Polaroid FLM-3232 Dead 24V Rail
  • martyparish
    • Dec 2012
    • 313
    Hello good people,
    I have acquired this Polaroid FLM-3232 from freecycle. 2006 model.
    The symptoms:
    Red stand by comes on when plugged in, then blue ON led comes on upon hitting power button. All seems normal at this point but back lights never come on.
    When in stand by, there is 24V present on C2 connector. This apparently is stand by power(odd right?). The pins are not labeled unfortunately but I know the far left pin is PS_ON and confirmed it's working properly. (jumps to 5V when hitting power on)
    Caps all "look" fine and half of them are rubycon, other half look like Lelon(crap right?). I don't have an ESR meter.
    C3 is the back light feed and it never comes up when powered on. I've tried with and without it connected to inverter.
    Moving forward, I tested the main filter cap and it's 173V in stand by and 170V when powered on. This is a problem right?
    I checked various diodes and FETs best I could then I decided to check the little ICs on the back for shorts and it looks like the PFC may be shorted. I could use some help from you guys to determine if this PFC is indeed my problem.
    The IC is L6561D and the pins 4(CS) is dead short to ground.
    I've attached images of front and back of PSU. IC in question is circled.
    Thanks in advance for any insight!
    Edit: I just realized I put this in the wrong forum, sorry guys. If a mod sees this, could you move it over to the TV forum please?
    Re: Polaroid FLM-3232 Dead 24V Rail
    The current sensing (CS) pin is connected to the Low Ohm Source resistor (<1 Ohm resistor)? That can be the reason it is showing short. If you look at page 6 of the spec sheet, you will see example circuit and it is connected to 0.31 Ohms Source resistor.
    Can you also post 1/4 section pictures of the board, top side and bottom side?
    • martyparish
      • Dec 2012
      • 313
      Hi Bud thanks for jumping in! Yes, I was looking at that schematic and thinking the same as you stated. Maybe it wasn't a dead short but just low reading after all. I'll check that again to be sure.
      Let me know if these pics are satisfactory. I labeled them b_1 - b_4 and f_1 - f_4.
      I inverted the front image so that f_1 and b_1 are the same quadrant.
      Thanks again!
      • martyparish
        • Dec 2012
        • 313
        Update: I went ahead and ordered the three caps near the 24V rail. Those are Lelon brand and figured it was worth a shot for a few bucks. All the rest of the caps are Rubycon and Nichicon.
        Will post back after they arrive. (I've asked a mod to relocate this thread to the TV forum)
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          If it's got PFC and you only get 170v on the main cap, then you have to fix the PFC circuit. You should be getting around 380-400 volts when the PFC is operating.
          A working TV? How boring!
          • martyparish
            • Dec 2012
            • 313
            Thanks for the input Th3_uN1Qu3. I thought the voltage was incorrect and that it should be around 400 at some point. I will see what else I can find out when I open it back up.
              Since the L6561D which is for the PFC is not working, with board not connected to the power and the Main cap is discharged (check the voltage on the main cap) please take the resistance reading on all the pins of the L6561D against the Ground pin (pin 6) and report the reading. I have a feeling you have bad PFC IC.
              • martyparish
                • Dec 2012
                • 313
                Sorry for the delay guys. I just got my parts in and now have the TV opened back up.
                Bud, here are the results of the PFC resistance, all referenced to pin 6 ground:
                1: OL
                2: OL
                3: OL
                4: 0.7 ohm
                5: OL
                7: OL
                8: 50 ohm
                I'm going to install the caps now just for kicks but not expecting any miracles...
                Thanks again fellas!
                  Pin 8 (VCC) does not look right at 50 Ohms, the Zener diode inside the IC may be bad. I would replace the IC.
                  • martyparish
                    • Dec 2012
                    • 313
                    Thanks Bud. I will order it asap.
                    What's weird is, I replaced the three 1000uf 35V caps and tried the set but now my 24V stand by is way low and fluctuating! I've triple checked the cap install and all looks fine.
                    Originally, I had a solid 24V and the PS_ON would go to 5V when I hit power but now 24V hovers from 2-5V~. What the heck???
                      The 12v/24 power supply section need 380VDC (provided by the PFC Voltage booster) for it to run correctly, right now it is only getting 170VDC feeding it.
                      • martyparish
                        • Dec 2012
                        • 313
                        I have replaced the PFC IC and still only getting 170VDC at the large cap
                        Sorry it took so long to update you guys, it's been hectic around here.
                        I'm going to have another look at this tv today and see if I can find anything else.
                        If it is not the IC, what would be the next component to look at?
                        I want to thank you guys in advance, the help is always appreciated! I've fixed quite a few units now thanks to all the information provided here! The latest was my 22" monitor that wouldn't turn on in the morning. (bad caps of course!)
                          Check the voltage on the VCC pin8 of the PFC IC. Also check and see if you still get 50 Ohms reading on the VCC pin8.
