Sony CPD-15SX1 - Bad convergence in upper left corner
  • lti
    • May 2011
    • 2558
    This monitor was given to me about fiive years ago, and it has always had the issue shown in the picture. You can see that the black outline of the mouse cursor is offset from the white cursor. Blue lines up properly, but green and red are not in the correct location. Other than this, the monitor gives a good picture. What could cause this?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sony CPD-15SX1 - Bad convergence in upper left corner
    It's a convergence problem. CRT monitors are prone to this problem.
    PlainBill
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      I believe you have some adjustments in the menu, but they are for the overall picture.
      Trinitron tubes are prone to this kind of local convergence issues - they are corrected in the factory by small magnets placed around the tube. You can try taking it apart and placing small fridge magnets on the back of the tube in the affected area to see if you can improve it without affecting the rest of the picture. Use Nokia Monitor Test for the generation of convergence patterns.
      A working TV? How boring!
      • b700029
        Banned
        • Sep 2010
        • 640
        If it's only in that corner, it may be a slightly bent aperture grill. Unfortunately not fixable.
        • lti
          • May 2011
          • 2558
          I can't figure out how to take it apart. Something is holding the back cover on along the top edge, but I can't see what it is.
          It only affects that corner and doesn't extend past the My Computer icon on the desktop.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            There may be 2 or 3 plastic latches on the top. Should be similar to LCD monitors, but usually much easier to unhook them, though.
            Try running degauss a few times and see if that fixes the problem. If not, then perhaps try Th3_uN1Qu3's method.
            There's also this, but I don't think this will help your problem:
            http://www.youtube.com/watch?v=j404EgmdXSU
            By the way, good to see another Trinitron user.
            I still have my Dell D1025HTX. It has absolutely amazing colors. Was watching a movie on it a few weeks ago. At one point in the movie, there was this dark room with bright windows - the dark spots in the room were truly black whereas the windows were blinding white. Good luck getting that on any LCD monitor.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              You know what's funny? I have both Trinitron and regular shadow mask CRT monitors. I like the shadow mask one better.
              • PlainBill
                • Feb 2009
                • 7034
                And I have a 23" LCD monitor. And I love the viewing area, even though it's color rendition makes Th3_uN1Qu3's avatar look like a corpse.
                PlainBill
                • lti
                  • May 2011
                  • 2558
                  You should see the Dell E772c monitor that my parents use. I don't know why, but the color rendition is completely screwed. First it had a yellow tint, then it had a red tint. Currently, gray looks more like pink and blue objects really stand out against everything else.
                  On the Sony monitor, I can't find the latches along the top edge. There are two slots on the top edge, but I don't see any way to unhook any latches that might be there. The problem has existed for at least five years, so it should have been degaussed enough times.
                  It seems that this monitor has trouble displaying dark colors unless the brightness is turned up to an insane level.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    The latches may be next to the slots (or they may be far away too).
                    Post some pics if you want. CRT monitors are usually very easy to open.
                    Try playing around with the brightness, contrast, color temperature, and color adjustment (if available).
                    Normally on CRTs, I put all of the colors and contrast in the high 90's (%), and color temperature around 7500K to 8000K. As for brightness, that depends on the tube itself. I have several test patterns I can upload if you feel like playing around.
                    Yeah, I have both shadow mask and Trinitrons as well. Can't say which I like better though - it just depends on the occasion. For watching movies, playing games, and viewing images, I prefer the Trinitron because it has superior colors. For reading text or editing images, I prefer my shadow mask Samsung SyncMaster 955DF because it's more crisp.
                    In this summer-like weather, though, I'm now using my family's computer (which has a 17" LCD). Those CRTs are better suited for the winter when it's cold .
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      6500K FTW.
                      One thing i don't like about the Trinitron is that due to its phosphors being aligned in strips, it suffers from some kind of pixelization at very high resolutions (that is if you can reach those high resolutions without running into focus issues), whereas a shadow mask just gets blurry if you go past the tube's physical resolution. I run 1440x1080 on a 19" CRT, so if i get an LCD it would actually be a downgrade unless it's 1680x1050 or higher.
