Vizio P42 No screen
  • Ares1441
    • Mar 2013
    • 8
    Vizio P42 No screen
    I recently was given a Vizio P42HDTV10A from a friend, because it doesn't provide video any more. According to him, there was a loud pop, and then the screen went blank. From the research I've done, it would seem that either the Ysus board or the Zsus board (or both) are not working; it also seems to be a fairly common problem with this TV. The cost of replacing either board is considerably more than I would like to spend repairing the TV. I have to imagine though, that the entire board wouldn't have to be replaced. If it's simply a part on the board that I could remove, and solder a new one on, that would greatly preferred. So my questions are these:
    1. What exactly goes wrong with the Ysus/Zsus board when it malfunctions? Which parts are affected?
    2. Has anyone replaced whichever parts are needed to make the board work again? If so, please provide as much detail pertaining to the situation as possible.
    (I have soldering experience, so removing and replacing parts is not an issue. The issue is knowing which parts are in need of replacing.)
    Every bit of information and help is much appreciated. Thank you.
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: Vizio P42 No screen
    post pictures of each board! welcome to BadCaps.
    • Ares1441
      • Mar 2013
      • 8
      Here are the Ysus, Zsus, and some other boards.
      • Ares1441
        • Mar 2013
        • 8
        Here is the rest of the pictures.
        • cliff_hootarski
          • Jul 2006
          • 411
          1st check the fuses on both the Ysus and X or Zsus boards (the big boards on the left and right side of the TV as you are looking at the back of the TV). Power off (unplugged), wait for at least 5 minutes to discharge all the capacitors. I would expect the IPM modules on either board (more likely the Ysus) shorted causing fuse or fuses to blow. The IPM's are under the big heat sinks on either board. The "pop" sound is usually one of the modules going to the big electronics graveyard.
          • Ares1441
            • Mar 2013
            • 8
            Okay, I checked all the fuses. There was one blown fuse on the Zsus board.
            • Ares1441
              • Mar 2013
              • 8
              On a quick side note, I found a 54" Panasonic VT25. Would the components of that TV be able to be used to fix the Vizio?
              • Ares1441
                • Mar 2013
                • 8
                It also seems that I mislabeled the power as the zsus. This is the zsus.
                • cliff_hootarski
                  • Jul 2006
                  • 411
                  Was the blown fuse on the power supply or the Zsus? If it was on the Zsus, pull the board and check the IPM for shorts.
                  There is a tutorial on which pins to check on the Coppell TV repair blog:
                  http://blog.coppelltvrepair.com/2011...s-ipm-for.html
                  If indeed you find a short, you can replace the IPM, but it is a difficult job unless you have the right equipment.
                  • Ares1441
                    • Mar 2013
                    • 8
                    The blown fuse was on the zsus. Do you think I could pull a woking IPM off of another plasma tv?
                      You could do that, though beware these IPMs have short lifespans. That IPM may only have a few months left on it. If you get one which is from a newer generation it'll probably work much better, as I think LG fixed the issue (of course, they never told their customers and/or offered free repairs.)
                      • Ares1441
                        • Mar 2013
                        • 8
                        Alright, and are all IPM's pretty much the same? (same size/number of pins/etc)
                        • cliff_hootarski
                          • Jul 2006
                          • 411
                          Short answer...Nope. You should see a sticker on the side of the big heat sink with the number of the IPM.
                          • dib
                            • Sep 2013
                            • 2
                            • blah
                            Just wanted to say thanks for the informative post. I've had one of these on hand for some time. Picture went out but still powers on+sound. Purportedly common but little actual instruction on how to troubleshoot+fix it. I have fuses on order now so if those don't work I'll see if this helps.
                            • capkid
                              • Oct 2010
                              • 1339
                              Replacing the fuse is not going to correct your issue; you'll just end up with another blown fuse. You need to replace the aforementioned damaged IPM: http://www.youtube.com/watch?v=Y8MNQYXw8E0
                              LG Plasma Mal-Discharge Correction Service
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • spice_disc
                                Vizio TV M50-C1 reboot cycle and static on screen
                                by spice_disc
                                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                09-08-2024, 02:37 PM
                              • TheDando
                                MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 Screen Connector
                                by TheDando
                                Hey guys I've got a MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 with a broken screen connector on the motherboard.I was wondering how I would go about finding a exact replacement for it.I can't seem to find any schematics that would help me so I'm kinda stumped.I did buy a screen connector that I thought was close enough but it doesn't really invoke much confidence in me that it works perfectly as plugging the screen into sometimes does output a "glitchy" image for just a few seconds.So now I'm kinda in a cross road where I'm pretty sure it could be a faulty screen but I...
                                10-28-2024, 06:59 PM