                          • martyparish
                            • Dec 2012
                            • 313
                            It reads 50 ohms between pin 6(gnd) and pin 8.
                            I tested voltage on pin 8(Vcc) and it begins around 4.8V and slowly drops out.
                            I used pin 6 as the ground ref, is that okay?
                            Thanks again, much appreciated.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              Yes, the way you measured is correct. What i see is that you're not getting enough voltage on the Vcc pin to power up the PFC chip. That's due to the 50 ohm resistance you get from Vcc to GND, which you shouldn't be seeing.
                              I have a feeling that the old chip was okay and there's something wrong with the board. Of course, the new chip you got could be bad, but it's unlikely for it to be bad in exactly the same way. Lift the new chip off and measure on the board without the chip installed. Do you still get 50 ohms? If you do, trace the rail going to pin 8 and test all parts connected to it.
                                I should have asked him to take the resistance reading on the pads before installing the new IC.
                                • martyparish
                                  • Dec 2012
                                  • 313
                                  Awesome guys thanks for the fast replies. I'll check the resistance with chip removed, although that was a tricky task for me to install (rookie)
                                  • kerbsjacob
                                    • Nov 2011
                                    • 11
                                    Just did one of these. Had intermittent PFC failure and low voltage on big 400v cap. Same symptom, no backlight. otherwise ok.Found there was two surface mount diodes in series connected to pin 8 of pfc chip. One was cracked and had intermittent connection. I found it by re soldering all pfc circuit components on PSU. When I went to re solder it, it came apart in the middle, an I know I didn't cause it to crack, pretty sure it was the cause. It was not a visable problem before I reflowed the solder. I don't know what kind if Zener it should be, only has yellow stripe,no info on diode or board. I installed 5.1v Zener and I works, but who knows for how long. The other one in series looks the same and is 5.1 v, but others on the board look the same and are higher voltage. Cap voltage now 300 at first , but droops to 233v, but continues working.
                                    Main point , check surface mount diodes.
                                    Does anybody know what the right value is it should have? Or possibly have a working supply that could be tested to find Zener voltage of the diode?
                                    • martyparish
                                      • Dec 2012
                                      • 313
                                      Hey kerbsjacob, that's awesome and thanks for the info. What's crazy is that yesterday I was taking a hard look at these two diodes thinking one or both could be my issue. Now you come along with this info!
                                      Can you take a peek at this photo and tell me if the diodes that I circles are the ones you are referring to?
                                      Thanks!
                                      • martyparish
                                        • Dec 2012
                                        • 313
                                        It looks like kerbsjacob hit the nail on the head. I also had a broken diode connected to pin 8.
                                        I used the L6561 datasheet referenced in my first post(or budm's post) to get these part numbers. (see attachment)
                                        1N4150 (DIODE SWITCHING 50V 0.3A DO35)
                                        1N5248B (DIODE ZENER 18V 500MW DO35)
                                        Hopefully these are correct and fix my problem. I will report back when I replace them.
                                        • Nagy Daniel
                                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                                          by Nagy Daniel
                                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                          So, I generated a table with AI so I can...
                                          03-04-2025, 08:24 AM
                                        • JimMc0
                                          Gigabyte GA-H61M-USB3-B3 dead short 3.3v rail to ground.
                                          by JimMc0
                                          Hi there,
                                          I discovered this forum through a youtuber who teaches electronic repair. I've been trying to troubleshoot my dad's old PC which is a Gigabyte GA-H61M-USB3-B3 and will not power on. I discovered a dead short on the 3.3v rail at the ATX connector so I used a bench power supply to feed 3.3v into the ATX connector and sunk about 400mA into the board (I hope that's not too much!). I used a FLIR camera to identify the problem area:
                                          The chip seems to be the following, an ITE IT8892E 1108-CXS which seems to be a PCI bridge?
                                          03-27-2024, 08:36 AM
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
                                        • ktmmotocross
                                          Asus UX433FAC - batery dead after short on VIN rail
                                          by ktmmotocross
                                          Hello.
                                          Have this Asus UX433FAC that came with shorted mosfet on main power rail. After replace laptop works ok, but battery is dead. Laptop show charging but voltage on battery is 0.2V. when remove battery voltage on battery connector goes to 8.5V, but when connect battery again it goes down to 0.2V.
                                          can that short shorted battery? batmon show that battery is full at 80%
                                          12-29-2022, 12:06 PM
                                        • DXseekerMO
                                          Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                                          by DXseekerMO
                                          Hello everyone!
                                          Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                                          Symptoms:
                                          1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                                          2) TV does not appear to turn on
                                          3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                                          4) "Power on" terminal on Power Supply has 3.26v
                                          5) "A13V" terminals have 12.9v
                                          6) Stand-by test jumper on Power Supply has 12.9V
                                          7) Optical audio jack on Main Board illuminates
                                          8) With stand-by...
                                          06-09-2021, 12:19 AM
