Dell E172fpb
  • syclonejim
    • Jan 2006
    • 4
    Dell E172fpb
    I have a Dell E172fpb 17" lcd manufactured by BenQ. It will not power on, the power button justs blinks green and the screen flashes. I have taken the panel apart and examined the power inverter board. There are no bulging capacitors, but it is full of Lelon caps. I have seen on this forum that this brand is considered one of the least desireable. Anyone have any experience with this LCD panel or problem? I have done several other capacitor repairs, but always the sure tail sign(bulging).
  • Paylesspcrepairs
    • Mar 2006
    • 1
    Re: Dell E172fpb
    I have the same 17" Dell/Benq LCD Monitor with the same problem. Do you have any advise for me on a fix for this monitor? -- Any help would be great!
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Re: Dell E172fpb
      post a pic of the inverter and logic.
      • HelpQuick
        • Mar 2006
        • 5
        Re: Dell E172fpb
        I have the same monitor for repair, pics as requested...
        Regards
        Richard
        • japlytic
          • Oct 2005
          • 2086
          Re: Dell E172fpb
          This board was a little bit confusing at first to determine which connectors are not at mains potential. CN701 (and CN753) are safe to measure, because there appears to be a blank area of PCB between it and the primary side.
          The first area to make measurements is CN701 (low voltage power supply). Also measure the output on diodes D751 and D761. Take care when measuring CN752 and CN753. You may need to measure voltage between each pin of these connectors, instead of GND.
          • Rainbow
            • Aug 2005
            • 1374
            Re: Dell E172fpb
            CN752 and CN753 are high-voltage supplies for backlight - I'd not mess with that. It either works (backlight lights) or not (backlight does not work but everything other does - if you light it up with something strong, you can see picture).
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              Re: Dell E172fpb
              what is backlight getting, i thought it was 12v?
              • HelpQuick
                • Mar 2006
                • 5
                Re: Dell E172fpb
                Symptoms...
                If the monitor is connected to a PC (in windows or whatever), when you first power it up, you get a very quick flash of the windows desktop on the display. The power LED then starts flashing at a rate of around 1 flash per second.
                I have taken voltage readings at CN701... Pins 9 & 10 pulse 3.3V, but as i'm using a Digital VM, it seems to fluctuate between 1.5 and 3.3V. Pins 7 & 8 pulse between approx 2 and 5.0V. Pins 3 - 6 are GND.
                If you listen closely to the board, you can hear a "tick" when it pulses... my hearing is not great, so i can't pinpoint where the "tick" is coming from...
                If anyone is interested, I've attached a pic of the under-side of the board.
                • Rainbow
                  • Aug 2005
                  • 1374
                  Re: Dell E172fpb
                  The bottom of the PCB is discolored so it certainly runs hot. Maybe some of the caps are dried out. If they're crap brand, they can go fast.
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    Re: Dell E172fpb
                    here is an interesting thread
                    http://www.network54.com/Forum/87612...9/DELL+E172FPB
                    regarding the caps, those elna style vents suggest koshin caps. i would be interested to know if they test off spec.
                    its hot in the region of the fets.....
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      Re: Dell E172fpb
                      the ticking suggests the pwm is starting and then hitting the overcurrent limit.
                      or lack of feedback from the opto causing same.
                      i would change out any caps in the darkened areas anyway.
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        Re: Dell E172fpb
                        on that thread i linked they had some fets going bad. but there has got to be a reason for that? badcaps running fets hot? or just bad design
                        i would sink them anyway once you get that up an running. looks kinda toasty there. edit : actually forget that some are sinked the others impossible.
                        • HelpQuick
                          • Mar 2006
                          • 5
                          Re: Dell E172fpb
                          Ok, on my board, the blue caps are brand new (maybe still crap, limited stockists nearby and not enough time to order over the net), labeled C751, C703, C712 C709, C707, C708 and C710.
                          D701 and D702 are UGF10DCT Diodes (with sinks).
                          Thanks for the link willawake... Looking at that, it looks like the same problem I have, so, does anyone know of a stockist in the UK that has some 2SC5707's (Edit: or equiv) (in lower quantities than 700)? Quick google didn't reveal much...
                          Thanks for all the help!
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            Re: Dell E172fpb
                            you should test them before ordering. guys please explain again how to test fets.
                            digikey will supply if rs/farnell/elfa dont have
                            better to recap also anyway for a final repair, it is not too many caps.
                            • Rainbow
                              • Aug 2005
                              • 1374
                              Re: Dell E172fpb
                              If there's something shorted (like one of the transistors), you can find it using "beep" multimeter function.
                              • HelpQuick
                                • Mar 2006
                                • 5
                                Re: Dell E172fpb
                                Thanks all for your help...
                                I tested the transistors Q759 and Q760 were shorted, I have swapped these, and the monitor now works great!
                                Once again, Thanks to all who helped!
                                • briand805
                                  • Mar 2006
                                  • 7
                                  Re: Dell E172fpb
                                  I have the exact same monitor and as of tonight the same exact symptoms.
                                  I pressed the power button and it broke. At this point the monitor started to flicker on and off once a second with the green light pulsing at the same time as well as a small click or chirp.
                                  I took it appart and can not see any damage to the actual led or switch.. just the button is broken on the monitor face.
                                  I can see no damage to the small board the led and switch is connect to.
                                  Luckily I have someone here who is familiar with working with boards and they will take a look at it.
                                  Thanks for the info.
                                  • HelpQuick
                                    • Mar 2006
                                    • 5
                                    Re: Dell E172fpb
                                    The monitor that i had fixed with the help of this forum has once again failed... this time, the monitor works for around 2 hours, then goes off with the original symptom.
                                    If it's left off for a while, it can be used again for about 2 hours (presumably some sort of thermal problem)
                                    I haven't had a chance to look at it again yet, but will let you know how i get on.
                                    • mkuan
                                      • Apr 2006
                                      • 1
                                      Re: Dell E172fpb
                                      Hi, I am new here and I have the same problem with the monitor. The first problem is that I don't know how to open the monitor -_-, Plz help.
                                      • jumba
                                        • May 2006
                                        • 13
                                        Re: Dell E172fpb
                                        Many, thanx for the solution, the trannies are shot.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
                                        • diamon
                                          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                          by diamon
                                          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                          Pictures of these boards:
                                          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                          Dell...
                                          02-28-2024, 12:51 PM
                                        • master3112
                                          Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
                                          by master3112
                                          I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
                                          Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
                                          The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
                                          07-29-2025, 01:55 PM
                                        • OntarioTL
                                          Dell 5410 greyed out BT
                                          by OntarioTL
                                          Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                                          If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                                          Dell Lattitude 5410
                                          Service Tag...
                                          07-25-2025, 01:28 PM
