Lenovo T590 bios
  • huzo
    • Sep 2014
    • 178
    • CROATIA
    Lenovo T590 bios
    hello guys, can someone check the dump?
    when power button is pressed, the keyboard and caps and power button went on for a second, and then died... then i tried flashing dumps i found, and now only gives 3 power light flashes when charger connected... i even restored original dump, and it only lights up power button 3 times....no keyboard light or caps or anything...
    the chip is 25Q256JVEQ, 3.3V
    the board is FT490/ FT492/FT590/FT591 NM-B901
    the original dump is in the attachment
  • huzo
    • Sep 2014
    • 178
    • CROATIA
    Re: Lenovo T590 bios
    i need to explain something,
    so first time i extracted the dump, i did it with 1.8V adapter by mistake, and then i used the ordinary ch341 to extract the dump...
    and i tried the ordinary 3.3V dump back, and it doesn't work, but the one i extracted with 1.8V adapter works like it did in the first place, (lights,and fan spin for a second)
    i compared the hex files, and they are not the same! altough the size in .bin is the same, 32.768, when packed in .rar it's not the same!
    here are both files, someone please explain how is this possible?
    and please check my dumps...the one named 1.8V gives some signs of life,so i would say that one should work.
    • OKRPKCOMP
      • Dec 2020
      • 429
      • PAKISTAN
      serial no, type ?????
      here is password protected bios for just checking if it is bios problem or somewhere else
      https://www.badcaps.net/forum/showthread.php?t=90076
      • huzo
        • Sep 2014
        • 178
        • CROATIA
        i've tried that dump, along with few others i found here on badcaps...non work ,just 3 blinks on power button, except the original i dumped from the chip that acts like i described...keyboard light and power light and fan spin for a second...
        i didn't know that the exact type and serial is important,but here it is : TYPE: 20N4-000DSC S/N PF-1QDB04
        • OKRPKCOMP
          • Dec 2020
          • 429
          • PAKISTAN
          T590 (Type 20N4, 20N5) Laptop (ThinkPad) - Type 20N4
          try and feedback
          • OKRPKCOMP
            • Dec 2020
            • 429
            • PAKISTAN
            if not working then more tries
            S/N PF-1QDB04
            • huzo
              • Sep 2014
              • 178
              • CROATIA
              ok,manny thanks friend!
              will give it a try when i get home!
              Have you found something corrupted in the dump?
              i forgot to mention, i also have a small dump 1mbit, but i think that one isn't the issue...i will give this a try,and report back...
              • huzo
                • Sep 2014
                • 178
                • CROATIA
                nothing....all act the same...lights up, fan spins and goes dead...all 3 dumps...
                i've attached 1mbit dump also...if you could check?
                • hardware1
                  • Sep 2021
                  • 2939
                  • N/A
                  This chip is for Thunderbolt (as far as I know), so solder it back.
                  About your Main BIOS, you can try this New BIOS, I build it using your file from post #2 "t590 orig 3.3V".
                  I think your CPU should be "i5-8265U" or "i7-8565U".
                  all donations are welcome,
                  • huzo
                    • Sep 2014
                    • 178
                    • CROATIA
                    yes it's i7 8gen...that 3.3V that i posted didn't work at all, only three power button flashes,no reaction to any lights,not turning any voltages except 3.3V and 5V on board...but i will give it a try...if you could take a look at the one marked 1.8V...i think ,that one should be repairable!
                    • hardware1
                      • Sep 2021
                      • 2939
                      • N/A
                      The 1.8v file isn't good at all, you can't read a chip that needs 3.3v with 1.8v adapter.
                      • huzo
                        • Sep 2014
                        • 178
                        • CROATIA
                        but i did download it with 1.8V adapter, i am sorry i didn't do a chip detection to see what neo programmer sees... i know that it needs at least 2.7V to read 3.3V chip, but somehow it did it...and i tried to compare dumps in hex editor and same chip, different data...one read with 1.8V, other with 3.3V...
                        I tried the dump you posted, it's like all the others, it doesn't work, it's always the same... keyboard light, power light,fan spin for a second an that's all...i am thinking there is something else wrong...i disconnected everything from the board, only left power button and charger...the same...
                        I opened another thread in troubleshooting section,since i doubt the bios is an issue, there i will explain some measurements...
