dell n5110 bios.bin new goooooood
  • laptop market
    • Sep 2012
    • 122
    • mansoura
    dell n5110 bios new goooooood
  • ismy4real
    • Dec 2011
    • 87
    Re: dell n5110 bios.bin new goooooood
    same here with dell N5110 any new good news
    • Tol
      • Nov 2012
      • 1
      • Kazakhstan
      : Ура: BIOS GOOD!!! Laptop works! THANK YOU!
      • bushido
        • Oct 2012
        • 32
        • japan
        what is new on this bios.bin file for dell n5110
        • polytek
          • Dec 2013
          • 496
          • TUNISIA
          bios is good laptop is working thankyou
          • crowntoy99
            • Oct 2012
            • 267
            • india
            good one .... thanks
            • bidawisoft
              • Nov 2016
              • 17
              • morocco
              tnx
              • simo
                • 27
                Thanks a lot Guys again, Dump flashed, laptop fired up.
                • lapzlapz
                  • May 2016
                  • 22
                  • kerala
                  tnks............
                  • alibisma
                    • Oct 2014
                    • 37
                    • Saudia
                    thanks its working
                    • salim deia
                      • May 2017
                      • 18
                      • algeria
                      thanks
                      • lebana
                        • Jan 2015
                        • 81
                        • sudy
                        thank u
                        • gustarom
                          • May 2013
                          • 44
                          • indonesia
                          thanks bos
                          • mahmoodgl
                            • Feb 2015
                            • 10
                            • arak
                            gooooooooooooooooooodwork
                            • kodox
                              • Jul 2017
                              • 329
                              • Indonesia
                              After i flashed using CH341A programmer, it said that "size don't fit & will auto-adjust". Laptop still dead, but thank's anyway....
                                • 21841
                                Try this one .
                                • skinner
                                  • Jun 2013
                                  • 60
                                  I know this is an older post but if you get that issue it's because you're using too small of chip to but the bios on.
                                    • 21841
                                    In this case its because the bios by the OP is 4,097 KB ,it should be 4,096 KB ,thats what the CH341A expects. You can delete the last 4 KB from the bios with a hex editor (the last line) , or use the bios at post #16 .
                                    • othmen
                                      • Jan 2017
                                      • 3
                                      • tunisia
                                      thanxxxxxxxxxxxxxxxxxxxxxxxxx
                                      • audrimars
                                        • Apr 2020
                                        • 48
                                        • palestine
                                        hi - I need bios n5110 inspiron but (a11 ) to be good for windows 10
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          Dell 9010 MT BIOS Update Always Fails
                                          by mikeybass
                                          Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
                                          04-23-2025, 04:30 PM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
                                        • Akhlz001
                                          Dell Pro 13 Plus PB13250 Bios Unlock
                                          by Akhlz001
                                          Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                                          09-20-2025, 07:15 PM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