                      True, my monitor puts out a fair amount of heat but then again, so does my computer itself. And i don't have any LCDs anymore. I was contemplating a LG 22" widescreen with a color issue (most likely bad cable), but nah... i'm sticking to my boob tube for the time being.
                      • lti
                        • May 2011
                        • 2558
                        Now this monitor has another problem. The convergence is completely screwed along the right edge of the screen. The problem gets worse at lower resolutions and is very hard to see at 800x600. I will post pictures of this later.
                        • lti
                          • May 2011
                          • 2558
                          Here are pictures of the top of the monitor and the problem that I am having. This only happens to white objects along the right edge of the screen. Any objects that are another color are displayed properly.
                          My camera never focuses on the object you are trying to take a picture of. Its OSD will place a box around the object I want to take a picture of, but it actually focuses on a random object or takes a picture that is completely out of focus.
                          Yes, that game was running at four frames per second. I really need to get a computer that isn't made by Compaq.
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            Looks like there are latches right next to the slots (to the right for the slot on the left and the left for the right slot). Try sliding a thin object (like a putty knife or an old credit/debit card). If not, perhaps use a flashlight into one of the slots and see if you can see anything (maybe a special tool must be inserted in the slots?? - I doubt it, but still).
                            Normally, most CRT monitors of this size and age have only 4 screws and about 4 latches or so.
                            Not sure about the focus issues, though (both the new and the old one).
                            Yeah, I've noticed that, too. That's why I usually run mine at the recommended resolution.
                            • lti
                              • May 2011
                              • 2558
                              There are latches in those two areas. I just found them.
                              This monitor has those two latches at the top and two screws at the bottom. The base is attached to the back cover.
                              That issue you mentioned is strange. This monitor has a maximum resolution of 1024x768, and I never noticed any issues. If you set the resolution above 1024x768, the monitor shuts off and the power LED starts flashing orange.
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                So you mean it's a 15" ??? And you're playing _old_ games but still can't get past 4fps? Sheesh... you really DO need a better computer. I don't bother fixing any screen unless it's 19" or larger. I do have a laptop which has 800x600 as its native res... but that one runs DOS games just fine. And most of the early Windows ones too, like MDK, GTA, GTA2... It has a 2MB Trident video chip - i don't think you can do much worse than that.
                                So either you're trying to run a "newer" game (try a Voodoo II, or a S3 Savage4 but that's AGP), or there's something very, very wrong with your computer.
                                • lti
                                  • May 2011
                                  • 2558
                                  I was using this computer. It's a Compaq, so it will always be slow and unstable. That game was running at 320x240.
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    Well, i have a Compaq Deskpro 4000 that works great. And it has 8 (eight) SIMM slots and onboard LAN. It also weighs a ton, you'd think the Russians built it. And it has a power supply with a 92mm fan.
                                    • howardc64
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
                                    • Watson306
                                      6 Red Blinking lights (left side darker) on Sony KD-49XE8396
                                      by Watson306
                                      I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
                                      I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
                                      I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
                                      Many Thanks in advance.
                                      11-01-2022, 05:33 AM
                                    • Carlos#2003%
                                      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                      by Carlos#2003%
                                      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                      02-15-2024, 07:52 PM
                                    • spleenharvester
                                      Whirlpool PACF212HP W portable air conditioner, upper fan only turns slowly.
                                      by spleenharvester
                                      I just acquired this portable aircon, history unknown. Its behaviour is quite strange:
                                      • When turned on and placed into cooling mode, the upper fan (cold air out) just spins slowly. The compressor and lower fan do not run.
                                      • If the device is then placed into heating mode and then back into cooling mode, the lower fan and compressor kick in and start cooling, but the upper fan still only spins slowly.
                                      • If the device is placed into fan-only mode, the upper fan does not respond to low/medium/high speed toggles - just keeps running slowly.
                                      • Display and buttons all behave normally aside from the
                                      06-27-2025, 07:49 PM
                                    • dkneyle
                                      Sony KDL-46HX850 Can't upgrade/update firmware
                                      by dkneyle
                                      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                      09-25-2024, 10:44 PM