                        https://www.badcaps.net/forum/showthread.php?t=120926
                        • huzo
                          • Sep 2014
                          • 178
                          • CROATIA
                          i found something odd in the schematics...
                          on VCC, pin 8, there is a diode ,before diode there is 3.3V,after diode 1.5V on the VCC pin, so the diode is bad, i shorted it and now i get the 3.3V on VCC, but symptoms are the same, it still doesn't work...could the chip itself be damaged?Because the erasure and blank check and programming and verify goes all ok...i got the error first time i deleted the chip something about the erasure control and registry bits....i forgot what it was, i just pressed ok...
                          • alexandrebrigues
                            • Feb 2023
                            • 5
                            • Brasil
                            Good evening, Could you please try to fix my bios. Motherboard: Nm-b901 rev 1.0 (T490-20n3), I lost the serial number.
                            removed the bios with Ch341a, and it corrupted. laptop lights up, I hear a beep and turns off.
                            • jeffl1980
                              • Aug 2024
                              • 12
                              Lenovo T590
                              Model 20N5S0W300
                              SN PF1BXUWM
                              Mobo FP531
                              In attempting to bypass the BIOS password, I misinterpreted the instructions as referring to CPU gen instead of Thinkpad gen. As a result of my error, I followed the DXE password bypass driver injection instructions and flashed a new BIOS created by the Lenovo Autopatcher python script. When attempting to boot the patched BIOS, I heard continuous beeps but couldn't enter the BIOS menu. FWIW, I couldn't find any material on the web about an anti-tamper switch. I flashed the original BIOS back to the chip, at which point the laptop showed no signs of life other than an orange light on the underside indicating power (indicating a problem perhaps). I've done multiple reads of the BIOS chip and confirmed using an MD5 checksum that it matches what was originally on the chip. This doesn't appear to be a problem with corrupted BIOS I believe.
                              I would like to get the laptop back to a working state so I can execute the Flashing EC procedure mentioned in the sticky post.
                              What are the recommended steps to recover?​
                                SMDFlea commented
                                Editing a comment
                                Thread merged. Post your original bios backup.
                            • jeffl1980
                              • Aug 2024
                              • 12
                              Please see attached for original BIOS image.
                              • jeffl1980
                                • Aug 2024
                                • 12
                                I've tried reviving my T590 over the last two weeks to no avail. Any recommendations on how to approach troubleshooting?
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11815
                                  T590 Laptop (ThinkPad) - Type 20N5
                                  • jeffl1980
                                    • Aug 2024
                                    • 12
                                    Thank you, hoaca388.
                                    I switched to Neoprogrammer. Now I can consistently read the BIOS image that I write. In other words, the md5 checksum of the image I write to the IC matches the md5 checksum of what I read back from the IC. This is progress as I couldn't do this previously. I wrote my original BIOS and the BIOS that hoaca338 provided. I removed the battery, external power, and CMOS battery for 30 seconds. I pushed the button to disconnect the battery (even though this is probably not needed). The behavior is the same: the laptop shows no sign of life. The LED near the power connect glows orange as shown in the pic below.
                                    What else can I try to restore this laptop?
Name:	2024-09-18 08.43.26.jpg
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11815
                                      Come here : https://www.badcaps.net/forum/troubl...mobile-devices
                                      • AHmad_Salal
                                        Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                        by AHmad_Salal
                                        Hello all,
                                        I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                        11-28-2023, 05:28 AM
                                      • Ahari
                                        by Ahari
                                        I...
                                        08-13-2025, 06:12 AM
                                      • hyperwood
                                        [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                        by hyperwood
                                        Hi everyone,
                                        I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                        The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                        I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                        ✅ What I need:
                                        • A working 2MB BIOS dump
                                        • Matching NM-E471 Rev. 2.0, e.g. JY575
                                        06-25-2025, 02:28 PM
                                      • Habble7
                                        I need a BIOS dump for the Samsung S49CG934SU monitor
                                        by Habble7
                                        The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                        Suspected Cause:
                                        I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                        Troubleshooting Attempts:
                                        05-22-2025, 07:28 AM
                                      • Joluvillas
                                        Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                        by Joluvillas
                                        Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                        06-18-2024, 10:35 PM
