              • Aug 2013
              • 542
              do the wires that go to the standby light attach to the main board through the side power panel?
              • philliesfan30m
                • Aug 2013
                • 542
                here is the schematic for this tv.
                • philliesfan30m
                  • Aug 2013
                  • 542
                  oops bud already posted 1 for your tv
                    OK, on page 29 of the service manual, report the voltage reading of ALL the pins of CN6401/6402/6403 when TV is plugged in and not turn on ( in standby mode) and when TV is powered on by the power switch. Black probe on the chassis, all the boards are connected together.
                    • 1beertap
                      • Mar 2009
                      • 219
                      Okay, here's what I tested.
                      CN6401
                      1 STBY3_3V = 3.3V
                      2 AC OFF DET = 2.0V
                      3 POWER ON = 3.28V
                      4 AUDIO_12V = 0V
                      5 AUDIO_12V_GND = 0V
                      6 REG12V_GND = 0V
                      7 REG12V_GND = 0V
                      8 REG12V = 0V
                      9 REG12V = 0V
                      10 BL_ERR = 0.05V
                      11 BL_ON = 0.04V
                      12 DIMMER = 0V
                      13 NC = 0V
                      14 T-CON_VCC_12V= 0V
                      15 T-CON_ON = 0V
                      CN6402
                      1 UNREG24V = 0V
                      2 UNREG24V = 0V
                      3 UNREG24V = 0V
                      4 UNREG24V = 0V
                      5 UNREG24V = 0V
                      6 GND = 0V
                      7 GND = 0V
                      8 GND = 0V
                      9 GND = 0V
                      10 GND = 0V
                      11 BL_ERR = 0.05V
                      12 BL_ON = 0.04V
                      13 NC(ADIM) = 0V
                      14 DIMMER = 0V
                      CN6403
                      CONNECTOR NOT USED
                      When I attempt to turn the unit on, the readings are still the same. Even though it does have a standby led and power led, both remain off at all times. The power button does work and is connected to the main board. The led indicators are connected to the main board via a separate connector from the buttons. Thanks guys and hope this helps.
                        OK, you have power supply board problem, it is getting the PS_ON (Power ON) but the 12V, 24V are not coming on. BUT, one voltage should change state, POWER ON = 3.28V, it should be below 1V when TV is powered OFF and 3.28V when Power switch is activated, if it does not change state, that mean the main board is also stuck on, so you may also have main board problem.
                        • xredhawk
                          • Jul 2011
                          • 103
                          i hear alot of problems with bad eeproms
                          • anmol
                            • Mar 2012
                            • 73
                            • India
                            disconnect socket from remot control board and check power on with keypad.
                            wbr
                            • chapulin
                              • Sep 2013
                              • 1
                              • mexico
                              since you do not have 12 volst you should check the circuit cxa
                              • dcapper
                                • Dec 2013
                                • 496
                                I have the same tv and replaced the power supply. It was a no go. It's the mainboard. I'm almost sure of it. I think you have the same issue.
                                • anmol
                                  • Mar 2012
                                  • 73
                                  • India
                                  @ dcapper,
                                  you have try as post #14 ?
                                  wbr
                                  • dcapper
                                    • Dec 2013
                                    • 496
                                    Originally posted by anmol
                                    @ dcapper,
                                    wbr
                                    I'll check mine tonight. I bought a new power supply and it didn't work, so I'm willing to go on a little faith.
                                      dcapper, are you getting the PS_ON signal to the power supply board?
                                      • dcapper
                                        • Dec 2013
                                        • 496
                                        No. I ordered a new mainboard today for $50.00
                                        • brithepi2k
                                          Sony KD-65XE8596 no standby light
                                          by brithepi2k
                                          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                          cheers...
                                          09-06-2025, 02:22 PM
                                        • SkishyIshy
                                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                          by SkishyIshy
                                          Hey All,
                                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                          03-17-2021, 11:44 AM
                                        • androripara
                                          Sony Bravia 55HX820 - 4 times blinking red standby led
                                          by androripara
                                          i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
                                          I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
                                          Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
                                          10-19-2023, 05:16 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • JUCaESAl
                                          Sony bravia KD-65AF9
                                          by JUCaESAl
                                          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                                          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                                          10-20-2025, 04:03 AM
