Hello all,
I am intending on fixing my A&H PSU board myself, since I cannot afford the £100+ for a new board, I can visibly see that some of the caps are bulging on the board and one has leaked (see pictures).
The caps are as follows
1 (C57 board location). Samwha HC series, Model R3D, 400WV 68uF 85°C (M) - Width 22mm Hight 20mm
Intended replacement - Electrolytic Capacitor Samwha HK series, Model C92, 400WV 68uf 105°C (M) - Width 22mm Hight 20mm I in fact found the exact replacement, but I believe I am correct in thinking the higher rated 105°C will afford a better performance and lifespan with no down side.
2. (C64, C65, C67 board location) Samwha WB series, Model R6A, 25 V 407uF 105°C (M) Width 16mm Hight 10mm
Intended replacement - RUBYCON - 25ZLJ470M10X12.5 - CAPACITOR, RADIAL, 25V, 470UF
3. (C66 board location) Samwha WB series, Model R0A, 25 V 407uF 105°C (M) Width 16mm Hight 10mm - Here I have a problem and the problem is this capacitor seems to be EXACTLY the same as the one listed above (2.) except that it seems not to have failed (so looks shorter in hight but isn't) and has a different model number (R0A) I know that the ripple current rating is VERY important in this type of PSU and the R6A has a ripple current rating of 1430 ((mA rms) 105°C 100kHz) so maybe the different model number was a specific rating, unfortunately I cannot find specs on it and therefor have no way of knowing what hidden qualities it's replacement might have to have.
If anyone can recommend a replacement as close to the same spec or higher I would really appreciate it, I am a novice at this and I know that PSU's need to be right since the voltages involved are very high, also honestly A&H mixers aren't cheap and I cannot afford to inadvertently fry any other components. hehe
So any other suggestions or advice would be wonderful. I also found this nice bit of info on these caps that might be of help for others looking for info on these caps visiting the board.
http://forums.cnet.com/7726-13973_102-3130121.html
So I will replace all the Samwha crapcaps.. yay!
